For practical purposes:
- settings -> end of task -> disable timer
- energy-settings -> disable all
greets
kw
Hi Shimodax,geoffrey wrote:No problems here using v017 on a T43 2668F7G. Works like a dream... Only wish now is to be able to control the slight pulsing on the lowest fan level. This fan level would be inaudible if it weren'f for the buzz every 5 seconds that sounds like a bee has got stuck inside the computer.
Thank you very much for all your dedicated work, Markusgeobel wrote:Some more analysis. The program works fine on my T40 in spite some sensors are absent/not read.
speed setting vs fan speed :
1,2 2900-3000 rpm
3,4,5 3500-3700 rpm
6,7 4000-4100 rpm
Accordingly the following table should be better for smart mode on T40 than default:
Level=47 0
Level=50 2
Level=55 4
Level=60 7
Level=70 128
Finally would be nice to fix continuous recording of a warning message in System log in event viewer:
The embedded controller (EC) hardware returned data when none was requested. This may indicate that the BIOS is incorectly trying to access the EC without syncronizing with the OS. The data is being ignored.
George
The system log file will reach its max size in a few seconds with the warning message GEOBEL mentioned above,after that,it can't record other events at all.geobel wrote: Finally would be nice to fix continuous recording of a warning message in System log in event viewer:
George
Well, system will always be able to record events. The problem is that any recorded event is quickly overwritten by the continuously recorded warning message.lywsp wrote: The system log file will reach its max size in a few seconds with the warning message GEOBEL mentioned above,after that,it can't record other events at all.
Will the next version fix the bug?
No, we are talking about Windows System log. Can be seen via Event viewer (Control Panel/ Administrative tools/Event viewer)Shimodax wrote: Regarding the log. The program does write a logfile to disk (with everything that's also shown in the log part of the window ... the file fancontrol.log).
Are you getting so many errors that these quickly scroll out of the window? The log window has a buffer of 100 lines, technically these should be enough for hours of operation before stuff scrolls out (it will still be in the log file though).
Markus
Yep, got that, but stuff isn't written to the system log so easily (not in matter of a few lines of code anyway), so that is something I don't want to do at the moment.geobel wrote:No, we are talking about Windows System log. Can be seen via Event viewer (Control Panel/ Administrative tools/Event viewer)
