christopher_wolf
- Special Member
Change the RPM of the Fan? I think you will have to go with the presets as those are defined in the EC and that is the easiest way to control the Fan RPM; I don't know if you can access other RPMs that aren't supported by either the EC or by the Fan.
~o/
She does the things you do.
But she is an IBM.
~o/
But she is an IBM.
kingdaveone
Hello i m french so sorry for my bad english.
First, thanks for this very good software.
It works on my T40p 2373 G1G.
But my GPU is always very hot with standart configuration just websurfing in wifi and at 600mhz.
Here it s my configuration :
Smart
[11/01/2006 13:11:04] Current Config:
[11/01/2006 13:11:04] Active= 1, Cycle= 5, FanBeep= 1200 30, MaxReadErrors= 10
[11/01/2006 13:11:04] IconLevels= 50 55 60, IgnoreSensors= XXX,YYY,ZZZ
[11/01/2006 13:11:04] Levels= 48°C -> 0, 51°C -> 3, 55°C -> 4, 60°C -> 7, 65°C -> 0x80
[11/01/2006 13:43:38] Fan: 0x80 / Highest: 48°C (45 42 30 48 33 n/a 31 n/a 0 0 0 0)
[11/01/2006 13:43:38] Smart: Set fan control to 0x00, Result: OK
[11/01/2006 13:56:41] Fan: 0x00 / Highest: 51°C (45 46 36 51 34 n/a 31 n/a 0 0 0 0)
[11/01/2006 13:56:41] Smart: Set fan control to 0x03, Result: OK
CPU 44°C (0x78)
APS 46°C (0x79)
PCM 36°C (0x7a)
GPU 50°C (0x7b)
BAT 34°C (0x7c)
BAT 31°C (0x7e)
BUS 0°C (0xc0)
PCI 0°C (0xc1)
PWR 0°C (0xc2)
any idea what to do ?
Thanks for help.
Smart
CPU 44°C (0x78)
APS 46°C (0x79)
PCM 36°C (0x7a)
GPU 50°C (0x7b)
BAT 34°C (0x7c)
BAT 31°C (0x7e)
BUS 0°C (0xc0)
PCI 0°C (0xc1)
PWR 0°C (0xc2)
Thanks for help.
replace fan -- built-in fan simply too loud for me
Hi everyone,
To follow up on kingdaveone, his observation might be quite correct. I found a report on a German site
http://www.homep.de/index.php?module=Co ... d=3&meid=2
where someone ran a test and found that the low fan threshold may be related to the fact that the Thinkpad only measures CPU, not GPU temperature, and therefore that the fan has to kick in early to avoid overheating the GPU. Sorry, I am no expert but that seemed to be the gist of it.
Now, I have tried everything on my new R50e (reduce CPU speed, reduce voltage) but the problem is that, at some point, the fan does need to run and then it is just too f***ing loud for me.
Does anyone know if it is possible to replace notebook fans with quieter models (perhaps running at lower RPMs)? It's my last hope. Truly!
Otherwise, I am considering picking up a quieter Toshiba. I am using one in the office, and even when I run it at 100% CPU load, it is very quiet. No noticeable increase in fan speed, only warm air gently pushing out the vents. Just like my X20 Thinkpad, bought about 5 years ago.
I really like the Thinkpad (keyboard, the trackpoint, everything) but this fan issue is turning me completely off it. I need quiet when I work and can't have a loud fan cycling on and off every five minutes. In fact, I can even feel it vibrate in my palm when it's on.
Sorry for the rant. If anyone has any other suggestions, I would love to hear them. Otherwise, buying this TP may have turned out to have been a very costly mistake.
Cheers!
C.
Cheers!
C.
christopher_wolf
- Special Member
Well, reading through the Readme file provided with the Fan Control Utility, there is a way to get it to flat out ignore certain temperature sensor values; in this case, it would be the GPU as that seems to get the hottest.
