Full charge capacity vs. Number of charge cycles.
zaku
#91 Post by zaku » Sat Dec 30, 2006 2:42 pm
how do you guys keep the cycles so low even if it's a 2 years old battery??
even though most of the time i use ac power it increases its cycle once in a while (the most i've used is like >70%)
exactly at which level that it will add a cycle count to the battery??
IBM Thinkpad T43 - PM 1.86GHz
Sony VAIO FE - C2D 1.86GHz
tomh009
#92 Post by tomh009 » Sat Dec 30, 2006 3:05 pm
underclocker wrote:I wonder how many cycles a battery can take! This one still holds a charge for over an hour.
Model of Thinkpad: T40
Number of Cells: 6-cell
Design Capacity: 47.52Wh
Full Charge Capacity: 20.18Wh
Cycle Count: 683
Manufacturer Name: SANYO
Manufacture Date: 2004-06-28
First used Date: 2004-07
Battery Name (FRU Part Number): IBM-08K8193
These are all my cycles:
Model of Thinkpad: X31
Full Charge Capacity: 33.55Wh
Cycle Count: 706
Manufacturer Name: Panasonic
Manufacture Date: 2004-09-27
First used Date: 2005-02
Battery Name (FRU Part Number): IBM-08K8048
Not bad for 700+ cycles!
hiyel
#93 Post by hiyel » Sat Dec 30, 2006 5:19 pm
Model of Thinkpad: T43
Design Capacity: 51.83Wh
Full Charge Capacity: 46.81Wh
Cycle Count: 78
Manufacture Date: 2005-11-29
First used Date: 2005-12 (12 months old)
Total Wear: 5.02Wh in 12 months.
~3Wh of this happend in the first month when the start and stop charging percentages were at the default 100% level.
Then I started to play around with these numbers and after 2 months I set them to 90% and 94%.
Since then the wear is 2Wh in 11 months, i.e., 0.18Wh per month. Way better than 3 Wh per month with the default values.
For me, this means at least 2 hours of normal use charge even after two years from now.
T43 2686NAU (2.0GHz, 14" SXGA+) 1.25GB, Seagate 100GB 7200rpm, Bluetooth IV, and an annoying pulsating fan...
underclocker
moderator
moderator
#94 Post by underclocker » Sun Dec 31, 2006 4:29 pm
Not bad at all!!! You've posted the strongest battery numbers yet, fantastic.
700+ and not much loss, sweet!
schmaud
#95 Post by schmaud » Fri Jan 05, 2007 2:39 pm
T42 2373-fwg
Design: 47.52 Wh
Current: 32.47 Wh
cycles: 348
a bit less than 70%.. not to bad for more than 2 years.
r
wehugheog
#96 Post by wehugheog » Fri Jan 12, 2007 8:50 am
Model of thinkpad T40
Number of cells 6
Design capacity 47.52
Full charge capacity 7.82 :eek:
Number of charge cycles 446
Manufactured date. 2003-11-11
First Use Date 2004-01
Pretty low. It was good till about a month ago, then it went down very very fast. Well, I have 220Volt plug in my car and a new T60p otherwise I would have bought a new battery.
EDIT: T40 instead of T4
Live where you suitcase/backpack is and where you are happy for a couple of months!!!
T40 / T60p 2613CTO T61p WUXGA
Current location: EU
Mugrunty
#97 Post by Mugrunty » Sat Jan 13, 2007 1:19 am
Model of thinkpad T60
Number of cells 6
Design capacity 56.16
Full charge capacity 45.32
Number of charge cycles 37
Manufactured date. 2006-05-19
First Use Date 2006-08
Hi guys, I just wanted to know you think that my battery capacity has dropped way too much for the amount of use I have given it.
One day it just violently dropped from like 53 to 48 Wh, and has been going down slowly ever since. I've only done maybe 3 or 4 deep cycles just to see if maybe it was digital "memory".
You think it's a tad low???? thanks! :D
edit: I believe it is at about 80% of capacity right now.
T60 2GB RAM, ATI X1300, 14.1" XGA, T2300 1.66GHz, 80GB 5200rpm Fujitsu, DVD multi-recorder CD-RW, Windows Xp Professional.
X200t 4GB RAM, 12.1" Enhanced Multitouch WXGA, L9400 1.86GHz, 128GB SAMSUNG SSD (lenovo), Windows 7 professional 64-bit
Mugrunty
#98 Post by Mugrunty » Tue Jan 16, 2007 10:29 pm
anyone?? :( :D
dg
#99 Post by dg » Fri Jan 26, 2007 9:31 am
Following discussion in
http://forum.thinkpads.com/viewtopic.ph ... 707#239707
I temporarily put my T41 battery in a T42 to use its Battery MaxiMiser "Improve battery health" option.
