PII Upgrades
wireless4laptop
wireless4laptop
yes, no special, just put it in harddisk caddy and use.
Yea I agree, but it just depends on the part and how strongly it's needed to run the computer. You can run it without the little plastic cover for the hard drive or a key on the keypad, but without a CPU, you've got NOTHING!
That's why I suggested you just buy a complete motherboard or a complete lower base. It may cost a little more, but you are getting more parts for your money.
tfflivemb2
- Moderator1
The 2645-41U is just fine. Are you adding the PC100 to another PC100 stick? If so, you MIGHT have a problem detecting all of the memory. The PC100 sticks do work, but tend to have problems when trying to max out the system, where they only detect 50% of the second stick.pcnoob wrote:Ok, just got my TP600 in the mail. It's a 2645-41U. Is this any good. I also bought a stick of Kingston PC100 128MB SODIMM. I think the density on that stick of memory is 16x64. Would it be backward compatible?
tfflivemb2
- Moderator1
It was the second slot that seemed to be affected. You might want to search through the forum and see if there were any fixes. I have been rather forunate myself, and haven't run in to this problem with any of the TP600s that I have maxed out. I think that the 41U was one of them, but I can't say for certain.
pcnoob
Oh well, I guess can live without that 64mb. Heck, I am glad that I even have a laptop to type my school papers with. I just hate being at the school library, having to bear with the noise from the others around, and being restricted to use their computers for 1 hours per session.
It's finally over. I am free!!
tfflivemb2
- Moderator1
serverbook
- 2 Replies
- 1188 Views
Sat Apr 01, 2017 1:01 pm
- 2 Replies
- 805 Views
Last post by squirrell25
Tue Apr 18, 2017 6:15 pm
- 9 Replies
- 646 Views
Last post by MikalE
Wed Jun 14, 2017 9:32 am
