question
Question, so I have been using this since 2+ years ago, I only turn it on when I need it, meaning, I have it in a folder, my settings file, etc. and it runs great.
Now, I would like to install it on my X61 tablet, and just downloaded the .40 version, but it seems to want to install a whole BUNCH of stuff, borland language files, C++ files, not sure if that is for installs, or for reference.
Is there a way to keep it a simple NON service, just running in a folder when I click on it and need it?
Like now, the FAN is no since I have an external monitor setup, but I would love to silence the damb thing today!
troubadix
Ok, here it is:
http://staff-www.uni-marburg.de/~schmitzr/tpfc_v041.zip
runs quick'n'clean in/out of the folder, 32/64bit, Celsius/Fahrenheit switching, service option available...and of course with the requested papal linky
Next month I'll be going to the Carribean
....so be gentle and donate
ciao, troubadix
edit: latest stable version v .33 (service, 32bit) at:
http://staff-www.uni-marburg.de/~schmit ... v_v033.zip
ciao, troubadix
thormdac
many thanx troubadix!
installed the new version as service, taskmanager shows its been started, though no icon appears in task bar. (running vista 32 bus.)
any idea on that?
greetz
any idea on that?
greetz
X300 / 6478-15G
| X60s | 1702-5PG | 2GB | 100GB Hitachi 7K200, 3. Generation | XP prof |
/ T60 / 2007-FVG / 2GB / 100GB / XP prof
tpificon.exe ( used the one from v30 ) seems to work with this on service and I did get the icon in taskbar with temp showing. From my logs, it seems to be working with my settings but will be able to tell more later.
T61p - 15.4" LG - T7500 - FX 570M 256mb - 4Gb ram - 200Gb 7k200 - 4965AGN - NMB - BT - FP - 9 cell - Vista Ult. x64
troubadix
I'am gonna think that over... meanwhile let's have a look at your bank accountbadblood wrote:troubadix, will you marry me?![]()
badblood is right, running as service under vista you have to run tpfcicon.exe additionally . I put all these additional files neatly together in:thormdac wrote:taskmanager shows its been started, though no icon appears in task bar. (running vista 32 bus.)
http://staff-www.uni-marburg.de/~schmitzr/tpfccopy.exe (as written in readme)
ciao, troubadix
thormdac
just one more thing:
accessing /starting tpfcicon, I only get a window showing the temperature-checks.
would like to access the old view, i.e. showing the menu with functional alteration!
should i just start tpfancontrol application again? once i do this i get the desired view.- but then again, no need to start it via service, right?
if that is the case, might as well just put a link into autostart and not install service, right?
many thanx again
greetz
many thanx again
greetz
X300 / 6478-15G
troubadix
@thormdac: first: I do not run Vista
Under Vista services are isolated in session zero and not shown on desktop, for this reason we have tpfcicon, that should run without admin rights. Of course you can run fancontrol as program application with admin rights and you will have the old GUI. But I really don't know if any program link that needs admin rights in autostart folder will work, so have a try.
While tpfc is running as service, it will not run as program application, and vice versa, the port driver is blocked. So stop and uninstall, or set to manual the service first, then start program or put a link to autostart folder.
Please post your solution!
ciao, troubadix
ciao, troubadix
thormdac
troubadix wrote:@thormdac: first: I do not run Vista![]()
i aint sure how long I will keep on testing vista either!
I have disabled UAC!
So putting tpfcontrol in the startup folder works as desired.
Main reason i was asking: Any way of staying with the service version and the icon, but keeping the "old" gui
playing with the settings, i noticed when handing control back to bios, the fan is "stuttering" along.
in addition i find differences between service and normal version:
running service, handing control to bios, cools down to 45degrees.
running normal, handing control to bios, cools down to 50degrees.
greetz
X300 / 6478-15G
troubadix
Nothormdac wrote:Any way of staying with the service version and the icon, but keeping the "old" gui![]()
Disadvantage of an icon.exe controlling the running service: it had to be executed with admin rights (under engaged UAC
Too many misunderstandings
It shouldn't do thatthormdac wrote:running service, handing control to bios, cools down to 45degrees.
ciao, troubadix
I am running v41 as service fine. But it will not block running tpfc as app. When I try running tpfc as app with tpfc as service already running, I get 2 copies of tpfc running: 1 showing in service and another showing as process in the task manager.troubadix wrote:
If I stop one instance of fancontrol, tpficon will disconnect from the tp server and connect to the other.
