ThinkVantage Access Connection Problem
Riddil
#61 Post by Riddil » Mon Apr 03, 2006 7:40 am
Paul Unger wrote:Is there any real surprise that some of us area having problems with this when we're dealing with 'supplicants', 'VBS scripts', and 'stacks', Riddil?! That's all WAY beyond me :roll: But thanks for taking the time to troubleshoot that for us! And here I thought a 'supplicant' was someone who asked his *god* for something--which is about where trying to get AC to work had left me :lol:
Trust me... I can completely identify with you. The sad truth is that it *doesn't* have to be this difficult. It's just a poor installer in the intel driver / supplicant package that creates all the headaches. But since the nastiness is there, it means it's a huge pain in the [censored] to get it working. :-/
fotel
#62 Post by fotel » Tue Apr 17, 2007 6:26 pm
Hi guys, I am a newcomer to this forum, but I am experiencing the exact same problem with the newest AC (4.23) and 2200BG driver (9.0.4.33). It was working fine until I accidently installed the intel utility also, not just the drivers. I tried to uninstall all software related to wireless with Your uninstall! (So I am not a write-only person:) ) and it all went fine, but the problem still persists. One time in device manager when I checked the state of the adapter the ON/OFF switch also disappeared.
What else should I try?
Among the protocols I can not see the AEGIS, even if I installed the drivers for the adapter as they are ment to be installed.
BTW, I am using XP with SP2, it that makes any difference.
IBM T23 - 1.13Ghz, 1G RAM
Lenovo T500 - 2082
manixc
#63 Post by manixc » Thu Apr 19, 2007 11:04 am
fotel: I am having the exact same problem. :(
update1: I decided to uninstall Access Connection and repair my installation of the new Intel drivers and utilities. I can connect using Windows.
I will try to reinstall an old version of Access Connection (v4.12 I think).
update2: I can connect with Windows but not Access Connection with the newest drivers. I found that Access Connection do not have the right MAC address for the wireless adapter.
update3: I tried AC v4.23 but it didn't work(become non-responsive often) as well. and it's very slow on my T42. any ideas?
Always, Always have a back up plan
fotel
#64 Post by fotel » Sun Apr 22, 2007 1:29 am
Well, I got my problem solved.
When I have been installing the Intel drivers, I unchecked to install the PRO/Wireless software. This caused the unpresence of the AEGIS protocol, becouse the 801.x supplement is only installed when you check the PRO/Wireless software too, so I installed it again (from the lenovo site, not Intel) and using the default settings. Previously I installed the software from the Intel website, but than it has set up to use its own application to manage WiFi, so this is why I uninstalled that part and choose only the drivers. When using the lenovo package, I did not experience that.
After that I only reinstalled Access Connection, without even uninstalling it's previous version. I am using the newest package for both 2200BG drivers and AC.
Hope this helps.
I tought, that the supplement is part of the driver package, since it acts more like a driver to me, and is will be installed without the Intel wireless app also, but I was wrong.
Lenovo T500 - 2082
