R50e + Pelican 1490
Newarkizise
R50e + Pelican 1490
#1 Post by Newarkizise » Wed Sep 28, 2005 9:30 am
Hi
3 pics of my girlfriends R50e and my Pelican 1490.
thePCxp
#2 Post by thePCxp » Wed Sep 28, 2005 11:46 am
Cool R50e! (and pictures)
cruzlite
#3 Post by cruzlite » Fri Sep 30, 2005 7:54 am
I have a pelican also...Great case!
Use caution when running machine while in case...(As in top pic)...
!!!!!!!!!!!!!!The foam/etc. can cut off cooling intakes & exhaust!!!!!!!!!!!!!!!
T41-2373 9FU/Banias@1.7ghz/i855/1gb
60gb7200/14.1sxga/ATI9000
CD-RW/DVD/802.11abg/xp Pro sp2
doppelfish
#4 Post by doppelfish » Fri Sep 30, 2005 8:34 am
Second on the 'cool case' opinion. One less thing to worry about when you're porting your portable computer (i mean, that's the point of these things, innit).
How do the dividers stay in place? I can't make out any slots into which they would fit ... can you reseat them?
cheers,
-- fish
Newarkizise
#5 Post by Newarkizise » Fri Sep 30, 2005 10:30 am
Now when I use the case with my R52, which is a little wider than the R50e, I ripped one line of the sidepadding away, and made with a knife a little hole for the fanhole, and removed one of the soft paddings which was under the computer.
So now i suppose the computer can atleast somehow cool itself.
Though as, i rarely use my computer in the case.
(Sorry maybe a bit bad english..)
