Full charge capacity vs. Number of charge cycles.
scillyisles
Model T42p 2373 QIG
9 cell battery
Full charge capacity 71.18 wh
Design capacity 71.28 wh
Cycle count 7
First used 2004-11
Model T41p 2373 GEG
9 cell battery
Full charge capacity 73.02wh
Design Capacity 71.28wh
Cycle count 12
First used date 2004-02
9 cell battery
Cycle count 7
First used 2004-11
Model T41p 2373 GEG
9 cell battery
Cycle count 12
2373-Q1U T42p 2.1Ghz P4M 2GB RAM, ATI Firegl , 320Gb,15" LCD,Win 7 Ult
6457-BQG T61p 2.6GHz C2 Duo 4GB RAM, 320GB 15.4in LCD,FX 570M, Win 7 Ult
2758 W700 QX9300 2.53GHz 4GB ram, 200GBx2 BDWriter, 1GB FX3700m,17" Win 7 Pro
4319-4NG W510 i7820QM,8GB,320gb,15.6 FHD,FX880M,Win 7 Pro
Model of thinkpad T42
Number of cells 6 (internal) SONY Li-Ion
Design capacity 47.52
Full charge capacity 41.43 (87%)
Number of charge cycles 53
Manufactured date. 2004-06-04
First Use Date 2004-07
Number of cells 3 (ultrabay slim) SANYO Li-Polymer
Design capacity 23.76
Full charge capacity 18.83 (79%)
Number of charge cycles 106
Manufactured date. 2004-07-26
First Use Date 2004-08
Maybe someone has some tips for me as I always have the Ultrabay Slim (UBS) battery installed...
What happens here is that the UBS battery runs flat first before the internal one (obvoiusly). Thing is therefore you induce more charging cycles on the UBS battery which in turn shortens its life..
I tell you what though it's nice not to have the protruding 9-cell thingy hanging out the back ..
pretty decent actually
Model of thinkpad: T41
Number of cells 6
Full charge capacity 41.36 :-j
Number of charge cycles 89
Number of months since the manufactured date. 12 months, 2004-02-09
used almost a year
Number of cells 6
used almost a year
This is my first post
Model of Thinkpad: T41
Number of cells: 6
Design capacity: 47.52
Full charge capacity: 32.04
Remaining capacity: 15.53
Number of charge cycles: 130
Manufacturer name: Sanyo
Manufacture date: 2004-02-10
First used date: 2004-03
almost used one year
Number of cells: 6
t41 PM 1.6G, 1G ram and 7E60 =good
This is my "backup" 6 cell battery:
Status: No activity
Remaining percentage: 100 %
Remaining capacity: 48.16 Wh
Full charge capacity: 48.16 Wh
Temperature: 27 C
Cycle count: 18
Manufacturer name: SONY
Manufacture date: 2004-03-24
First used date: 2004-04
Serial number: 1084
Bar-coding number: 1Z8PC43R11W
Battery name (FRU part number): IBM-92P1011
Device chemistry: Li-Ion
Design capacity: 47.52 Wh
Design voltage: 10.80 V
Here's my 9 cell info after a bit of charging:
Status: Charging
Remaining percentage: 89 %
Charge completion time: 1:04
Remaining capacity: 57.98 Wh
Full charge capacity: 65.41 Wh
Current: 0.23 A
Voltage: 12.48 V
Wattage: 2.81 W
Temperature: 25 C
Cycle count: 26
Manufacturer name: SANYO
Manufacture date: 2003-11-28
First used date: 2004-01
Serial number: 603
Bar-coding number: 1Z7SR3BW0GR
Battery name (FRU part number): IBM-08K8198
Design capacity: 71.28 Wh
I'll have to figure out where I put my "original" 6 cell battery, it's around here someplace. It reports that the battery health is BAD and has the red display in Battery Information.
Regards,
James
Status: No activity
Temperature: 27 C
Cycle count: 18
Serial number: 1084
Status: Charging
Current: 0.23 A
Voltage: 12.48 V
Wattage: 2.81 W
Temperature: 25 C
Cycle count: 26
Serial number: 603
Regards,
James
James at thinkpads dot com
thewhippingboy
wow, 594 cycles! Mine has ~27Wh after ~160 cycles and 23 months since the manufactured date. Probably the age is more important than the number of cycles.thewhippingboy wrote: Full charge capacity: 27.18Wh
Number of charge cycles: 594
Number of months since the manufactured date: 21
T430 · i7-3632QM · 12GB RAM · 512GB SSD · HD+ · NVIDIA NVS 5400M · H5321gw
T420s · i5-2520M · 12GB RAM · 480GB SSD · HD+ · HD3000 · F5521gw
T60 · T2500 · 3GB RAM · 128GB SSD · 14.1 SXGA+ · 128MB ATI X1400
Past: T400, T41, T22, 600X, 390X
Guv'nor-K
- Location: Embry-Riddle Aeronautical University, Daytona Beach, FL /Home: Karachi, Pakistan
Model of thinkpad: T43
Number of cells: 6-cell
Design capacity: 51.84Wh
Full charge capacity: 49.25Wh
cycle count: 42
Manufacture date: 2005-09-15
First used date: 2006-02
cycle count: 42
IBM T43 2668-44U - running Ubuntu & XP---1.86Ghz - 1.5GB PC-4200 - 40GB 5400 RPM HDD / 7K100 in Ultraslim Bay - X300 64MB - FP Reader - and my Sennheiser HD-595s
Navck
The reason you shouldn't cycle batterys in your packs is that they don't all "evenly charge" (One cell may get a 110% charge (BAD!), another gets 90%)
The only "real" way you can charge each cell indivually would be to take them out or have a smart system that charges a cell a bit by bit with a CC/CV athlogram. But that would mean you couldn't do anything but wait for the battery to fully recharge...
