troubadix
#811 Post by troubadix » Mon Jan 28, 2008 4:56 am
Crunch wrote:Darf man Eeuch auch was schicken to be considered a "donator"...?
...always glad to receive donations :D :D :D of course :!:
Please use the paypal donation button at the TPFanControl donation site:
http://staff-www.uni-marburg.de/~schmitzr/donate.html
or donation item of systray icon menue (only last version of TPFanControl).
snail mail lovers please pm me for postal adress :wink:
Anyway I'll put your name to the hall of fame in order of the amount :D
@Crunch: distance Muenchen<->Marburg 300 miles :cry: so use paypal :idea:
ciao, troubadix
gechu
#812 Post by gechu » Wed Feb 06, 2008 10:56 am
I'm using version 0.24 -> via NHC @ a T60. Are there any benefits for me setting up the latest fan control software?
What can be regarded as "safe" temperatures? Right now it's 60-65. But it annoyes me because the temperature keeps raising and when it it's 65 degrees the fan starts blowing.
thanks,
Erik
troubadix
#813 Post by troubadix » Wed Feb 06, 2008 1:27 pm
gechu wrote: Are there any benefits for me setting up the latest fan control software?
Don't change a system you are happy with :D
"safe" is an unsafe term :wink:
90 degrees centigrade will do your chips no harm, possibly your finger tips on keyboard :? , but if you're running these high temps for a very very very long time you have to keep an eye on your HDD temp, that should stay definitly below 60° C to minimize the risk of lifetime reduction (HDD temp is not monitored by TPFanControl).
All of that my own opinon, use TPFaControl at your own risk :!:
Ciao, troubadix
troubadix
#814 Post by troubadix » Wed Feb 06, 2008 5:23 pm
... if only I had known:
the light at the end of the tunnel is .... a Thinklight :D :D :D
http://staff-www.uni-marburg.de/~schmitzr/tpfc_v042.zip (just beta)
ciao, troubadix
gechu
#815 Post by gechu » Thu Feb 07, 2008 2:44 am
troubadix, thanks for the quick and helpful reply!
/Erik
gunston
#816 Post by gunston » Thu Feb 07, 2008 8:05 am
what is the most stable and latest version now??
i am still using 0.18 service.
2. X60s 1703-CA3 powerful
troubadix
#817 Post by troubadix » Thu Feb 07, 2008 10:23 am
Hi!
Stable and latest version is always in signature link.
known as stable:
http://staff-www.uni-marburg.de/~schmit ... v_v025.zip WinXP32 service only, no digital icon
http://staff-www.uni-marburg.de/~schmit ... v_v033.zip WinXP32 service only, with digital icon
http://staff-www.uni-marburg.de/~schmitzr/tpfc_v041.zip WinXP/Vista, 32/64bit, Celsius/Fahrenheit, service/non_service, with digital icon (new port driver, signature version)
latest beta:
http://staff-www.uni-marburg.de/~schmitzr/tpfc_v042.zip like v041 with additional bluetooth (internal) and thinklight control and parameter NoExtSensor=1 for Thinkpads A2x,T2x to prevent buggy reading.
ciao, troubadix
Paul Unger
#818 Post by Paul Unger » Thu Feb 07, 2008 1:19 pm
I just installed tpfancontrol v041 on my T61. Working like a charm, it is. But I'm wondering . . . There are two 'battery' sensors: one at 0x7c (5 bat) and another at 0x7e (7 bat). The one at 0x7c is always at 50C--from the moment I turn on until I turn off; no amount of 'fanning' will bring it down. So:
1. is it safe to comment this sensor out?
2. how do I do so? I tried "IgnoreSensors=bat" but it still showed "5 bat" and "7 bat" in the "active" list when I ran it. I also tried removing the slashes before "SensorName5=bat", but that didn't remove it either. What am I missing?
