This is on a 2668 with 39T0355 Integrated Bluetooth IV (firmware 9.105/99). Back to Bluetooth IV Integrated Software 3.0.1.918....Released Versions
Version 4.0.1.2302 Initial release
Version 4.0.1.2600 A problem fix
Version 4.0.1.3000 Support for new models and problem fixes
Summary of Changes
Where: < > Version number
(New) New function or enhancement
(Fix) Correction to existing function
<4.0.1.2302>
- (New) Initial release for ThinkPad Z60t/Z60m
<4.0.1.2600>
- (Fix) Fix the issue that the Headset profile sometimes does not
work properly on Windows 2000.
<4.0.1.3000>
- (Fix) Fix an issue that the memory usage of Bluetooth Task Tray
(BTTray.exe) increases along with typing NumLock(NumLk) key.
- (Fix) Design change not to install virtual devices until user start
using the software for the first time.
- (New) Support ThinkPad T60/T60p
- (New) Support ThinkPad X60/X60s
- (New) Support ThinkPad R52/T43/T43p/X32/X41/X41 tablet
Problems with new Bluetooth integrated with enh. data rate
davidspalding
Following the suggestion of Software Installer this week, I installed the latest "Bluetooth with enhanced data rate software 4.0.1.3000" (77BA10WW). Apparently this "... with enh. data rate" was released in January (?) for the Z60 line, and this latest version incorporates support for T43/p, T60/p, X41 X60, and a few other models. Since updating, my radio would turn off immediately after turning on. That is, Bluetooth was unusable.
2668-75U T43, 2GB RAM, 2nd hand NMB kybd, Dock II, spare Mini-Dock, and spare Port Replicators. Wacom BT tablet. Ultrabay 2nd HDD.
2672-KBU X32, 1.5GB RAM, 7200 rpm TravelStar HDD.
christopher_wolf
- Special Member
Interesting problem; I made the update and had to do a bit of fiddling, but I un-installed anything else that could cause problems before then I went ahead with the Bluetooth update. I even got the Audio Gateway to work and have answered calls on my T43 which was really cool. I noticed a bit of an increase in transfer rates as well.
Have you tried a manual un-install and re-install?Try to not reboot afer un-installing the previous version as Windows will attempt to install its own drivers whilst the new Bluetooth is installing via Software Installer after the reboot. Just un-install the previous version and install the new one, manually if you have to from the package, and then reboot.
HTH
HTH
~o/
She does the things you do.
But she is an IBM.
~o/
But she is an IBM.
bill bolton
Re: Problems with new Bluetooth integrated with enh. data ra
I installed it with no hassles at all and its working fine here on a T43!davidspalding wrote:Since updating, my radio would turn off immediately after turning on.
Bill
davidspalding
davidspalding
Integrated Bluetooth II + Windows 7: How to use bluetooth headset??
by kfzhu1229 » Sat Jan 07, 2017 1:00 am » in ThinkPad T4x Series - 11 Replies
- 1791 Views
Last post by dandreye
Sun Jun 11, 2017 3:10 pm
Windows 10 + W520 frame rate drops to ~30 fps in games
by u666sa » Thu Mar 09, 2017 8:41 am » in ThinkPad W500/510/520 and W7x0 Series - 9 Replies
- 2634 Views
Last post by jcvjcvjcvjcv
Sun Apr 02, 2017 6:19 am
Microsoft finally reveals what data Windows 10 really collects
by Puppy » Wed Apr 05, 2017 2:27 pm » in Off-Topic Stuff - 9 Replies
- 808 Views
Last post by shawross
Wed Apr 19, 2017 12:56 am
Does it make sense to use mSATA SSD for data partition?
by serpico » Wed Apr 19, 2017 9:14 am » in ThinkPad T430/T530 and later Series - 11 Replies
- 627 Views
Thu Apr 20, 2017 12:36 pm