So apparently it's not blocked.
Might also be why Thormdac is getting 2 different results with one running as service and the other as normal. I'd guess that he has 2 different folders of fancontrol with different fancontrol.ini's?
Not a big deal for me, I just keep it as service. Would prefer the old gui but as everything is working I'm happy
thormdac
dear troubadix,
havin started from scratch, fresh vista image, I notice the following, having double-checked it again:
my symptoms with the tpfc-icon solution plus running as service produces:
1.- when handing to bios a plus of 5degrees as mentioned earlier
2.- a fan rpm of about 3500, whereas bios runs at about 2900!
3.- changes in the settings are not resulting in the adequate response, i.e. temp icon always shows, regardless of setting it to "0"
as well as altering the fan level doesnt work, i.e level 1= 3500 rpm, as well as level 3=3500rpm
i am using your 0.41 out-of the folder-version, with a shortcut in "startup" to get it started, now without any hassles
nighty-night
nighty-night
X300 / 6478-15G
troubadix
@badblood: running 2 instances of fancontrol, only one can read the temps
, check the gui
@thormdac: tpfcicon.exe doesn't read the ini, ShowTempIcon=0 will only have effect on fancontrol
There are not so many fan speed levels as numbers between 0 and 7 (so 1=3
) built in each and every TP controled by EC, they differ depending on model and they are not so numerous
go to http://www.thinkwiki.org search for >fan speed<
I will try to observe the other reported effects.
ciao, troubadix
ciao, troubadix
I was testing to see if it will lock other instances of fancontrol from running. and only the first instance read the temps - you're right.troubadix wrote:@badblood: running 2 instances of fancontrol, only one can read the temps, check the gui
Anyway I have couple questions:
At fan lvl 7 I get a fan rpm of 3200rpm. At lvl 64 I get 3300rpm. I thought 64 gets more than that , 4000+rpm no?
here's partial list of my log:
time;cpu;aps;crd;gpu;bat;x7d;bat;x7f;bus;pci;pwr;xc3;rpm;fan;switch;
2:32:29 AM; 68; 54; 31; 68; 40; 0; 33; 0; 37; 57; 54; 0; 3335; 64; 68;
2:32:34 AM; 68; 54; 31; 68; 40; 0; 34; 0; 37; 57; 55; 0; 3335; 64; 68;
2:32:39 AM; 68; 54; 31; 68; 40; 0; 34; 0; 37; 57; 55; 0; 3335; 64; 68;
2:32:44 AM; 68; 54; 31; 69; 40; 0; 34; 0; 37; 57; 55; 0; 3335; 64; 69;
2:32:49 AM; 68; 54; 31; 69; 40; 0; 34; 0; 37; 57; 55; 0; 3335; 64; 69;