Results
Before
Model of thinkpad T41
Number of cells 6
Design capacity 47.52Wh
Full charge capacity 38.53Wh 34.93
Number of charge cycles 140 141
Manufactured date 11-2004
First used date 12-2004(but bought 4-2005)
Manufacturer Sanyo
After
Full charge capacity 34.93
Number of charge cycles 141
So, quite a disappointing loss of capacity. I use it predominantly on mains. I think I'll wait a while before trying to recondition it again.
Looking at the other posts in this thread, I get the impression that Sony batteries last better than Sanyo (unless they explode/get recalled of course), and possibly Panasonic are best, if rare.
Danny
T61 (7664, T7500), 2.2GHz, 2GB, 100GB HDD, Intel GMA X3100, 14.1" WXGA, Win 7 Home Premium 32 Bit
T41 (2373-2FG), P-M 1.4GHz, 1.5GB, 40GB HDD, ATI Mobility Radeon 7500, 14.1" XGA, XP Pro
Talon88
~ Photo Attacher ~
#100 Post by Talon88 » Fri Jan 26, 2007 2:02 pm
This is mine, after 1 year 2 months of use.....!
Still like new......!
http://i3.tinypic.com/2a5ax4z.jpg
Moderator edit: Please read the forum posting rules about the size of embedded images and follow them in future!
~ Talon88 ~ IBM Z60t 14" WS ThinkPad ~
oskibear
#101 Post by oskibear » Fri Apr 20, 2007 2:19 pm
Model of thinkpad: X60s
Number of cells: 8
Design capacity: 74.88 Wh
Full charge capacity: 74.88 Wh
Number of charge cycles: 162
Number of months since the manufactured date: 15
Ogg
#102 Post by Ogg » Tue May 01, 2007 3:26 pm
Where is this Power Management thing that allows setting Charge and Discharge thresholds? I've looked all over my IBM Access menus and can't anywhere to make such a battery adjustment. I have Thinkpad Configuration v1.32.
T60 2008-CTO - 1.83GHz, 2.5GB RAM, 250GB
T40p 2373-AU4/G3U - 1.6GHz, 1.5GB RAM, 60GB 7200rpm
esquire
#103 Post by esquire » Wed May 02, 2007 11:23 am
Model of thinkpad: T42
SANYO
Number of cells: 6-cell
Design capacity: 47.52
Full charge capacity: 8.11 Wh
cycle count: 511 :twisted:
Manufacture date: 2004-06-22
First used date: 2004-07
Guess I'm doing something wrong....
Anyway, a new one is ordered and will be here in a week 8)
IBM Thinkpad T42 DXU
PetrVavrik
#104 Post by PetrVavrik » Wed May 02, 2007 11:35 am
Model of thinkpad: R60
Number of cells: 6
Design capacity: 56.16 Wh
Full charge capacity: 51.82 Wh
Number of charge cycles: 52
Number of months since the manufactured date: 12
ThinkPad T61 - T8300 2,4GHz, 2GB RAM, 160GB HD, 14,1" 1440x900, Intel 4965 a/g/n, DVDRW,Bluetooth 2.0, 6 cell SANYO battery, Fingerprint, Win XP
zahir
#105 Post by zahir » Thu May 03, 2007 11:27 am
Model of thinkpad: T60
Number of cells: 6
Full charge capacity: 56.16 Wh
Remaining capacity: 56.16
Manufacturer name: Sony
Manufacture date: 2007-03-06
First used date: 2007-05
Number of months since the manufactured date: 2
Just got it.... one question though, my battery is at 100% but it still says Charge completion time : 22 mins
Why?
IBM Addict
T60 - Core 2 Duo T7200(2.0 Ghz) | 2GB RAM | 80GB HDD | DVD-CDRW | 14.1" TFT | Bluetooth
R51 - Celeron M(1.3GHz) | 512 RAM | 40 GB HDD | DVD CD-RW | 14.1” TFT
bontistic
#106 Post by bontistic » Thu May 03, 2007 12:53 pm
Here are my digits:
Model of thinkpad :: R52
Manufacturer :: SANYO
Number of cells :: 6
Design capacity :: 51.84 Wh
Full charge capacity :: 47.62 Wh (91.86 %)
Number of charge cycles :: 9 :D
Manufactured date. 2005-02-22
First Use Date 2005-03 (25 months)
New User as of 9/25/2006
R52 :: Pentium M 780 2.26GHz :: 2GB PC2-5300 :: 80GB 5400RPM :: ATI X300 :: 15" SXGA+ :: Port Replicator II
T60p :: Core 2 Duo T7600 2.33GHz :: 2GB PC2-5300 :: 160GB 5400RPM :: ATI V5250 :: 15" UXGA :: 802.11n
losmeme
#107 Post by losmeme » Fri May 04, 2007 7:08 am
Model of thinkpad :: X31
Manufacturer :: Panasonic
Design capacity :: 47.52 Wh
Full charge capacity :: 40.12 Wh
Number of charge cycles :: 68 (58 when received used)
Manufactured date. 2004-06-09
First Use Date 2004-08
This is my second battery for my X31. When I purchased the X31 from IBM (refurbed) it came with a brand new battery, so that one is on the shelf for the time being. This used battery came with a MediaSlice I purchased off ebay last September. The auction stated Slice with CD Drive, but said nothing about including a battery! Great deal to get the Slice, CD AND battery for $50.
