Metallo
Re: Thinkpad Fan Noise Problem: Light at the End of the Tunnel
#961 Post by Metallo » Sat Feb 21, 2009 6:33 am
Hi!
I am new to TPFancontrol and noticed a problem with my T40 2373 "short fan", the icon on the bottom right of the toolbar should show a rotation of the various temperatures, but mine stays stable on gpu, temperature moves up or down but the icon stays there, on gpu.
Rarely, it moves to aps a few secs then back to gpu :roll:
Any idea why?
For the time being, I am using the default values in the .ini file, but would like to low the temperatures down for my T40, any profile suggestion is welcomed.
Also, if I want to use TPFancontrol as a service, shall I only start the service as such and nothing else? I mean, do I need to change any other option?
Finally, is there a possibility to have "smart mode 2" to start as default? I wanted to change the settings according to my needs and have it to start by default. I know I could easily do it in "smart mode 1", but I'd rather like to leave it as is and change the "smart mode 2" profile.
Thank you and congrats to troubadix :wink:
Alex
IBM ThinkPad T40 2373-8CG, Pentium M 1.5 GHz, 2GB RAM, HDD WD 250GB, DVD LG Electronics, ATI Mobility Radeon 7500, W7 PRO SP3
citizenNB
#962 Post by citizenNB » Sat Feb 21, 2009 7:31 am
Hi Alex,
Metallo wrote:I am new to TPFancontrol and noticed a problem with my T40 2373 "short fan", the icon on the bottom right of the toolbar should show a rotation of the various temperatures, but mine stays stable on gpu, temperature moves up or down but the icon stays there, on gpu.
I am not sure if I understand you correctly. But as far as I know TPFanControl dosn't show the temperature values in rotation, it rather shows the temperature value and the name of the sensor detecting the maximum temperature value. If the sensor nearby the GPU reports most of the time the highest temperature value, one can see the gpu temperature on the icon most of the time. ;)
citizenNB
T23 | T43p | Z60t
troubadix
#963 Post by troubadix » Sat Feb 21, 2009 7:33 am
Hi Alex,
1st: citizenNB
2nd: in WinXP only install service is needed, service starts automatically at boot time or by hand (start service)
3rd: there is no option to start with level2 profile by default. So take your values to start with to the level profile and the original level values to level2
4th: you can run T40 with original level values, but if you like to have your T40 a bit cooler and like to hear the fan sometimes, go down for 10 degrees centigrade in each level.
ciao, troubadix
Metallo
#964 Post by Metallo » Sun Feb 22, 2009 12:03 pm
Hi citizenNB & trouabadix,
Thanks for your replies.
Once I start the service, when I switch my laptop on, I get the following message:
program or service already running, error 5
I guess this is because the service starts at booting time and the application tries to start as well, how can I let TPFancontrol start as "service" only and not as "application" ?
Thank you
Alex
citizenNB
#965 Post by citizenNB » Sun Feb 22, 2009 12:14 pm
Hi Alex,
take a look in your Autostart. Is there a shortcut to TPFanControl. If yes, delete this one. Apperently, you already installed the service. So you don't have to start the program a second time at the Windows startup. :)
To control, if the service is installed, you could go to the Control Panel -> Administrative Tools -> Services. There you should find the service TPFanControl. ;)
citizenNB
T23 | T43p | Z60t
Metallo
#966 Post by Metallo » Sun Feb 22, 2009 12:24 pm
Sure mate, you are right, stupid me that I didn't think about that :banghead:
Now it works, perfectly.
Thank you!
Alex
Metallo
#967 Post by Metallo » Mon Feb 23, 2009 6:25 am
Hi there,
I have another question, I have 4 login accounts on my T40, how can I get the ballicon bottom right to appear in all accounts?
At the moment, it appears only in the account I used to install TPFancontrol.
Thank you
Alex
Metallo
#968 Post by Metallo » Tue Feb 24, 2009 4:14 am
Metallo wrote:Hi there,
Thank you
Alex
Well, the point is if you want to use TPfancontrol as a service, you have to delete the program from Windows startup in order to avoid the attempt to restart the program a second time, hence, error 5.
But, deleting the application from startup menu won't let the ballicon show up in a different user login account.
So, what's the trick here?
