T43: Fan and error 2010 solved?
NeoteriX
#31 Post by NeoteriX » Thu Dec 01, 2005 1:31 am
Heh, how in the world do you hit 33 degrees on the T43 at normal room temperature?! That's insane :) My TP maybe starts at 33 when it'ss been off and in a cold place...
christopher_wolf
Special Member
#32 Post by christopher_wolf » Thu Dec 01, 2005 1:33 am
I have started out at around 31 Degrees and hit 33 Degrees easily; depends on the ambient temperature (colder is better) and how it started up (a resume from suspend or hibernate won't add as much heat as a full boot would). :)
~o/
She does the things you do.
But she is an IBM.
zane
#33 Post by zane » Thu Dec 01, 2005 11:18 am
Before update, starts at 50C and rises to 52C.
After update, starts at 39C and rises to 45C(fan kicks at 44C).
The fan noise is same.
The ambient temperature is about 24C. CPU voltage is set to 0.7V.
Thinkpad T43 PM 1.86GHz 1GB 100GB X300 14.1" SXGA DVD Intel 2915 ABG WinXP/FC4
christopher_wolf
Special Member
#34 Post by christopher_wolf » Thu Dec 01, 2005 11:32 am
Is this when you are plugged in or on battery? Before, I used to startup around 37 Degrees; afterwards, it has gone down to 35 Degrees.
~o/
But she is an IBM.
ninecup
#35 Post by ninecup » Thu Dec 01, 2005 1:55 pm
This sounds very good.
zane wrote:Before update, starts at 50C and rises to 52C.
IBM Thinkpad T43 2668 AJU, P-M 2.0Ghz, 14SXGA,X300,60GB 5400rpm,256Mb,Windows XP Home/FC3