2:32:54 AM; 68; 54; 31; 68; 40; 0; 34; 0; 37; 57; 55; 0; 3335; 64; 68;
2:32:59 AM; 68; 54; 31; 68; 40; 0; 34; 0; 37; 57; 55; 0; 3335; 64; 68;
2:33:04 AM; 67; 54; 31; 68; 40; 0; 34; 0; 37; 57; 54; 0; 3335; 64; 68;
2:33:09 AM; 67; 54; 31; 68; 40; 0; 34; 0; 37; 57; 54; 0; 3335; 64; 68;
2:33:14 AM; 67; 54; 31; 67; 40; 0; 34; 0; 37; 57; 54; 0; 3335; 7; 67;
2:33:19 AM; 67; 54; 31; 67; 40; 0; 34; 0; 37; 57; 54; 0; 3335; 7; 67;
2:33:24 AM; 67; 54; 31; 67; 40; 0; 34; 0; 37; 57; 54; 0; 3315; 7; 67;
2:33:29 AM; 67; 54; 31; 68; 40; 0; 34; 0; 37; 57; 54; 0; 3287; 64; 68;
2:33:34 AM; 67; 54; 31; 68; 40; 0; 34; 0; 37; 57; 54; 0; 3287; 64; 68;
2:33:39 AM; 68; 54; 31; 68; 40; 0; 34; 0; 37; 57; 54; 0; 3287; 64; 68;
2:33:44 AM; 68; 54; 31; 68; 40; 0; 34; 0; 37; 57; 54; 0; 3287; 64; 68;
2:33:49 AM; 68; 54; 31; 68; 40; 0; 34; 0; 37; 57; 54; 0; 3287; 64; 68;
2:33:54 AM; 68; 54; 31; 68; 40; 0; 34; 0; 37; 57; 54; 0; 3287; 64; 68;
2:33:59 AM; 68; 54; 31; 68; 40; 0; 34; 0; 37; 57; 55; 0; 3287; 64; 68;
2:34:04 AM; 67; 54; 31; 68; 40; 0; 34; 0; 37; 57; 54; 0; 3287; 64; 68;
2:34:09 AM; 67; 54; 31; 67; 40; 0; 34; 0; 37; 57; 54; 0; 3287; 7; 67;
2:34:14 AM; 67; 54; 31; 67; 40; 0; 34; 0; 37; 57; 54; 0; 3287; 7; 67;
2:34:19 AM; 67; 54; 31; 68; 40; 0; 34; 0; 37; 57; 54; 0; 3316; 64; 68;
2:34:24 AM; 67; 54; 31; 68; 40; 0; 34; 0; 37; 57; 54; 0; 3316; 64; 68;
2:34:29 AM; 68; 54; 31; 69; 40; 0; 34; 0; 37; 57; 54; 0; 3316; 64; 69;
2:34:34 AM; 68; 54; 31; 68; 40; 0; 34; 0; 37; 57; 54; 0; 3316; 64; 68;
2:34:39 AM; 68; 54; 31; 68; 40; 0; 34; 0; 37; 57; 54; 0; 3316; 64; 68;
2:34:44 AM; 68; 54; 31; 68; 40; 0; 34; 0; 37; 57; 54; 0; 3316; 64; 68;
2:34:49 AM; 68; 54; 31; 68; 40; 0; 34; 0; 37; 57; 54; 0; 3316; 64; 68;
2:34:54 AM; 68; 54; 31; 68; 40; 0; 34; 0; 37; 57; 54; 0; 3316; 64; 68;
2:34:59 AM; 67; 54; 31; 67; 40; 0; 34; 0; 37; 57; 54; 0; 3316; 7; 67;
2:35:04 AM; 67; 54; 31; 68; 40; 0; 34; 0; 37; 57; 54; 0; 3316; 64; 68;
2:35:09 AM; 67; 54; 31; 68; 40; 0; 34; 0; 37; 57; 55; 0; 3316; 64; 68;
2:35:14 AM; 67; 54; 31; 68; 40; 0; 34; 0; 37; 57; 54; 0; 3316; 64; 68;
2:35:19 AM; 68; 54; 31; 68; 40; 0; 34; 0; 37; 57; 55; 0; 3316; 64; 68;
2:35:24 AM; 68; 54; 31; 68; 40; 0; 34; 0; 37; 57; 55; 0; 3316; 64; 68;
2:35:29 AM; 68; 54; 31; 68; 40; 0; 34; 0; 37; 57; 55; 0; 3316; 64; 68;
2:35:34 AM; 68; 54; 31; 68; 40; 0; 34; 0; 37; 57; 55; 0; 3316; 64; 68;
2:35:39 AM; 67; 54; 31; 68; 40; 0; 34; 0; 37; 57; 55; 0; 3316; 64; 68;
2:35:44 AM; 67; 54; 31; 67; 40; 0; 34; 0; 37; 57; 54; 0; 3316; 7; 67;
