Fastest CPU for X31? + more RAM + 7200rpm HDD?
Don't you guys think 2Gb of ram is to much? i say just get a 1gb chip
if you have to much ram in a computer it might actually slow down your comp meaning the computer has to render thru all that ram just my thought ... i have 1gig in mine right now
img]http://tinypic.com/e71mk0.gif[/img] ThinkPad X31 - Centrino - 1.7ghz[26725KU] 1gig ram, Fujitsu 80Gig HD-5400RPM,WiFi - "no Bluetooth =("
ThinkPad X60 - Centrino Duo 1.83ghz[1709CTO] 1gig ram, 80Gig HD-5400RPM, w/BlueTooth
Excess RAM isn't a problem at all, except on Intel chips with more than 3GB RAM. (AMD's 64-bit chips aren't a problem with more than 3GB)
Seeing as this is only 2GB RAM, it'll be fine.
Can you really see the diffrence between 1gig and 2gig mem?
FRiC
Like others have said, it all depends on what you do, but be careful about monitoring RAM with XP's task manager. XP's swapping and memory management is quite efficient, and it might not be obvious by using the task manager to see whether you need more RAM.
In my experience, upgrading from 512 MB to 1 GB yielded minimal speed increase. It's as if 512 MB is already plenty enough to handle everyday apps, while 1 GB still isn't enough for the memory intensive apps. However, when I went to 1.5 GB or 2 GB, there was a tremendous speed increase for the memory intensive apps. (My memory intensive apps are Photoshop CS2, Nikon Photo Capture, Simatic Step7/WinCC, and VMware.)
X230 | i5-3210M | 8GB | 500GB | WWAN
Try this:YukYukLee wrote:"no Bluetooth =("
http://forum.thinkpads.com/viewtopic.php?t=15986
Would probably work on the X31, and for $3.99, who cares if it does not?
-Dominique (X31 *with* Bluetooth)
Theoretically, the battery life will be shorter.
The larger RAM chips have more transistors. Each transistor takes power. So, 2GB of RAM will be twice as many transistors as 1GB of RAM, and will use more (note that I did NOT say twice as much - IIRC, it doesn't scale linearly) power.
Ok, but the power used by memory chips cannot be *that* much, can it? Would it even be noticable?
Also, notice that with more RAM you will use the HD less often, among other things. Although this may not apply to Windows (don't use it, so would not know).
Also, how much does dimming the LCD help? It just seems like it should help a lot, but there are users that seem to have tested it and say that it does not make that big of a difference (which seems odd to me).
Windows will *ALWAYS* use the HDD for swap, however, it swaps less with more RAM.
If you're slamming RAM with lots of Photoshop stuff, you'll DEFINITELY hit the HDD less with 2GB. RAM does take less than the HDD.
Also, the difference between 1GB and 2GB when less than 1GB is used would be a few minutes of battery, max.
Hey domi, I just ordered that Bluetooth Daughter Card.. I was just wondering wether i need something else with that card, or will it just work without any antenna's
I think it will work, but your Bluetooth devices (eg. mobile phone) will have to be closer to your TP than with the built-in antenna.YukYukLee wrote:Hey domi, I just ordered that Bluetooth Daughter Card.. I was just wondering wether i need something else with that card, or will it just work without any antenna's
-Dominique
That doesn't seem to be true in my case. There was no "minimal" speed increase, rather a HUGE speed increase. When I upgraded from 512 to 1024, the entire system was noticeably snappier, and didn't slow down after two hours or more of use. Memory intensive apps, in my case, photoshop cs2, were much faster and efficient.FRiC wrote:Like others have said, it all depends on what you do, but be careful about monitoring RAM with XP's task manager. XP's swapping and memory management is quite efficient, and it might not be obvious by using the task manager to see whether you need more RAM.
Of course, having 1.5GB would help even more, but the speed from 512 to 1024 is not nominal. It's the difference between day and night!
Phil
IBM X40, 2371-AV0
Lenovo T61, 6458-AB1
En route: X61t
IBM X40, 2371-AV0
En route: X61t
True, but the fact is that an upgrade from 512 to 1024 is a huge difference. We all know that the more memory there is, the better. I just want to clarify that the extra 512mb of memory DOES make a difference. Try using the same image you mentioned with only 512mb. Then try it with 1024. You'll notice a very, very, very, very big difference. I might as well say that that the difference from 1024 to 1536 is minimal...
Phil
IBM X40, 2371-AV0
En route: X61t
IBM X40, 2371-AV0
En route: X61t
Do you know where i can buy the antenna's and how to install it on my Thinkpad?domi wrote:I think it will work, but your Bluetooth devices (eg. mobile phone) will have to be closer to your TP than with the built-in antenna.
-Dominique
SOLD excellent condition T520 with *FHD* screen (1920x1080), i5-2540 cpu (2.6GHz), 4GB RAM, 320GB HDD
by tpdude4 » Sun Feb 26, 2017 8:33 am » in Marketplace - Forum Members only - 0 Replies
- 1166 Views
Last post by tpdude4
Sat Mar 04, 2017 6:46 am
FS: T520 with i5-2540 cpu (2.6GHz), 6GB RAM, NVIDIA 1GB gpu, 1600x900 screen, 160GB HDD
by tpdude4 » Sun Jun 25, 2017 6:09 am » in Marketplace - Forum Members only - 0 Replies
- 77 Views
Undervolting CPU in Windows 8 / 10 ? RMclock doesn't work any more.
by zoltan87 » Fri Feb 17, 2017 10:26 am » in ThinkPad T6x Series - 6 Replies
- 2480 Views
Last post by lab
Sat Mar 18, 2017 11:55 am
Cpu upgrade what cpu to search
by radiator » Sun May 21, 2017 12:45 am » in ThinkPad T400/410/420 and T500/510/520 Series - 2 Replies
- 529 Views
Last post by my03
Sat May 27, 2017 6:22 pm