There should be the following line in the fancontrol.ini file
IgnoreSensors=XXX,YYY,ZZZ
So, for example, to ignore the BAT sensor; you would input the three letter code for it e.g "IgnoreSensors=XC1,BAT" The same would go for the GPU.
As far as I know, changing the fan itself isn't a solution, much less a viable one, for this problem; it has been noted that the GPU does, indeed, run hot
See; http://www.thinkwiki.org/wiki/Problem_with_fan_noise
And the following from the aforementioned ThinkWiki
Plus, you can always shut the fan off and throttle down. HTHI can confirm that on my R51, the graphics card seems to be the problem. The fan keeps running most of the time even with AC on, but even though I activated DynamicClocks (with the radeon driver), I can see in /proc/acpi/ibm/thermal that the GPU (4th value) is at 52-53°. The fan stops running as soon as the temperature gets down to 50 degrees and starts again at 53. While debugging, I seemed(!) to be able to reduce the temperature together with the resolution (e.g. "xrandr -s 2" to get from 1400x1050 to 1024x768) or by switching off the graphics with "xset dpms force off". The bottom line is that the below "partial fix" won't work because the GPU temperature is the problem.
Last edited by christopher_wolf on Thu Jan 12, 2006 6:36 pm, edited 1 time in total.
~o/
But she is an IBM.
~o/
But she is an IBM.
kingdaveone
christopher_wolf
- Special Member
You mean a Critical Temperature for the GPU to watch out for? I wouldn't know of it off the top of my head; but 99-100 Degrees should be the Critical Shutoff threshold for the CPU, and assuming the GPU is nearly the same physical size as the CPU...I would say in the 90s as well.
ATI might have some more info on that in the tech specs for that GPU.
~o/
But she is an IBM.
~o/
But she is an IBM.
If anyone is interested in the fan beep modified version of v0.18, I have put a copy on my site at:
http://www.righteousbender.com/content/fancontrol.exe
It is just the executable, the remaining files inside the folder must remain there, and make sure to backup the original fancontrol.exe before replacing it.
I haven't had too much opportunity lately to test it, but I haven't had any unexpected beeps since I recompiled it with modified constructor values. Just thought I would share for anyone that doesn't care to recompile it
If enough people have the rogue beeps perhaps v19 can have the default values for the beep be 0 0.
List of (un)supported Thinkpads
I have been looking for just this kind of program. Unfortunately, it doesn't work on my TP-A22e. The software reported that it couldn't read the sensors, but at least nothing crashed/rebooted. It is a small victory.
I'll keep trying...
A22e, 2655-27u.
I'll keep trying...
A22e, 2655-27u.
Yes please, always nice to automate things!emaijala wrote:Hi,
I've modified tpfancontrol a bit and made it run as a service. I've been running hassle-free for a good few weeks now. Anyone interested in this version?
--Ere
:: www.ctgilles.net
:: IBM Thinkpad T43p 2669-WF2 - 15" UXGA @ 1600x1200 - Pentium-M 760 2GHz - 1 GB DDR II - 60GB 7200rpm HDD - DVD±RW - ATI FireGL Mobility V3200 - XP Home / Vista UA32 dualboot
christopher_wolf
- Special Member
x40 fan control
i'm testing this program on the x40 and just wanted to say it works wonderfully. no problems as of yet.
here is the numbers in battery optimized mode (i'm using default settings)
CPU 37°C (0x78)
APS 39°C (0x79)
PCM 43°C (0x7a)
GPU 35°C (0x7b)
BAT 32°C (0x7c)
BAT 31°C (0x7e)
BUS 0°C (0xc0)
PCI 0°C (0xc1)
PWR 0°C (0xc2)
CPU 37°C (0x78)
APS 39°C (0x79)
PCM 43°C (0x7a)
GPU 35°C (0x7b)
BAT 32°C (0x7c)
BAT 31°C (0x7e)
BUS 0°C (0xc0)
PCI 0°C (0xc1)
PWR 0°C (0xc2)
thinkpad x40, type:2372-9EU, (2x) 512MB, 40GB HD (4200rpm), 802.11abg, CDC bluetooth
thinkpad x60s, type:1702-94U, (2X) 512MB, 40GB HD (5400rpm), 802.11abg, Ultralight LCD.
