Hmm, how can you *not* mount a drive correctly in a ThinkPad X? What I know is that using the same X, the same tray and the same screws, the Hitachi 7200 rpm vibrated (when on a hard surface) where as none of the several Toshiba's 5400 rpm I have did. Maybe I just had back luck with the one Hitachi 7200 rpm I had.bhtooefr wrote:That said, I've heard the stories about loud vibrations with 7200RPM drives in X31s and 32s. The secret, from what I've heard, is making sure it's mounted correctly.
-Dominique