PS = Lithiums when in hot weather, tend to degrade (Bump it high, you lose capacity, bump it higher, you'll risk "venting"). Venting is the fun thing of "when your battery decides its not happy in its specific enviorment, and decides that its seals should open up, leaking flame out."
Guv'nor-K
this is my first laptop and quite honestly, i dont know a lot about the lithium batteries in them...
could you explain what you meant by "you shouldnt cycle the battery in its pack"? i understand a cycle would be a full charge and then a discharge but if you break a down some more for me, id appreciate it, or maybe a link where i could read up on them?
thanks!
thanks!
christopher_wolf
- Special Member
This is a good link to start out from; See
http://batteryuniversity.com/
You shouldn't run down LiIon batteries to 0% charge, that shortens their operational life span. You should also try to store the LiIon batteries in your Thinkpad at around ~40% charge. See;
http://www.thinkwiki.org/wiki/Maintenan ... _treatment
HTH
HTH
~o/
She does the things you do.
But she is an IBM.
~o/
But she is an IBM.
smugiri
Both arguments are right if we pause to realize that we are talking about 2 different scenarios. Regular use and battery re-calibration.jdhurst wrote:I looked up the battery information for my Lithium-Ion laptop battery, and it does not suggest deep discharges. Everywhere I have read about batteries say that deep discharges are not good for L-I batteries.
The advice as posted here is for Ni-MH batteries with a memory.
... JDHurst
You do not want to deep discharge lithium ion batteries in the course of ordinary use and JDhurst is right is saying that you should plug the laptop in whenever and wherever you can to save its life. Partial discharge/charge cycles are better than full discharge/charge cycles in the course of ordinary use.
You do need to deep discharge to re-calibrate the battery which is done to improve the amount of run time you can get from the battery.
@christopher_wolf' link to battery university gives lots of good info including this technical article for those who may be interested.
Steve
princeatul
Model of thinkpad : T43
Number of cells : 6
Design capacity : 51.84 Wh
Full charge capacity : 53.46 Wh (can this be greater than Design Capacity???
Number of charge cycles : 2
Number of months since mfg : 2 months
Battery maintainance:
To increase battery lifespan, you have set your battery to start charging when below 88% and to stop charging at 94%.
somebody suggested to have settings similar to this. Don't remember thread.
--- Edit ---
Found the thread, read comment by hiyel on this thread.
It also rests on the premise that Partial discharge/charge cycles are better than full discharge/charge cycles
Number of cells : 6
--- Edit ---
IBM T43 2686-E7U 14.1" SXGA+, 1.86GHz, 1.5GB, Hitachi 7K100 80GB @7200, DVD-RW, Intel 2915ABG
It is the sweet, simple things of life which are the real ones after all.
smugiri
Model of thinkpad: T40p
Number of cells: 9
Design capacity: 71.28Wh
Full charge capacity: 47.72Wh
Number of charge cycles: 139
Manufactured: 2004-11-08
First Used: 2005-03
This gels perfectly with the argument that frequent partial discharges are better that complete discharges.
Number of cells: 9
First Used: 2005-03
AIX wrote:wow, 594 cycles! Mine has ~27Wh after ~160 cycles and 23 months since the manufactured date. Probably the age is more important than the number of cycles.thewhippingboy wrote: Full charge capacity: 27.18Wh
Steve
Model: R50p
Cells: 9
Design capa.: 71.28 Wh
Full charge: 46.51 Wh
Cycle count: 46
Manufacture date: 2003-12-16 (sanyo)
1st used date: 2004-02
Model: T41p
Cells: 9
Full charge: 59.27 Wh
Cycle count: 39
Manufacturer date: 2004-04-27 (sony)
1st used date: 2004-06
Cells: 9
Cycle count: 46
Model: T41p
Cells: 9
Cycle count: 39
ThinkPads
560 / 380z / T20 (2647-44G) + Dock II / R50p (1832-23G) with T42p mb now / T41p (2374-GGG) / T43 (2668-F9G) / R.I.P. T61p (6458-W1H) @ HD + Adv. Dock / X200t (7453-BH7)
smugiri
In the spirit of eating my own dog food, I run 4 deep discharge cycles to recalibrate the battery like IBM recommends. Here are the old/new numbers for comparison.smugiri wrote:Model of thinkpad: T40p
Number of cells: 9
First Used: 2005-03
Number of cells: 9
Full charge capacity: before recalibration -> 47.72Wh
after recalibration -> 52.56Wh
Number of charge cycles: before recalibration -> 139 cycles
after recalibration -> 143 cycles
First Used: 2005-03
So, I have an increase of approximately 7% from running 4 deep disharge cycles. Not bad in my opinion.