Alex
troubadix
#969 Post by troubadix » Tue Feb 24, 2009 11:12 am
run tpfcicon.exe or tpfcicon_noballons.exe additionally in different user login account :D
Metallo
#970 Post by Metallo » Tue Feb 24, 2009 11:29 am
troubadix wrote:run tpfcicon.exe or tpfcicon_noballons.exe additionally in different user login account :D
This is not the solution, if I run ]tpfcicon.exe it gives error 183 because the program is already running (I have uninstalled the service and reinstalled the whole program as application because I thought that when it is asking to put an icon into startup program it should have worked for all the login accounts, but it is not so :( ).
If I click tpfcicon_noballons.exe it works until I log off, which again, is not acceptable.
Any idea why it doesn't work on all four accounts?
Alex
troubadix
#971 Post by troubadix » Tue Feb 24, 2009 12:43 pm
as TPFanControl works flawlessly on my machines with normal user switching (logon/loggoff), I guess you are talking about FastUserSwitching.
With Fast User Switching, users can switch sessions without closing Windows, programs, and so forth. For example, User A is logged on and is browsing the Internet, User B wants to log on to their user account and check their e-mail account.
TPFanControl cannot be run simultaneously on two different accounts, as you can't have two drivers active on one car. So, you have to stop TPFanControl before FastUserSwitching and start it again on different account manually .
Metallo
#972 Post by Metallo » Wed Feb 25, 2009 11:01 am
OK, I see your point, but I wonder how other applications work, for instance, skype shows up in the toolbar of my 4 accounts simultaneously, so I guess it depends on how the programmer has conceived the software??
Anyhow, good work! :D
Cheers
Alex
troubadix
#973 Post by troubadix » Tue Mar 10, 2009 10:06 am
NEW: now program or service can have up to 8 additional icons simultaneously on different accounts by tpfcicon.exe/tpfcicon_noballons.exe, try TPFanControl v0.60 SecWinUptime & SecStartDelay no longer needed.
ciao, troubadix
edit: program/service behavior at user log off completely reworked TPFanControl v0.61.
Stormwing
#974 Post by Stormwing » Mon Mar 23, 2009 10:27 pm
Hi, just registered. I've been running a T43 since mid 2005, and I've already had the fan worked on once. Nowadays, I get a "Fan Error" upon startup, and the computer shuts down. Usually I can circumvent this by going to the BIOS/Access IBM utility, and then wait for the fan to start, but today the fan seems to have died completely. Took a long while to get the computer started, but the fan just wouldn't start.
I had been using v0.20 before, so I went and got v0.61, hoping perhaps it would make a difference. The fan still won't budge. Is there anyway to make it start spinning, or have I screwed it up wayyyyy too much at this point?
RasmusP
#975 Post by RasmusP » Tue Mar 24, 2009 5:46 am
I use you fan control software with great pleasure. The other day a
service guy from IBM was replacing the fan of my X60 and he was aware
of you program too. Either way, I have a couple of usability/feature
request. First of all, it is kind of annoying that it does not show up
in the ctrl-tab list when it is expanded. When the program is
expanded and on the desktop it would be naturally to be able to find
it via ctrl-tab.
Also, it would be great if the program could be vertical rather than
horizontal. These days vertical space is much more valuable than
horizontal space. If there were a vertical mode one could place it on
the side of the screen. A mock-up screenshot to make
visualize my idea can be seen here.
Thanks for you effort in making TPFan avaible!
--Rasmush
troubadix
#976 Post by troubadix » Tue Mar 24, 2009 11:17 am
RasmusP wrote:it would be great if the program could be vertical rather than
horizontal
try: TPFanControl_slim.zip :D :D :D screenshot
Metallo
#977 Post by Metallo » Tue Mar 24, 2009 11:35 am
troubadix wrote:NEW: now program or service can have up to 8 additional icons simultaneously on different accounts by tpfcicon.exe/tpfcicon_noballons.exe, try TPFanControl v0.60 SecWinUptime & SecStartDelay no longer needed.
ciao, troubadix
Thank you! :D :D :D
Alex
RasmusP
#978 Post by RasmusP » Fri Mar 27, 2009 11:48 am
troubadix wrote: try: TPFanControl_slim.zip :D :D :D screenshot
Cool! Thanks!
joefried
#979 Post by joefried » Sun Mar 29, 2009 4:54 am
I'm a newbie here and have a Thinkpad T43 (2687 DDU). I'd like to install the Fan Control programme but was unsure what was the latest version. Could someone post the link?
