I can confirm that RMClock with FC works just fine. Plus RM clock does throttling, which NHC doesn't do (yet).amgdoc wrote:GpsPasSion wrote:Great proggie ! Any chance we can get that "service" version ?
Also is there an undervolting program that plays nice with Fan Control ? NHC seems to be interfering with it with 'Warning: Can't read Status (possible conflict with other software)" messages ?
just turn off the sensor readings in NHC to allow it to work with FC. i have and FC is reading the temp with no errors. why would you want both programs to monitor temp anyway? just let FC do the monitoring since it is in charge of cooling.
or you could try RMclock as tincbtrar suggested. i have not tried it before and it might give you what you are looking for.
I found out that the T40 fan is has a buzz unlike just the regular whir of a T42 which i previoulsy had. I was wondering if there is a lower setting to maybe get RPM's of 2000 or so? I have a 1.3, so for just cruzin the net, it usually cycles between low speed and off. I cannot stand this buzz, I might try to swap a newer style fan in that is smoother.
z60 still noisy after fan down to zero
I also hear a fan-like noisy sound in my new z60-2529 EPG.
Great notebook...but what is this soft-noise with every movement of the HD?
After I tried the fancontrol-tool succesfully (!), and set the fan speed back to zero, the fan (on the right side) was indeed not spinning..but the sound still was present (???)
The guys at Lenovo told me there is only 1 fan in this machine. What is this sound then? Is it the HD ? From above it looks like it come from the left side, under the keys.
When I set my power-management on 'turn off HD after three minutes' and waited for this moment: no HD activation, but still this sound.
Anyone reconize this problem? Any idea what's in the z60 making noises?
Martijn
The Netherlands
Martijn
The Netherlands
Re: z60 still noisy after fan down to zero
I'm sorry...must be wrong coordination:
The fan is at the left side, and is very quiet (and stops running after set to zero with fancontrol) But...
The sound still seems to come from the right side....
Most likely the hard drive. Which brand/model of drive does your z60 have?Tinus wrote: Anyone reconize this problem? Any idea what's in the z60 making noises?
X61
sorry about my slowliness. Here's a link to the service version with source code and exe: http://www.kolumbus.fi/emaijala/fancontrol_service.zip. Please let me if you have any issues. It's not very nicely packaged, just the source plus exe so you need at least WinIo.sys and WinIo.dll from the original package.
--Ere
--Ere
I already tried this as mentioned above. However, no difference notible.In Control Panel -> Power Options, you can set it to turn off hard drive after 3 minutes of idle time. After that close all applications and wait for 3 minutes. It should power off.
But: since my HD crashed a few minutes ago, I now know for sure that the HD was making the stationary noise.
It crashes with the Hitachi Feature Tool. To be specific:
after I set the Advanced Power Management down to minimal, the HD crashed, didn't boot, but only 'clicked' a bit scarry.
Before the crash, I did try other settings though. Acoustic Level etc. After every change I made with the tool the noise stopped for a while..and started again.
So, Lenovo sent me a 'new' HD. Hope this one will be quiet, else need to buy a Seagate I think. Thanks for your help, though.
Martijn
This program is great!!!
I bought my T43 1 week ago. Its type is BH2(PM 2.0 1G(I added 512MB) 80G). Every thing is going on pretty good. I never thought the noise from the fan is a serious problem except I saw your posts. To be honest, I think the speed of 3183 RPM won't make the annoying noise. The noise from the HDD is even bigger than that from the fan. So I use the configuaration:
Level=48 0
Level=52 1
Level=56 4
Level=60 7
Level=70 128
IgnoreSensors=PWR,YYY,ZZZ
With my observation, the temperature of PWR isn't the critical factor 'cause it won't rise much higher than orther components.
In normal time the fan just run at around 3183 RPM. It's quiet.
My tp's normal temperature is:
CPU 50 (0x78)
APS 48 (0x79)
PCM 39 (0x7a)
GPU 51 (0x7b)
BAT 36 (0x7c)
BAT 31 (0x7e)
BUS 48 (0xc0)
PCI 48 (0xc1)
PWR 51 (0xc2)
I wonder if this temperature is safe to my T43?
Level=48 0
Level=52 1
Level=56 4
Level=60 7
Level=70 128
CPU 50 (0x78)
APS 48 (0x79)
PCM 39 (0x7a)
GPU 51 (0x7b)
BAT 36 (0x7c)
BAT 31 (0x7e)
BUS 48 (0xc0)
PCI 48 (0xc1)
PWR 51 (0xc2)
IBM T43 2668-BH2 PM2.0, 1024MB, 80G, 14.1" SXGA+
It want to be a T60, but I can't let it be.
@ere
after installing you're "special version" works very fine. No problems at auto-start after all.
Herr Yunta
Not working on 2374-3HU T41, sxga+ Embedded Controller version 3.04, Bios version 3.19.