3. is there any way to turn sensor 5 off and leave sensor 7 on? Sensor 7 seems to be more indicative in that it varies from 26C on upwards. I ask because they seem to share the same name ("bat").
troubadix
#819 Post by troubadix » Thu Feb 07, 2008 5:18 pm
@Paul Unger :
1. yes it is safe (I guess :wink: )
2. any sensor that is found by its name in "IgnoreSensors= " is read out and shown but the value is ignored computing the thermal fan switch("switch" value), while "IgnoreSensors=bat" is set, both of them are read and shown, but ignored.
3. so you have to rename sensor 5 by e.g. "SensorName5=aaa" (without slashes in front) and after set "IgnoreSensors= aaa" to have it ignored. :shock:
...yeah, some day we will have a FAQ page :idea:
btw: most of these sensor names come from T43 where some guys found them using some cans of cooler spray...but locations change with different TP models :roll:
ciao, troubadix
gunston
#820 Post by gunston » Thu Feb 07, 2008 10:12 pm
hmmm, trial run 0.41 now.
so, what temperature did you guys set to turn on the fan, currently the default setting is 65degC only the FAN will kick off.
Paul Unger
#821 Post by Paul Unger » Thu Feb 07, 2008 10:58 pm
You don't want to know what I set mine to! :) Because it's so hot where I work, I like the fan on as much as possible; and a steady hum is better imho than cycling on / off. So I run on level1 from 42 - 50, level3 50-60 and level7 60+. It may be overkill, but I think the replacement cost of a fan is cheaper than a system board. :wink:
gunston
#822 Post by gunston » Thu Feb 07, 2008 11:00 pm
Paul Unger wrote:You don't want to know what I set mine to! :) Because it's so hot where I work, I like the fan on as much as possible; and a steady hum is better imho than cycling on / off. So I run on level1 from 42 - 50, level3 50-60 and level7 60+. It may be overkill, but I think the replacement cost of a fan is cheaper than a system board. :wink:
no worry, processor can sustain max temperature of 100degC
Paul Unger
#823 Post by Paul Unger » Thu Feb 07, 2008 11:21 pm
Oh, I'm aware of that. I just like a cool running machine. Heat is the enemy! :twisted: Fans are our friends in the fight (as I'm sure you're well aware in Brisbane)!
gunston
#824 Post by gunston » Thu Feb 07, 2008 11:23 pm
Paul Unger wrote:Oh, I'm aware of that. I just like a cool running machine. Heat is the enemy! :twisted: Fans are our friends in the fight (as I'm sure you're well aware in Brisbane)!
:twisted: FAN kick off on 60deg,
superboss
#825 Post by superboss » Sat Feb 09, 2008 12:20 pm
Tried this utility today and while I loved the improvement in fan noise the temp of my GPU quickly rised to alarming (?) values. 62 degrees Celsius and climbing before I switched to "BIOS mode". Also a "clicking" noise appeared from the area inside the machine where the GPU is located. I got abit worried and switched back to manual mode with fan speed set to 1 which seemed to work fine and the "clicking noise" stopped. Is 65 C really an okay temp to use for GPU and CPU? The case of the machine was so hot I was almost worried it would start melting :D
IBM Thinkpad T43 (2669-84G): 1.86GHz / 1GB RAM / X300 / 1400x1050 15" Flexview / 40GB HD
troubadix
#826 Post by troubadix » Sat Feb 09, 2008 6:09 pm
superboss wrote:62 degrees Celsius and climbing ...
as fancontrol.ini says:
Level=50 0
Level=65 3
Level=70 6
Level=75 64
the step: Level=55 1 of older versions disappeared by copy&paste :( :( :(
I'll fix that, but meanwhile edit fancontrol.ini to your needs. 65° C shouldn't be a threat to your cpu or gpu.
ciao, troubadix
gunston
#827 Post by gunston » Sat Feb 09, 2008 6:51 pm
Level=50 0
Level=65 3
Level=70 6
Level=75 64
is okay for my X61 to turn on the FAN at this temperature. but for T43, i afraid the southbridge is getting too HOT !!!