2:35:49 AM; 67; 54; 31; 67; 40; 0; 34; 0; 37; 57; 54; 0; 3316; 7; 67;
2:35:54 AM; 67; 54; 31; 68; 40; 0; 34; 0; 37; 57; 54; 0; 3252; 64; 68;
2:35:59 AM; 67; 54; 31; 68; 40; 0; 34; 0; 37; 57; 54; 0; 3252; 64; 68;
2:36:04 AM; 67; 54; 31; 68; 40; 0; 34; 0; 37; 57; 54; 0; 3252; 64; 68;
2:36:09 AM; 68; 54; 31; 68; 40; 0; 34; 0; 37; 57; 55; 0; 3252; 64; 68;
2:36:14 AM; 68; 54; 31; 69; 40; 0; 34; 0; 37; 57; 54; 0; 3252; 64; 69;
2:36:19 AM; 68; 54; 31; 68; 40; 0; 34; 0; 37; 57; 54; 0; 3252; 64; 68;
2:36:24 AM; 68; 54; 31; 68; 40; 0; 34; 0; 37; 57; 54; 0; 3252; 64; 68;
2:36:29 AM; 67; 54; 31; 66; 40; 0; 34; 0; 37; 57; 54; 0; 3252; 7; 67;
2:36:34 AM; 67; 54; 31; 63; 41; 0; 34; 0; 37; 57; 54; 0; 3252; 7; 67;
2:36:39 AM; 66; 54; 31; 62; 41; 0; 34; 0; 37; 56; 54; 0; 3324; 7; 66;
2:36:44 AM; 64; 54; 31; 61; 41; 0; 34; 0; 37; 56; 54; 0; 3286; 7; 64;
2:36:49 AM; 63; 53; 31; 61; 41; 0; 34; 0; 37; 55; 53; 0; 3299; 7; 63;
2:36:54 AM; 61; 53; 31; 60; 41; 0; 34; 0; 37; 55; 53; 0; 3287; 7; 61;
2:36:59 AM; 61; 53; 31; 59; 41; 0; 34; 0; 37; 55; 52; 0; 3301; 7; 61;
2:37:04 AM; 59; 52; 31; 59; 41; 0; 34; 0; 37; 54; 52; 0; 3301; 7; 59; Level=55 1
Level=60 7
Level=68 64
Level=80 128
Thanks for the input.
troubadix
whowwwbadblood wrote: here's partial list of my log:
not so much is known about temps, fan speed and sensors:
http://www.thinkwiki.org/wiki/Talk:Thermal_Sensors
http://www.thinkwiki.org/wiki/How_to_control_fan_speed
All the rest is a secret of ibm/lenovo and partly depends on model typ and embedded controller firmware version.ACPI DSDT register HFSP (8 bits, offset 0x2F in the EmbeddedController address space, accessed through the standard EC interface at IO ports 0x62 and 0x66) is read/writable and has the following meaning:
Bits / Values :
7 6 5 4 3 2 1 0
1 0 * * * * * * - automatic
* 1 * * * * * * - disengaged
0 0 X X X X X X - manual (0..63; 0=disable fan, 1=min, ..., 7=max)
lvl 7 should mean: highest regulated fan speed
lvl 64 should mean: not regulated
all I can say
ciao, troubadix
Thanks for the detailed reply..even if some of that went over by my head
Most I can get it seems is 3300rpm.
Maybe someone with a T61p can share their experience in regards to the max fan speed they can get.
edit: Upon further testing, I did get up to 4500rpm max but it doesn't seem to be controlled by the temp levels. ie I ocassionally get 4500rpm on both level 7 and 64 but mostly its at 3200-3300rpm.
cheers
cheers
my success report with tpfc_v041
Greetings!
