***NO MORE 2010 on AFTERMARKET HITACHI (7K100, 7K60, etc)***
patfla
#31 Post by patfla » Tue Feb 28, 2006 1:19 am
Tried this but ...
Have a HTS721010G9AT00. 100 GB 7k100 that is. I get the 2010 error and while I have bios 1.24, haven't bothered yet to set the thing to pass over the 2010. And usually just hit ESC.
Made the diskette in secton B of the instructions and tried it out.
You boot from DOS into the application. There are three panes in the DOS style display: upper left; upper right and bottom. Upper right gets filled in with information about the new flash.
Upper left should get filled in with candidate drives to which the flash can apply itself to.
The bottom pane shows your results after you run (say hit U).
For me, the flash info appears in the upper right.
But nothing appears in the upper left. And neither the first 'failed' operation (OA51A) nor the succeeding operation work.
Says something about "no recognized drive".
After thinking about in several ways, my best guess is as follows: GangBang shows his 'before' firmware version to be MCZOA40M.
Can you post your 'after' firmware version?
The reason I ask is that the firmware version my machine came installed with is MCZOA51A. Which seems to be what others are upgrading to.
I can only speculate that what I have is OA51A (Hitachi's) and not IA51A (IBM's [that won't provoke the 2010 message]).
So the DOS application runs; finds that I'm at A51A already. And does nothing.
Dang.
So the natural thing occurred to me. Downgrade to some prior version of the firmware. And then upgrade to IA51A.
Except searching around the Web I don't find any Hitachi HDD firmware kits.
Ideas?
thanx.
pat
noeffort
just bought an Hitachi OEM drive
#32 Post by noeffort » Tue Feb 28, 2006 9:56 am
7k100 60gb for my t41. Is a firmaware upgrade needed?
Just flashed bios to lastest rev 3.19 and embedded controller to v3.04.
thanks
Aroc
#33 Post by Aroc » Tue Feb 28, 2006 1:35 pm
To noeffort:
The firmware update is only for T43 thinkpads since the t43 is native SATA but uses a PATA-to-SATA bridge in order to use PATA drives. Your T41 does not have this bridge and therefore does not have the BIOS flashes a 2010 error when a non-IBM drive is installed.
So the answer is no.
Please read the rest of the thread for yourself or do a search on the 2010 error. you will find the answers you need.
IBM X220 | T61p | R61e | T43 | Black Macbook | i5 Hackintosh | i7 iMac 27 | Dell 3007WFP-HC WQXGA
Aroc
#34 Post by Aroc » Tue Feb 28, 2006 1:42 pm
double post
Phil_C
#35 Post by Phil_C » Tue Feb 28, 2006 11:33 pm
patfla wrote:Made the diskette in secton B of the instructions and tried it out.
pat
I don't have my new Hitachi HDD yet, but I think you are supposed to boot from the floppy and bypass autoexec.bat with F5, then type the commands on the DOS command line, not from within the FW.EXE program.
Is this correct, everyone?
Phil
W500 4062-36U, 2.53 GHz, 15" WSXGA+, Win 7, 8GB RAM, 512GB SSD, Multi-Burner, Intel WiFi Link 5100, 9-cell battery
T43p 2687-EJU, 2 GHz, 15" UXGA, Win 7, 2GB RAM, 100GB 7200 RPM HDD, Super Multi-Burner, IBM WiFi II, 9-cell battery
Aroc
#36 Post by Aroc » Wed Mar 01, 2006 12:36 am
Yes, I went so far are to delete the autoexec.bat completely. It's not needed.
patfla
#37 Post by patfla » Wed Mar 01, 2006 2:36 am
Well not really sure what the heck I did yesterday (today's been a really long day, and it's now after 11).
The one thing I didn't know is F5 as DOS is starting up to bypass config.sys and autoexec.bat.
Yet on the other hand, I really do think I was using the hfui15 commands the other day. (which would indicate that I was at the command line).
Whatever.
Today, tried again. Hit F5 as DOS was booting from the diskette. Followed in the instructions (first Oa51a; failure; then Ia51a; success).
And yes it works. Flashed. The app indicated success. And the 2010 err message is gone.
And as far as different rev levels, another thing I vaguely remember is checking hfui15's switches and I believe /F means 'force' that is, ignore, for example, that the rev level might seem to be the same.
In Computer Mgmt | Dev Manager | Hard Disks | Properties on the right disk | and then the Details tab, yesterday it read MCZOA51A.
Today it reads MCZIA51A.
pat
GangBang
User with bad email address, PLEASE fix!