[2/9/2006 11:26:22 AM] Current Config:
[2/9/2006 11:26:22 AM] Active= 0, Cycle= 5, FanBeep= 1200 30, MaxReadErrors= 10
[2/9/2006 11:26:22 AM] IconLevels= 50 55 60, IgnoreSensors= XXX,YYY,ZZZ
[2/9/2006 11:26:22 AM] Levels= 47°C -> 0, 50°C -> 3, 55°C -> 4, 60°C -> 7, 70°C -> 0x80
[2/9/2006 11:26:54 AM] Fan: 0x80 / Highest: 46°C (44 41 33 46 30 n/a 24 n/a 0 0 0 0)
[2/9/2006 11:26:54 AM] Smart: Set fan control to 0x00, Result: CMD IGNORED (PASSIVE MODE)
[2/9/2006 11:26:55 AM] Fan: 0x80 / Highest: 46°C (44 41 33 46 30 n/a 24 n/a 0 0 0 0)
[2/9/2006 11:26:55 AM] Smart: Set fan control to 0x00, Result: CMD IGNORED (PASSIVE MODE)
[2/9/2006 11:26:56 AM] Fan: 0x80 / Highest: 46°C (44 41 33 46 30 n/a 24 n/a 0 0 0 0)
[2/9/2006 11:26:56 AM] Smart: Set fan control to 0x00, Result: CMD IGNORED (PASSIVE MODE)
3508-CTO 4GB X25-M 80GB 60Y3183 bluetooth Win 7 Pro 32bit (60Y3195 soon)
works great
So, this thingy works GREAT!!
TP T41
2373-4gu.
don't have all the bios versions, but the thing works fine, my legs are getting Warm!
TP T41
2373-4gu.
@GeorgeP: until now you had to start Markus' version with autostart or the taskscheduler. With Eres version you can start the fan-tool as a running service. For this you have to run the fantool_service.exe with the parameter -i once. After that fantool is installed as service.
Thanks, but I'm still unclear on the advantage to running as a service vs autostart.kw wrote:@GeorgeP: until now you had to start Markus' version with autostart or the taskscheduler. With Eres version you can start the fan-tool as a running service. For this you have to run the fantool_service.exe with the parameter -i once. After that fantool is installed as service.
G
With autotstart/taskscheduler I had this "missing winio.sys driver..blabla" error but not at service.
First off, I'd like to express my gratitude. I recently bought an old T23 and have been searching for this type of program for a couple of weeks. I ran across this thread via a search. My problem is that my thinkpad gets too hot and then the fan comes on full blast and is really loud. Now w/ the program I can manually keep the fan on while at home.
But the fan is still too loud to use in the library or in class. I've tried turning the fan on level 2, pretty silent, from power on but eventually the thinkpad heats up and I'm forced to bump the level to the loud 3-7 levels.
christopher_wolf
- Special Member
Welcome to the Thinkpad ForumsEm1 wrote:First off, I'd like to express my gratitude. I recently bought an old T23 and have been searching for this type of program for a couple of weeks. I ran across this thread via a search. My problem is that my thinkpad gets too hot and then the fan comes on full blast and is really loud. Now w/ the program I can manually keep the fan on while at home.
Well, first off, you might want to see how hot your CPU gets, NHC should work. If it is really that hot, you should put some Artic Silver on the CPU and clean the fan out some.
~o/
She does the things you do.
But she is an IBM.
~o/
But she is an IBM.
Same here, reads values fine on the machine in my signature, but in smart mode produce errors:
Looks like theT42 doesn't have all BUS, PWR and PCI sensors...
[24-Feb-06 10:49:03 PM] Current Config:
[24-Feb-06 10:49:03 PM] Active= 0, Cycle= 5, FanBeep= 1200 30, MaxReadErrors= 10
[24-Feb-06 10:49:03 PM] IconLevels= 50 55 60, IgnoreSensors= XXX,YYY,ZZZ
[24-Feb-06 10:49:03 PM] Levels= 47°C -> 0, 50°C -> 3, 55°C -> 4, 60°C -> 7, 70°C -> 0x80
[24-Feb-06 10:49:19 PM] Fan: 0x80 / Highest: 49°C (49 41 29 47 31 n/a 29 n/a 0 0 0 0)
[24-Feb-06 10:49:19 PM] Smart: Set fan control to 0x00, Result: CMD IGNORED (PASSIVE MODE)
T440s OK so far.
T420s NVIDIA graphics. Nice, then MB failure.
T400s Workhorse. two of'em, both faulty display with vertical stripes.
T43 °very nice° - MB reflown and dead, two of'em.
T42 15°, dead onboard wireless.
T40, dead memory slot, stolen from me
T30, stolen from me
TP600 dead
T30, stolen from me
TP600 dead
Hello. The program seems to be working okay on my ThinkPad T43p 2687D5U. However the fan goes much faster than the max setting when it's starting up and also if I set it to a high setting it goes thre then gradually slows much slower.
When it's on a low setting though I can hear it doing something very annoying... It runs steady and "bursts" maybe a few RPMS up and falls back down every so often.
Thanks for any ideas and whatnot!
--Ryan
--Ryan
christopher_wolf
- Special Member
That seems to be the pulsing problem; have only encountered it a few times, but toggling the power schemes and/or flipping FCU to BIOS-Manual-Smart Mode several time seems to do the trick of getting rid of it.
The Level 7 fan setting should produce constant RPM; somewhere around 4668 if I remember correctly.
HTH
HTH
~o/
But she is an IBM.
~o/
But she is an IBM.
christopher_wolf
- Special Member
The fan RPM has a tendancy to jitter about somewhat and the FCU polls the system within a certain interval (5 seconds if I remember correctly); how much is it varying?
~o/
But she is an IBM.
~o/
But she is an IBM.
T420s Vs T430 Fan noise
- 1773 Views
Sat May 13, 2017 3:47 pm
Fan noise need help
- 853 Views
Last post by radiator
Sat May 20, 2017 12:15 am
LF: Top-end X61 motherboard
- 529 Views
Last post by wujstefan
Sun Mar 19, 2017 1:52 pm
- 1189 Views
Thu Mar 30, 2017 11:11 am
