Best X-series to buy used?
brainpicker
OK. Well I guess that pretty much sums it up then. If an X20 can't be upgraded then neither can an X21, and if an X22 can't then that rules out the X23 & X24 too. It was worth a try as once you mentioned the RAM, HDD, and wireless speed upgrades I couldn't think of anything else that would matter to you besides the processor (I already knew video wasn't possible). I guess you've hit it all then. Well, maybe if you buy the X2 base you could get a speedier optical drive or even a dvd-burner?
Yak
Yak
Lenovo T60 (IPS) - Fujitsu ST5020D - Fujitsu Q2010 - Docks and accessories for each (and a roomfull of stuff I can't use.)
I was surprised that the 800mhz Pentium III and 256mb RAM runs does everything I need it to on here. (My desktop is an overclocked A64 @ 2800mhz 1gb RAM, 6800gt)
With XP Pro, I use it for everything office based, internet, email, messaging... most everything except photoshop and gaming. I even some web design work on here.
It doesn't feel sluggish or slow, once you have the OS tweaked it is rather snappy if you keep XP in good shape.
-Drew
ThinkPad X22, 800mhz, 256mb, 20gb, wifi, Windows XP Pro
underclocker
- moderator
The X22 is probably the best value at this time for a lightweight and small laptop.
This is my travel machine. I am surprised every time I use it. It is so fast that it's hard to believe it's only a PIII, 800MHz machine. I have 256MB RAM, WinXP and I upgraded the 20GB drive to an 80GB, 4200 rpm with and 8MB cache. Although the drive is the same speed as the original, the cache (4X the original's size) makes a huge difference. The drive runs cool and is silent, but it is fast!
The T22 was also the first model to have an Infrared port.
USB 1.0 is the only down side (but a pc card will work).
The T20 is noticeably slower, I had two and sold both.
You can refer to the Hardware Guide, but the T22 definitely has the cpu soldered to the system board, I looked, too. Unless you have really small fingers, loads of patience, and a soldering gun with a tip the size of a pin, you're not swapping the cpu on this one!
underclocker
underclocker
asiafish
- thinkpads.com customer
Batteries and LCDs are the big issues on any used laptops, and there is no hard and fast rule for how long they will last. Best bet is to ask lots of questions of the seller before you buy and make sure that he/she will take it back if the LCD isn't to your liking.
Batteries should always just assume to be bad. Worst case, you go to IBM or an eBay vender and buy a new one.
Richard Dawkins, 2002
FS: misc parts.... lightly used classic keyboard | 4GB DDR3 RAM | lightly used T500 palmrest, bezel
by tpdude4 » Sat Dec 31, 2016 9:06 am » in Marketplace - Forum Members only - 6 Replies
- 692 Views
Last post by tpdude4
Sun Jan 15, 2017 6:45 am
Best 15.4 (or larger) *used* TP with numpad
by glossywhite » Thu May 18, 2017 4:33 pm » in Thinkpad - General HARDWARE/SOFTWARE questions - 6 Replies
- 580 Views
Fri May 19, 2017 3:47 pm
Best "x" series for an i7
by yakuza » Sun Feb 05, 2017 9:00 am » in ThinkPad X200/201/220 and X300/301 Series - 16 Replies
- 2203 Views
Last post by apojoga
Mon May 22, 2017 2:48 pm
At which series level did this t series start coming with W7 Restore Discs?
by fefrie » Fri Apr 21, 2017 10:35 pm » in ThinkPad T400/410/420 and T500/510/520 Series - 2 Replies
- 721 Views
Last post by w0qj
Sat Apr 22, 2017 5:18 am