#38 Post by GangBang » Wed Mar 01, 2006 11:55 am
Patfla...
Good to hear everything works fine with u. :wink:
T20, X20, T30, T40p 2373-G1A(Upgraded to 2.1 Ghz 765, 2GB Samsung DDR PC2700, HDD 72K60), T43 2668-4DA(upgraded to (replaced)MOBO w/ 128MB FireGL V3200, BMDC3, 2GB Crucial DDR2 533, Multiburner Plus, HDD 7K100)
patfla
#39 Post by patfla » Wed Mar 01, 2006 4:08 pm
Yes. And thanx to you and Messar for making this possible.
CupOfJoe
#40 Post by CupOfJoe » Wed Mar 01, 2006 4:50 pm
Just here to report a SUCCESSFUL venture in ridding myself of the 2010 POST error.
I recently came into a newly purchased T43p -- 2687D5U.
I wanted to upgrade the drive to a 7200rpm version, so I purchased an OEM drive at the local electronics superstore:
Hitachi 80GB 7200rpm HTS721080G9AT00
(Manufacture date of the drive: September, 2005)
I grabbed the "5K7K100_Revised.rar" file and extracted the IMG file from the RAR archive. Then I extracted the files from the IMG file, and created a bootable CD with the extracted files on it. Finally, I proceeded to boot my laptop with said CD.
After following the directions posted by messar, everything is A.O.K. -- no more 2010 POST message.
My gratitude to messar et al. Sometimes the internet (or, more appropriately, the people who use & contribute to it) can be the most useful resource on earth -- ya gotta love it!
-CupOfJoe
T60p (200783U -- with 2GB of RAM)
Phil_C
#41 Post by Phil_C » Wed Mar 01, 2006 7:17 pm
Well, duh --- Never having bought anything but an IBM HDD, I now see that no screws and no bracket came with my new Hitachi. Where do I buy those?
Phil
Phil_C
#42 Post by Phil_C » Wed Mar 01, 2006 10:11 pm
Another successful FW update here (7K100 100GB). Thanks much, messar and everyone else. These forums are great!
Phil
DIGITALgimpus
#43 Post by DIGITALgimpus » Fri Mar 03, 2006 8:53 pm
I have a HTS541010G9AT00 (firmware version: MBZOA60A).
Sigh... sadly doesn't seem to have a firmware update.
Talked to Hitachi, the rep was rather helpful, and said they have absolutely no reports of issues with their drives in T43's, besides the 2010 error. It's purely the firmware to identify.
Anyone have an idea for the MBZO revision of the 5k100 (100GB)?
mamamia
easier way
#44 Post by mamamia » Sat Mar 04, 2006 6:09 pm
thank you so very much, cupofjoe. i realized you didn't use a bootable floppy or usb. and so, i just followed your example. burn that img that messar provides onto a cd. boot with it. follow same as part A.
worked perfectly. 7k100 on x31.
thanks messar
CupOfJoe
Re: easier way
#45 Post by CupOfJoe » Mon Mar 06, 2006 1:47 am
mamamia wrote:thank you so very much, cupofjoe. i realized you didn't use a bootable floppy or usb. and so, i just followed your example. burn that img that messar provides onto a cd. boot with it. follow same as part A.
thanks messar
Excellent!
These kinds of forums prove their usefulness over & over again.
Yep - I'm a fan.
-CupOfJoe
messar
#46 Post by messar » Mon Mar 06, 2006 6:27 am
seems that I should provide a bootable iso image for part B....
I'll do this tonight. GMT+8 in hongkong :wink:
vcbaby
#47 Post by vcbaby » Wed Mar 08, 2006 8:46 pm
messar, upload the bootable iso image for part B,please!
thx!
IBM Fans
u.vivarelli
#48 Post by u.vivarelli » Thu Mar 09, 2006 6:11 pm
I've a problem...
when I've the prompt "A:>" I write the string for my drive and the answer is: bad or invalid command"
It's normal that if I press "dir" I've only 10 files as "autoexec.bat, command.com, system.sys, xcopy ecc.. but not the files of the CDrom????
I use this string:
hfui12h.exe oa6ga mh4ia6ga.bin \f mrha6ga.tbl
(for a 7k60)
thanks!!!!
monkey243
#49 Post by monkey243 » Fri Mar 31, 2006 1:42 pm
Tried to update My 5K100 80G firmware,But failed!
