What kind of trackpoint do you use, and why? [3 pics, 14Kb]
davidspalding
tfflivemb2
- Moderator1
The first time I saw the soft rim ones, I thought they were mistakes - that the convex part had been scooped out or something, heh.
Anyway, it's a toss up between the classic dome and soft dome ones. Ultimately, though, the soft dome ones won out.
Incidently, I far prefer trackpoints to touchpads. In fact, I always disable my touchbad, so when my R50e didn't come with one, I didn't feel it a great loss, heh.
The only drawback to them is that doing things like playing Starcraft kinda makes your wrist tired... more so than a regular mouse would..
davidspalding
davidspalding
For those looking to buy JUST the classic cap, I found a [edit] private dealer of old Model M keyboards who sells them.
http://www.clickykeyboards.com/index.cf ... /id/150695
draco2527
I like the soft dome the best (I still like the "cat's tongue" caps as well and have about two dozen new ones)...I have to replace them often "OCD" when it comes to them getting crummy (the soft dome are easy to clean..but they do wear out)
The soft rim I hate!!!!
X220T Multi-touch
T410
X61T (pen)
X61T X2 (pen/touch) 1-WIN7 1-WIN8
T61
T410
X61T (pen)
T61
Well, if you have REALLY small fingers...benz wrote:I'm surprised no one mentioned option D:
http://img8.imageshack.us/img8/2889/nullpointer1aq.jpg
lowie
... tried it that way, no fun at all!benz wrote:I'm surprised no one mentioned option D:
{own}X60-1706|X30-2672
{owned}T42-2376|T40-2374|A30p-2652|R40e-2684
IAmTheEvilest
This feature is called "Press-to-select" and should be configurable on any T4x model, in the Ultranav control panel (which you can access through Control Panel -> Mouse).laz wrote:I noticed that with my dad's T42 2374 you can push down on the trackpoint to click, but on my T42 2373 you can't. When did they introduce that feature?
lowie
Do you actually use that "press-to-select" function? I am almost unable to perform select actions by pressing the trackpoint; most of the time it just moves the pointer away from what I want to selectdr_st wrote:This feature is called "Press-to-select" and should be configurable on any T4x model, in the Ultranav control panel (which you can access through Control Panel -> Mouse).
I don't use it. I hate it. It is the same feature that annoys me on touchpads - very easy to trigger unintentionally.lowie wrote:Do you actually use that "press-to-select" function? I am almost unable to perform select actions by pressing the trackpoint; most of the time it just moves the pointer away from what I want to selectdr_st wrote:This feature is called "Press-to-select" and should be configurable on any T4x model, in the Ultranav control panel (which you can access through Control Panel -> Mouse).
I move the pointer with my index finger and click with my thumb. Very easy.
davidspalding
I've had that on OTHER laptops, and I've found that I could lightly tap on it to select or double-click. Worked fine after < 1 hour's experimentation.lowie wrote:Do you actually use that "press-to-select" function? I am almost unable to perform select actions by pressing the trackpoint; most of the time it just moves the pointer away from what I want to select
BTW, you can disable the tap-select feature on the Touchpad, I think. In the version on my T43, that is. I might be thinking of click-drag, though. (Don't have my TP here with me.)
PrincipalValiant
I've ordered a set of extras and gave the soft dome a shot. I that with the soft dome I'm able to set the trackpoint to a much higher speed and control it more accurately than with the classic cats tongue.
Although it doesn't grip as well when my hand sweats and it seems to be sort of coushy it is definitely worth the extra speed and accuracy gained.
IBM T23 [2647-2TU] 1.0Ghz 1.0GB PC133 Hitachi 7K60 + 40GB Travelstar T30 Battery CDRW/DVD IV
Looking for 14" SXGA+, 1.2Ghz PIII, OPTIONAL DRIVE SCREWS & spare T2x series parts at reasonable prices
christopher_wolf
- Special Member
FRiC
I find that press-to-select works best with soft rim since the center is concave and easy to press down and doesn't lead to a side movement.lowie wrote:Do you actually use that "press-to-select" function? I am almost unable to perform select actions by pressing the trackpoint; most of the time it just moves the pointer away from what I want to selectdr_st wrote:This feature is called "Press-to-select" and should be configurable on any T4x model, in the Ultranav control panel (which you can access through Control Panel -> Mouse).
When I remove my trackpoint cap, the little black plastic part under it also comes off and I see the tiny stick of the trackpoint device itself. Is this normal? Should I glue the plastic part back?
X230 | i5-3210M | 8GB | 500GB | WWAN
davidspalding
- 2389 Views
Last post by Cookie Guru
Sat Dec 31, 2016 6:21 pm
What batteries did you use recellers?
by Thinkpad4by3 » Sat Jun 17, 2017 3:32 pm » in ThinkPad T4x Series - 3 Replies
- 256 Views
Last post by w0qj
Thu Jun 22, 2017 7:53 am
Thank you guys! I wanna get to know you more!
by Whitieiii » Sun Jan 22, 2017 6:52 am » in Off-Topic Stuff - 2 Replies
- 565 Views
Last post by TPFanatic
Sun Jan 22, 2017 11:51 pm
What computer have you had for the longest? When did you get it?
by pianowizard » Tue Jun 27, 2017 6:51 am » in Off-Topic Stuff - 5 Replies
- 118 Views
Last post by Puppy
Wed Jun 28, 2017 5:06 am