Hey guys.
Made a thread with my settings and some insight on the Fan Utility (which is tops BTW). Hope it helps a bit.
GpsPasSion
GpsPasSion
Now if only I could find a viable way to quiet the fan in my Dock II...It's actually always been louder than the T43!
up to now I've always started this little gem of a program with administrative rights but I just wanted to let you know that I may have found yet another way to start WinIO automatically, so that FanControl does not complain when started as a normal shortcut in the user autostart folder.
What I just stumbled upon ist this:
In the device manager (as an administrator again) click "view" - "show hidden devices". Then scroll to "Non PnP device drivers" (I'm using an approximation from my German XP, so it may be called slightly differently). There one can find "WinIO" and set it to "automatic".
Works well so far...
If only I could run RMClock automatically
I know that I could run it as "runas /savecred" but don't want to do that.
Hope this solution hasn't been posted before; at least I didn't see it
Cheers, AMS
Cheers, AMS
Z60m 2531-E9G w/ 2GB RAM
Turn off beep?
The program works great for my T43. Thanks.
I've noticed that there was a beep whenever the fan kicked in and off.
Could anyone let me know how I can turn off the beep?
Well, the directions are precise. When I was doing this, I noticed an exclaimation beside the non PNP driver "smi2". Is this normal?ams999 wrote:Hello,
Works well so far...![]()
If only I could run RMClock automaticallyI know that I could run it as "runas /savecred" but don't want to do that.
Hope this solution hasn't been posted before; at least I didn't see it![]()
Cheers, AMS
I will post results after I restart the system.
fritz_the_blank
I am using this with the T42 2378EVU and all seems well. All seven speeds work fine and I was able to disengage the beep in the .ini files. The sensor readings match those from mobimeter.
Does anybody have thoughts on what a safe operating tempature is? Currently, I have a tempauture of 51 degrees Centigrade with fan fixed at 2. However, when I did a full system scan with NAV last night, the tempature rose to 70 degrees with the fan on full.
Thanks for creating this program; I am very happy to use it when I need some peace and quiet!
FtB
FtB
fritz_the_blank
dave92270
Hi guys,
I tested the fancontrol on my new R52 (1849-4WU), and it appears to work well, no errors during the actual program run, but fancontrol occasionally generates windows error (without crashing anything else)when exiting it. I tested all manual speeds (0-7) and they all run fine; didn't try smart mode yet but I will later.
After short test, the temperature of CPU seem to be around 52-53C with idling computer and fan at rotation 2, GPU 47-48C. However, when I turn the fan off, the CPU and GPU temps start to rise; I didn't try to to see how far they'd go with fan off yet... first need to find out what the acceptable temperatures would be so I could switch fan before permanent damage occurs. My room temperature is currently around 76F.
[1/22/2006 5:26:17 PM] Manual: Set fan control to 0x02, Result: OK
[1/22/2006 5:28:14 PM] Fan: 0x02 / Highest: 52°C (52 42 34 47 30 n/a 28 n/a 39 47 43 n/a)
I have the IBM Thinkpad PowerManager v 1.01 installed and when I start the laptop, the fancontrol (launched in passive mode) reports "fan state" running in non-bios mode (0x07 I believe); but when I close the lid and then reopen (so after standby), the fancontrol reports the desired BIOS mode (0x80) controlling the fan - that is when I actually launched the program in active mode. I didn't try to launch fancontrol when PowerManager (non-bios mode 0x07) is controlling the fan yet (in the fear of possible collision/crash between fancontrol and PowerManager).
This program is promising and I'll observe the temperature and rotation values for some time to see which fan speeds are sufficient. However, I'm finding anything above fan level 1 already quite loud... could someone advice what are safe normal temperatures for the CPU and GPU so I can set values accordingly? I will read the full thread too, it's been probably asked many times....