Armi
fancontrol on Z61m
#828 Post by Armi » Mon Feb 11, 2008 6:41 pm
Does somebody use TPfancontrol on Z61M ? Which release ?
gunston
Re: fancontrol on Z61m
#829 Post by gunston » Mon Feb 11, 2008 6:42 pm
Armi wrote:Hello,
try on your own risk!
Armi
#830 Post by Armi » Tue Feb 12, 2008 8:38 am
gunston wrote:
Armi wrote:Hello,
Thanks for this very helpfull advice.
gunston
#831 Post by gunston » Tue Feb 12, 2008 8:40 am
Armi wrote: Thanks for this very helpfull advice.
oh, it is my pleasure, you are welcome. 8)
Paul Unger
#832 Post by Paul Unger » Tue Feb 12, 2008 11:40 am
I think what gunston is saying (he's usually quite helpful!) is that a lot of us have had to either search for users with the same machine type who have reported their experience or read the instructions and give it a go on our own. It's very easy to give control back to BIOS, so trying it is really quite a low-risk proposition. [But if your machine fries it's not my--or anyone else's--fault!]
Armi
#833 Post by Armi » Tue Feb 12, 2008 6:38 pm
Paul Unger wrote:I think what gunston is saying (he's usually quite helpful!) is that a lot of us have had to either search for users with the same machine type who have reported their experience or read the instructions and give it a go on our own. It's very easy to give control back to BIOS, so trying it is really quite a low-risk proposition. [But if your machine fries it's not my--or anyone else's--fault!]
OK, no problem
gunston
#834 Post by gunston » Tue Feb 12, 2008 7:29 pm
Paul Unger wrote:... [But if your machine fries it's not my--or anyone else's--fault!]
it won't fry, no worry, because all of the designed CPU had the capability of sustaining 100degC .
Xtal
#835 Post by Xtal » Wed Feb 13, 2008 12:24 am
v0.41 is great!
I have a suggestion for the readme text files. Most of the things that can be simply "double-clicked" in XP require administration privileges to work properly in Vista. This includes:
fancontrol.exe
install_service
uninstall_service
start_service
stop_service
All of these require a right click and "Run as administrator". If they are not run with admin access, fancontrol.exe fails with a winio.dll error while the service .lnk files fail without any message.
The initial setup.exe and TVicPortInstall41.exe properly request admin privileges when launched (the UAC window pops up) so these are OK.
Is there any way to modify fancontrol.exe or the .lnk files to request UAC admin privileges like the setup.exe does?
Armi
Strange fancontrol behavior.
#836 Post by Armi » Wed Feb 13, 2008 4:25 am
I installed fancontrol version 0.25svc on my thinkpad Z61m.
In smartmode, it seems to work nicely.
If I go to BIOS mode, Fancontrol enters in a strange process, where it switches endlessly between BIOS mode and Smartmode, staying about 4seconds in BIOS mode and one second in Smartmode.
In Manual mode level 7, same kind of switching between level 7 (4seconds) and level 1 (1 second).
Any ideas ?
troubadix
#837 Post by troubadix » Wed Feb 13, 2008 5:25 am
@Xtal: Thnx for your proposals. "Unfortunately" I am away from keyboard from now until mid of March (for a sailing trip :D :D :D ). We can deal with that after.
@Armi: apparently EC firmware of Z61m is not compatible to TPFanControl :cry: :cry:
bye, bye troubadix
gunston
#838 Post by gunston » Wed Feb 13, 2008 7:34 am
Sad to hear that Z6x is not compatible with TPFancontrol, maybe can change the scripts.
need to request troubadix :P
Armi
#839 Post by Armi » Wed Feb 13, 2008 7:36 am
I went back to old version V0.18 which works correctly on my Z61m.
gunston
#840 Post by gunston » Wed Feb 13, 2008 7:37 am
Armi wrote:I went back to old version V0.18 which works correctly on my Z61m.
Good to hear that. Congrats :!:
