upgrade to Bluetooth
ejwt
#31 Post by ejwt » Thu Mar 02, 2006 7:16 pm
marcos wrote:
The bluetooth device is found as soon the radio is turned on, you will need this:
http://www-307.ibm.com/pc/support/site. ... MIGR-38953
Press Fn+F5, turn blutooh on, and the installation should complete.
Thanks marcos, that did it!
Delmarco
#32 Post by Delmarco » Sat Mar 11, 2006 3:03 pm
Okay,
I also don't have Bluetooth on my T41,
Can I just buy a BlueTooth PCI card adapter? I already ordered a Class 2 (100 meters) BT card from ZOOM (www.zoom.com).
I noticed no one mentioned this as an option. So now I'm wondering if Bluetooth PCI cards will work on IBMs T40 series?
Buried: T41 2379-DJU sxga 1.8Ghz 100GB
Cremated: T60 2008-VEP sxga 2.0Ghz 320GB
Travel: T61 8892-02U sxga 2.2Ghz 420GB
Home: W500 4062-4HU wuxga 2.8Ghz 320GB
mtroxel
#33 Post by mtroxel » Sat Mar 11, 2006 3:11 pm
Delmarco wrote:So now I'm wondering if Bluetooth PCI cards will work on IBMs T40 series?
When you say "PCI card" I think you mean to say PCMCIA card...the little credit card size things that go in the side. If that's what you mean then I'm sure it's going to work. If you don't hear us talking about that as an option it's because we're all a bunch of techno-weenies who think it's important to have the bluetooth all integrated into the laptop.
Your method might be cheaper and is way faster....just not as integrated
T-400 7417TRU Boots into XP, two virtual machines.
Core2Duo E8400 (2,26GHz), 3,072 MB RAM
120GB 7200rpm SATA HD, 14.1in Widescreen LCD
DVD R/W, Intel 5100 wireless, bluetooth