Anyway, thanks for the fancontrol utility! I wish IBM/Lenovo would address this though - there is no need for running fan in laptop when machine is idling... I like the R52, but the fan is major annoyance for those who work in quiet environment and prefer to hear nothing.
Dave
Dave
I'd like to thank the gentleman who wrote the program, it works great!
after some research, trial and observation, I found out few things:
-the thermal ceiling for the Pentium M is 100C, it seems that IBM engineers were very conservative when they designed the BIOS to trigger the fan at high 40's mark.
-my laptop's fan has 3 speeds not 7, and they are 3000, 3600, and 4200.
-in normal conditions, it is the GPU that triggers the fan, the GPU is actually hotter than the CPU.
-to remedy the GPU temp issue, one can use the PowerPlay setting built in to the ATI driver, which under-clocks the GPU making it run cooler.
here are my settings:
Level=58 0
Level=60 1
Level=62 3
Level=64 6
Level=66 128
I 'm running like this for a couple of days now without issues, this way, the fan turns on seldom, the downside is that the bottom of the notebook gets fairly warm, which can be an issue if it's sitting on your lap for a while.
[/i]
Level=58 0
Level=60 1
Level=62 3
Level=64 6
Level=66 128
[/i]
T42 2379 DXU 1GB 60GB 7K2 15" SXGA+
Yes I agree, it is a great program!
However, just my opinion...I would ratchet those settings down a few degrees if I were you. You shouldn't consider the delta between the fan trigger point (high 40s) and the CPU operating limit (100C) as the indicator of the engineers' conservatism.
I think they probably were a bit conservative, but no doubt, they were considering the temperature operating limits of the entire system, not just the CPU. Other components, e.g., the disk drives cannot operate at 100C.
You said the GPU is triggering the fan. I don't know, but suspect the GPU's thermal limit is similar to that of the CPU. You may want to confirm with ATI. However, your settings will result in a hotter environment inside the case, which may impact other, more heat-sensitive components in the long run.
G
G
Works on X31
Hey all,
Just found and installed your great fan control program on my Thinkpad X31 2884-JUU and it works great! Love the smart mode, as I think the BIOS default lets the machine run too hot.
CPU 44°C (0x78)
APS 42°C (0x79)
PCM 49°C (0x7a)
GPU 41°C (0x7b)
BAT 34°C (0x7c)
BAT 30°C (0x7e)
BUS 0°C (0xc0)
PCI 0°C (0xc1)
PWR 0°C (0xc2)
Manual fan control works fine too. Keep up the great work!
-m
CPU 44°C (0x78)
APS 42°C (0x79)
PCM 49°C (0x7a)
GPU 41°C (0x7b)
BAT 34°C (0x7c)
BAT 30°C (0x7e)
BUS 0°C (0xc0)
PCI 0°C (0xc1)
PWR 0°C (0xc2)
-m
IBM Thinkpad X31
does anyone get emaijalas optimized version or a link for it?
thx
kw
thx
kw
GpsPasSion wrote:Great proggie ! Any chance we can get that "service" version ?
Also is there an undervolting program that plays nice with Fan Control ? NHC seems to be interfering with it with 'Warning: Can't read Status (possible conflict with other software)" messages ?
just turn off the sensor readings in NHC to allow it to work with FC. i have and FC is reading the temp with no errors. why would you want both programs to monitor temp anyway? just let FC do the monitoring since it is in charge of cooling.
or you could try RMclock as tincbtrar suggested. i have not tried it before and it might give you what you are looking for.
T420s Vs T430 Fan noise
- 1779 Views
Sat May 13, 2017 3:47 pm
Fan noise need help
- 856 Views
Last post by radiator
Sat May 20, 2017 12:15 am
LF: Top-end X61 motherboard
- 529 Views
Last post by wujstefan
Sun Mar 19, 2017 1:52 pm
- 1193 Views
Thu Mar 30, 2017 11:11 am
