I have cpufreq activated and even when I select to run at 600Mhz the fan does the stupid pulsating noise, although the temp drops down to ~30C...s0larian wrote:Do you use the cpufreq deamon in Linux? If this is deactivated or not installed, the fan runs all the time.
T40/R50 pulsating fan: new embedded controller bios?
There is a new Embedded Controller Bios on IBM's Web Site
29 Jul 2004
1RHT70WW
...BUT at the moment it's still linked to the old version from 7/13 (or did someone hack the site
http://www-307.ibm.com/pc/support/site. ... MIGR-55029
let's hope the solution for the pulsating fan will turn up soon...
29 Jul 2004
1RHT70WW
eriqesque
If you are plugged in the fan should be running unless you are in a freezer. The fan is what keeps your CPU cool ya know.vpn-user wrote:Pulsating has gone. But FAN ist still running all the time, IBM just does not care. The links work now.
BTW: My IBM-Clone battery does not work anymore since version 3.02...
If you want the fan to stop unplug.
eriqesque
RoadHazard
When I take my X31 down to 600 Mhz the fan stops spinning and temp stays at 40C. My T40 fan doesn't although temp gets down to 29C. It has nothing to do with keeping the temps down, it is a manufacturing error and should be corrected.eriqesque wrote:If you are plugged in the fan should be running unless you are in a freezer. The fan is what keeps your CPU cool ya know.vpn-user wrote:Pulsating has gone. But FAN ist still running all the time, IBM just does not care. The links work now.
eriqesque
BlauAufmBau
[Done] T43 Embedded Controller upgrade problem
by x3o2 » Wed Apr 26, 2017 11:51 am » in ThinkPad T4x Series - 3 Replies
- 608 Views
Thu Apr 27, 2017 8:09 am
W530 embedded controller chipset ?
by constsp » Sun May 28, 2017 7:16 am » in ThinkPad W530 and later Series - 2 Replies
- 168 Views
Last post by constsp
Sun May 28, 2017 7:36 am
Wake up after suspend problem on T41 with new SSD on IDE2SATA controller
by Mac-Chatter » Sat Mar 04, 2017 6:10 am » in ThinkPad T4x Series - 0 Replies
- 1709 Views
Last post by Mac-Chatter
Still get a "Fan error" after replacing fan
by thinkpac » Sun Apr 02, 2017 12:44 am » in ThinkPad T6x Series - 7 Replies
- 1212 Views
Last post by thinkpac
Sun Apr 02, 2017 11:17 am