Steve
Esben
Re: Full charge capacity vs. Number of charge cycles.
Model of thinkpad: T42-2378FVU
Number of cells: 6 cells
Full charge capacity: 43.92 Wh
Number of charge cycles: 57
Number of months since the manufactured date: 14 months (2005-01-14)
Number of months since first use: 9 months (2005-06)
I mainly use the AC adaptor, only occasionally using battery.
The fan is turned off 99 % of the time I use the laptop, which causes the underside of the laptop to often be quite warm. It also has to do with surfing on a coach, legs or the bed.
I very much appreciate a battery loss of only 7.5% during the period I've had it. No battery recondition cycle has been done.
Lenovo Thinkpad X230,
i5-3320M | 8 GB DDR3-1600 | 256 GB Crucial M4 | 12.5" IPS | Windows 8 Pro
Full charge capacity: 47.60 Wh
Number of charge cycles: 29
Number of months since the manufactured date: 9 (2005-6-21)
Number of months since first use: 7 (2005-8)
I have deep discharged it a few times (maybe 4, to around 4%...that is a deep discharge, right?) and it seems to have held up pretty well.
underclocker
- moderator
Model: T40 (2373-8CU)
Cells: 6
Design Capacity.: 47.52 Wh
Full Charge: 45.38 Wh
Cycle Count: 35
Manufacturer Name: Sanyo
Manufacturer Date: 2004-10-05
First Used Date: 2004-12
Battery Name (FRU): 08K8193
Cells: 6
Cycle Count: 35
giasoldacastlar
Model: T42 (2373-4WG)
Cells: 6
Full Charge: 25.47 Wh
Cycle Count: 210
Manufacturer Date: 2004-09-10
First Used Date: 2004-09
Last (and only) reconditioning: 2006-11-10 at about 200 cycles. I deep discharged the battery several times while travelling and a few times on purpose after the recalibration. Finally, I always used the default charging thresholds (96% - 100%).
Cells: 6
Cycle Count: 210
T400 2765-D3D
T42 2373-4WG + additional 512 Mbyte + IBM 11a/b/g Wireless LAN Mini PCI Adapter II
underclocker
- moderator
Another T40 battery, came with used machine (not all my cycles!!!)
I wonder how many cycles a battery can take! This one still holds a charge for over an hour.
Model of Thinkpad: T40
Number of Cells: 6-cell
Design Capacity: 47.52Wh
Full Charge Capacity: 20.18Wh
Cycle Count: 683
Manufacturer Name: SANYO
Manufacture Date: 2004-06-28
First used Date: 2004-07
Battery Name (FRU Part Number): IBM-08K8193
Cycle Count: 683
Melvyn
Number of cells 9
Design capacity 77.76
Full charge capacity 68.80
Number of charge cycles 179
Manufactured date. 2005-07-19
First Use Date 2005-09
At max battery it reach 7 hours, low dim, and so on
At max performance it reach 4 hours.
I did buy it used in ebay.
Number of cells 9
Lenovo ThinkPad T60p 8741-A11:
Intel Core 2 Duo T7400 @2.16ghz, 3GB Ram, ATI Mobility FireGL V5250, HD 100gb @7200rpm
Old: ThinkPad T42 2373-M1U
Brand New Oem X230 Battery Losing Full Charge Capacity Fast!
by TheMagicT410 » Sat Feb 11, 2017 12:58 pm » in ThinkPad X230 and later Series - 5 Replies
- 826 Views
Last post by TheMagicT410
Sat Feb 25, 2017 3:04 pm
T61 Battery Has Greater Remaining Capacity Than Design Capacity?
by olex126 » Mon Feb 20, 2017 3:15 pm » in Thinkpad - General HARDWARE/SOFTWARE questions - 5 Replies
- 1238 Views
Last post by olex126
Mon Feb 20, 2017 9:11 pm
Any way to get the model number of a W530 from a provided UPC code/ number?
by crashnburn » Tue May 16, 2017 11:30 am » in GENERAL ThinkPad News/Comments & Questions - 2 Replies
- 136 Views
Last post by crashnburn
Tue May 16, 2017 3:16 pm
- 3 Replies
- 267 Views
Last post by Temetka
Wed Apr 12, 2017 1:28 am