The command typed:
hfui14 OA60A -pm MB4IA60A.bdr /f mpba60ab.tbl
Press 'U' failed,Message:firmware is aleardy update.
hfui14 IA60A -pm MB4IA60A.bdr /f mpba60ab.tbl
Press 'U',failed,Message:Unmatch the original firmware
I have tried many times,but just failed.
somebody can help me?
IBM X31 2672B1J 1.3G/1G/120G/CISCO 350
aograin
100GB 7k100 Hitachi Problems
#50 Post by aograin » Thu Apr 20, 2006 12:41 am
Ok, long time reader, first time poster… anyways I just purchased a 100GB 7k100 Hitachi and am having trouble updating the firmware. Here’s what I’ve done so far…
I’ve downloaded and booted from a USB flash drive the files provided by Messar. Yet I can’t get them to work correctly.
The firmware that came with the drive is (MCZOA51A) I need (MCZIA51A).
I’ve tried the:
HFUI15.EXE OA51A MCZIA51.BDR /F MPCA51AB.TBL (and then)
HFUI15.EXE IA51A MCZIA51.BDR /F MPCA51AB.TBL
But I get these errors:
(Execution Status Window)
Checking Drive 0 (Device 0 on Primary Bus)
Soft reset failed. Error code=ff80
Am I missing something? Should I copy my operating system onto the drive first?
Maybe someone has bootable cd.iso that worked for them they could post. As always, thanks for any help.
Phil_C
#51 Post by Phil_C » Thu Apr 20, 2006 2:26 pm
aograin,
What happens after you enter the first line of commands? Are you taken into the program screen where you press "U"?
Maybe booting from a flash drive is causing the problem. I don't recall anyone else here doing that. You may need to try a floppy.
I have two of these HDD's and each FW update worked perfectly using an external floppy.
Phil
aograin
#52 Post by aograin » Fri Apr 21, 2006 2:59 pm
Ok, I figured it out. when I created the USB boot drive using HP's utility, I just copied the files over directly onto it. What I needed to do was to create a folder and then put the files into that folder. But that fixed the problem.
dylan2002
#53 Post by dylan2002 » Tue Apr 25, 2006 11:55 am
After follow the article description, I upgrade my 7K100 HDD firmware success and no more 2010 message. appreciation. :D
Rory
#54 Post by Rory » Sat May 06, 2006 1:01 pm
Help, please!
I just got a T43 and bought an 80GB 7K100.
The T43 has the latest BIOS (1.25) and I get the 2010 error. The drive has f/w MC40A51A. I used Aronis True Image and the drive boots fine after hitting escape. I know there's an option in the BIOS now to enable the drive to boot on its own but I would like to upgrade the drives firmware.
I tried to follow Messars instructions (part B) but fell as the first hurdle as I can't seem to download the file from http://rapidshare.de/files/13761480/5K7 ... d.rar.html
- either I'm doing something stupid or it's not there anymore?
Edited to say I've made this work now, and will post separate details.
DIGITALgimpus
#55 Post by DIGITALgimpus » Sat May 06, 2006 7:45 pm
They released a new firmware CD not to long ago... but still no 5400/100GB suppor (MBZOA60A). [censored].
:cry:
sam0627
#56 Post by sam0627 » Sun May 07, 2006 4:29 pm
Has anyone updated?
Hitachi; HTS721060G9ATOO (7K100)
FIRMWARE; MC30A0M
Can't seem to make Messar's work
alank2
#57 Post by alank2 » Thu Jul 20, 2006 7:32 am
I ran the instructions on a 7K 100Gb Hitachi and at first they wouldn't work. It occured to me that I had a User+Master password set on the drive, so I removed it, and then re-ran the instructions. It worked fine.
So, for anyone who is having issues, make sure you don't have a hard disk password assigned before trying...
Thanks,
Alan
dhave
#58 Post by dhave » Tue Aug 22, 2006 3:05 am
Has anyone succeeded in updating the firmware of a Hitachi E7K100? The update routine correctly identifies the drive, but the drive name isn't blinking. I'm guessing that it won't update.
Thanks.
T21, T41p, T61p (two), T420, T520
DIGITALgimpus
#59 Post by DIGITALgimpus » Tue Aug 22, 2006 7:48 am
Not likely. That's not even a laptop hard drive.
dhave
#60 Post by dhave » Tue Aug 22, 2006 8:57 am
DIGITALgimpus wrote:Not likely. That's not even a laptop hard drive.
It's been running in my Thinkpad for almost nine months. It's nearly equivalent to the Hitachi 7k100. They're both 100Gb 7200 rpm Travelstars.
