X60/T60 announced
Yeah... would like to know whats that about...JonathanGennick wrote:Less weight in Japan? I want that model thenGomJabbar wrote: X60s - starting at 2.54lbs (Japan) or 2.69lbs (rest of world) (7% lighter than X41).
What do you suppose is different about it?
Anyway... ill go check em out at the cebit
Own:
X61t
Owned:
X41, X31, T41, T42, X40, X61s
Yes... I love the X-series.
X61t
Owned:
K. Eng
- Moderator Emeritus
Ouch. I don't suppose anyone could get their hands on one for review?
hoya wrote:the lead-time on the T60 is 45 business days... that's 9 weeks! I'll be at CES tomorrow so I'll check them out then.
I'm also curious to know what the difference is between the X60 and the X60s. Does any one know?
kadf88
not according to this[/url]dr_st wrote:
X60s is slimmer and uses Ultra-Low-Voltage processors, which save battery power, but aren't quite as fast. Dual-core processors will only be available at the X60, not the X60s.
X31 2672-38U
1.5 Banias
1.5 gig
1.5 Banias
1.5 gig
Yes it does, see down on the page of this thread the answer from abaxter to my similar question...hoya wrote: ...
does the X60s also use a 2.5" hard drive? what is the source of your info?
http://forums.notebookreview.com/showth ... 228&page=2
The link I posted earlier from Lenovo's site shows the T60 uses the Ultrabay Slim expansion bay.T41mbi wrote:Have they finally put in a better screen?
and can I use my T4x ultrabay slim drives with the T60?
The screen on the first model is a 14.1" TFT XGA. I would suspect it is basically the same one as on my T42 model.
Link from Lenovo: ThinkPad T60
DKB
juancferrer
anandtech previews the T60 (skip to page 15) http://www.anandtech.com/mobile/showdoc.aspx?i=2663
Has a wireless on/off switch!!
the arrow keys also function as play/pause/stop/FF/etc..
seems that the microphone might have been moved near the Fn key (not a good idea IMO)
The volume up/down/mute buttons aren't as cool looking, and they're not shiny
The external antenna is for WAN only - so if you don't want that you won't have this.Steve007 wrote:Edit: Now I've seen more photos the T60 looks cheap and dare I say it, tacky?
I don't like the external antenna on the right hand side of the screen and the keyboards look cheap and nasty. It' certainly a massive step back from the rounded keys on the T4x series keyboard.
But I don't get your cheap and tacky comments as it looks the same quality as T4* to me nor do I get the point about rouded keys - the keyboard keys look the same to me other than the cosmetic change (colour/font).
Well I can't tell for sure until I see one in the flesh. It's not that bad though - just not much different to the T4x series, which is not a bad thing I guess....snife wrote:But I don't get your cheap and tacky comments as it looks the same quality as T4* to me nor do I get the point about rouded keys - the keyboard keys look the same to me other than the cosmetic change (colour/font).
The keyboard is different though.
(2373-G3G) T40p/P-M 1.6GHz/1GB/60GB/14.1 SXGA/64MB ATI Fire GL 9000/CDRW-DVD/Cisco 802.11b/WinXP Pro SP2
(2373-8TG) T42/P-M 735/1GB/40GB/14.1 XGA/32MB ATI Radeon 7500/CDRW-DVD/Intel 802.11bg/WinXP Pro SP2
See http://forum.notebookreview.com/showthr ... 232&page=3I brought up the smaller ultra nav keys, it's really not a way for them to cut corners but instead they got feedback and did usability tests indicating that the buttons are too big and prone to accidental strikes. Never a problem for me, but I take their word. As far as the non-grey buttons on the Function keys, the taking away of the blue and red stripe on the mouse buttons and silver power button -- that was also a conscious design move as they said in surveys most business users preferred less color on the keyboard area, especially their European user base, who they said much preferred more black and grey and less of the different color tones. Honestly, they're doing everything for a reason with thought behind it and not just to save a $1 here and there.
AlphaKilo470
I personally would have preffered that the mouse buttons stay colored as on most ThinkPads in the past. I also really don't like the wedge design (where the computer can't lay flat, originally seen on the G series) that they decided to incorporate on the X60.
Other than that, I think the new computers look pretty nice. I personally think that the X41 and the T4x look nicer than the X60 and T60 but that's not to say the new ThinkPads look bad, it's just saying the X41 and T4x look really nice.
- 985 Views
Mon Feb 06, 2017 12:11 am
- 680 Views
Last post by Muse
Mon Apr 24, 2017 7:22 pm
X60 tablet activation or Linux question
by Billaboard » Thu Jan 12, 2017 8:00 pm » in Thinkpad X6x Series incl. X6x Tablet - 12 Replies
- 1867 Views
Last post by Billaboard
Fri Jan 20, 2017 6:18 pm
WTB: X60 Tablet, SXGA+ (1400x1050) display
by topramen » Mon Jan 23, 2017 10:16 pm » in Marketplace - Forum Members only - 3 Replies
- 384 Views
Last post by unixed
Tue Jan 24, 2017 5:34 pm