I just installed tpfc_v041 on my T60 ThinkPads, both XP and Vista. Success for both.
ini settings are:
// Celsius: (IF Level FAN 0 < 80° -> Celsius is assumed)
Level=50 0
Level=55 1
Level=65 3
Level=70 6
Level=75 64
I inserted the "Level=55 1" to give me an intermediate response.
on both XP and Vista.
While it is true that the T60 machines are very quiet, the "whoosh" gets a little tiresome after a while, so I am running your program so see how it helps.
At 55C the fan runs slightly over 2900 rpm which hardly makes a sound but still moves enough air when the machine is idle.
I really like how this version allows to run the program without the need to start a service. This gives me control over whether or not to run it after bootup, when not run as service.
Just thought you would like to know about this success.
PS I assume you got my small payment by now as small thanks for your program ..
ini settings are:
Level=50 0
Level=55 1
Level=65 3
Level=70 6
Level=75 64
djThinkbad
Hi I wanted to know if there was a way the thinkpad Fancontrol Software could start aotomatically when computer restarts.
I often forget to turn it on after a restart or after a shut down and then find my self hearing the loud fan and then searching the
c-drive to turn it on
So is there a way to make it autostart like Notebook Hardware Control (NHC) does?
THANKS!
Yes, the later versions of the program allow for running it as a service at boot. This may or may not work well in Vista, but it's worth a try. Since I mostly use hibernate (rather than hard shutdown) the fan control program stays resident anyway. If I forget to restart it at re-boot, soon I start to notice the fan noise and that reminds me to launch it.djThinkbad wrote:Hi I wanted to know if there was a way the thinkpad Fancontrol Software could start aotomatically when computer restarts.
THANKS!
Rather than having to go to C: to turn the program on, you could just place a shortcut on the desktop and click that when you wish to start the fan control. That is what I have always done. Another solution would be to put a shortcut in your Startup folder, so it will launch at boot time.
djThinkbad
mgo wrote:Yes, the later versions of the program allow for running it as a service at boot. This may or may not work well in Vista, but it's worth a try. Since I mostly use hibernate (rather than hard shutdown) the fan control program stays resident anyway. If I forget to restart it at re-boot, soon I start to notice the fan noise and that reminds me to launch it.djThinkbad wrote:Hi I wanted to know if there was a way the thinkpad Fancontrol Software could start aotomatically when computer restarts.
THANKS!
Please can you tell me the steps!
I am not great at software/computer in general
Just a few steps so I can know what to do and dont screw up!
troubadix
Re: my success report with tpfc_v041
Yeah! Of course, i domgo wrote:Just thought you would like to know about this success.
Today, just being back from running down beaches one week at seaside (5 degrees centigrade, windforce 8 ), I found mgo's 20 bucks banknote in my snail mail box
There's no need to change the money
Ciao, troubadix
djThinkbad
troubadix
Till now there is no option to start TPFanControl in manual modedjThinkbad wrote:HOW do i make TP fan control start automatically but on speed 1 Manual???
Level=4 0
Level=10 1
Level=65 3
Level=70 6
Level=75 64ciao, troubadix
edit: THNX to Jeffri Lingo & Victor Dostrow for donation
find all donators: http://staff-www.uni-marburg.de/~schmitzr/donate.html
Darf man Eeuch auch was schicken to be considered a "donator"...?troubadix wrote:djThinkbad wrote:TPFanControl will start in smart mode with fan level 1 between 10 and 65 degrees centigrade and turn off fan only near freezing point.![]()
ciao, troubadix
edit: THNX to Jeffri Lingo & Victor Dostrow for donation![]()
Bin naechste Woch in Muenchen. Tschuesss!
T420s Vs T430 Fan noise
- 1773 Views
Sat May 13, 2017 3:47 pm
Fan noise need help
- 853 Views
Last post by radiator
Sat May 20, 2017 12:15 am
LF: Top-end X61 motherboard
- 529 Views
Last post by wujstefan
Sun Mar 19, 2017 1:52 pm
- 1189 Views
Thu Mar 30, 2017 11:11 am