Also, I got the sense that the fan programme wouldn't necessarily solve the excess noise issue -- does taking the CD player out help?
Many thanks,
Joe
troubadix
#980 Post by troubadix » Sun Mar 29, 2009 8:06 am
latest version: TPFanControl v0.61
joefried
#981 Post by joefried » Sun Mar 29, 2009 9:52 am
Ta! I'll install it now.
J
Masi_K
#982 Post by Masi_K » Mon Mar 30, 2009 2:32 pm
tpfan control doesn't follow typed settings after awaking sleep mode.
Haven't tested yet for hibernate.
T20, winXP sp3.
cpu temp stays about 38-42´c on idle after reboot and hours of use. After sleep mode temp raises instantly to around 50 and stays there on idle. Is this sensor reading error or software ?
600A->T20->T43->T61-W520
troubadix
#983 Post by troubadix » Tue Mar 31, 2009 2:56 am
sorry, not this kind of error here & no T20 :oops:
Ursus
#984 Post by Ursus » Wed Apr 22, 2009 12:11 am
Hi, I've had a T60p for a couple of years that was running warm and just found this tool.
1 cpu 50°C (0x78)
2 aps 38°C (0x79)
3 crd 35°C (0x7a)
4 gpu 68°C (0x7b)
5 ba1 33°C (0x7c)
6 x7d n/a (0x7d)
7 ba2 32°C (0x7e)
8 x7f n/a (0x7f)
9 bus 38°C (0xc0)
10 pci 49°C (0xc1)
11 pwr 53°C (0xc2)
12 xc3 n/a (0xc3)
The GPU is the v5250... I need to underclock that a bit although I play some 3D games sometimes.
Oh I am also using the vertical widget that was just posted as it is much more useful to my needs.
Thanks a bunch guys.
troubadix
#985 Post by troubadix » Wed Apr 22, 2009 9:36 am
Ursus wrote:Oh I am also using the vertical widget ...
If you like that you may use v0.62 with .ini:
SlimDialog=1 //Set to 0 to have full window dialog
:D :D :D
Metallo
#986 Post by Metallo » Mon Apr 27, 2009 4:15 am
ciao, troubadix
Hi Troubadix,
I had to format my T40, therefore reinstalled TPFanControl 0.61 as a service.
However, if I use the FastUserSwitching (I have 2 accounts now) the balloon icon doesn't show up when opening the second account.
Any idea why?
Thank you
Alex
troubadix
#987 Post by troubadix » Mon Apr 27, 2009 8:02 am
Hi Alex,
reason why:
In Windows XP, Windows Server 2003, and earlier versions of the Windows operating system, all services run in the same session as the first user who logs on to the console....
as second user isn't in same session (zero), you have to run tpfcicon.exe (out of that startup folder) to communitcate with service by named pipe.
ciao, troubadix
Metallo
#988 Post by Metallo » Mon Apr 27, 2009 2:36 pm
troubadix wrote:Hi Alex,
ciao, troubadix
OK, I see the point... but I won't switch to Vista for this! :roll:
Should you find a solution out of your hat, just let me know :mrgreen:
Ciao!
Alex
Masi_K
#989 Post by Masi_K » Sun May 03, 2009 1:12 pm
I confirmed that tpfancontrol works well with T20 if you do not use sleep/hibernate. Awaking from both modes kindly disables tpf. Manual mode and bios mode works okay, but even when setting fan at full speed, cpu temp doesnt get lower than 50'c. After reboot, everything is back to okay. Temp reading is quite correct. Bottom of laptop is noticiable hotter when 50'c
troubadix
#990 Post by troubadix » Sun May 03, 2009 3:45 pm
Never had any test on T20 :| but by the way had you set inTPFanControl.ini:
// For Thinkpads A2x,T2x,X2x set NoExtSensor=1 to exclude reading
// of extended sensors to prevent program errors.
NoExtSensor=1
Best regards to Finland!