I really wish I could set thresholds on this X31.
T43 1.8 / 2GB / 60GB 7K100 X31 1.4GHz / 2GB / 60GB 7K100
T20 700MHz / 512MB / 40GB 570E 500MHz / 320 MB
570 366MHz / 64MB (x2) 755CV 100MHz 486 / 8MB / 540MB
Ogg
#108 Post by Ogg » Sun May 06, 2007 6:10 pm
Model of TP: T40p
Manufacturer: SONY
Number of cells: 9
Design capacity: 71.28 Wh
Full charge capacity: 66.65 Wh
Number of charge cycles: 177
Manufactured date: 2003-10-22
First Use Date: 2003-11
FirstTimer
#109 Post by FirstTimer » Tue May 08, 2007 10:11 pm
Model of TP: z61p
Manufacturer: SONY
Number of cells: 3
Design capacity: 29.16 Wh
Full charge capacity: 20.14 Wh
Number of charge cycles: 28
Manufactured date: 2007-01-19
First Use Date: 2007-02
This is the second ultrabay battery going dead on me.
Lenovo did replace the first one with similar full charge capacity after 10 cycles.
They did ask me to perform battery maintance before replacing it
Lenovo Z61P- Atheros ABGN
FirstTimer
#110 Post by FirstTimer » Sat May 12, 2007 4:13 pm
Model of TP: z61p
Manufacturer: SONY
Number of cells: 3
Full charge capacity: 18.80 Wh
Number of charge cycles: 33
frankiepankie
#111 Post by frankiepankie » Thu Jul 05, 2007 2:55 pm
Model of TP: T40
Manufacturer: SANYO
Number of cells: 6
Design capacity: 47.52 Wh
Full charge capacity: 24.35 Wh
Number of charge cycles: 110
Manufactured date: 2004-01-07
First Use Date: 2004-02
Pretty low, but after the 28th of July i am going to exchange this battery with a better one, if the seller still has better ones.
He said to me:
If the battery last shorter then 2:00, return it.
I am benching and doing test, to see if it is healthy enough to keep it.
Lenovo ThinkPad T410
KristianJ
Moderator1
Moderator1
#112 Post by KristianJ » Thu Jul 05, 2007 4:04 pm
Number of cells: 6
Full charge capacity: 43.10
Number of charge cycles: 25
manufactured date: 12/04 (Sanyo)
My backup battery:
Model of thinkpad: T40 (haven't used on T42 until just now when I checked the stats)
Number of cells: 6
Full charge capacity: 21.2
Number of charge cycles: 377
manufactured date: 3/2004 (Sanyo)
X220 4291-46M
HP Pavilion dv7-2109tx
SHoTTa35
#113 Post by SHoTTa35 » Thu Jul 05, 2007 5:21 pm
[censored] you guys are lucky with those 1yr + batteries that still hold 95% of their original charge. :cry: I have the following:
Number of cells: 6
Design capacity: 47.52Whr
Full charge capacity: 21.92Whr
Number of charge cycles: 38
manufactured date: 2004-11-01 (SONY)
First Used Date: 2005-03
I haven't had my TP for that long tho... oh well, i'll be searching for a new 6 Cell soon.
KristianJ
Moderator1
Moderator1
#114 Post by KristianJ » Thu Jul 05, 2007 7:54 pm
I'm just lucky that the previous owner hardly ever ran the T42 off battery! :D Thing is though, I regret not switching the battery in my old T40 (which had about 130 cycles) for the 377 cycle one, although the 377 cycle one does a fairly good job for its age and current capacity.
X220 4291-46M
TOMSrolla
#115 Post by TOMSrolla » Thu Jul 05, 2007 9:02 pm
Posted: Sun Dec 31, 2006 6:19 am Post subject:
Model of Thinkpad: T41p
Number of Cells: 9-cell
Design Capacity: 77.76Wh
Cycle Count: 26
Manufacture Date: 2006-12-15
First used Date: 2007-05
T60p-8741-4VU|2.33GHz Merom|4GB DDR2|500GB/7200+7K200 HDD|256mb FireGL V5250|15.4 WSXGA+|DVD-RAM|Thinkpad a/b/g/n+BT| NMB China KB|9-cell bat|Win7 Ultimate 64-bit
T41p-2373-GEM|1.8GHz Dothan|2GB RAM|7K100+5K120 HDD|128MB FireGL T2|14.1 SXGA+|DVD/CD-RW|IBM a/b/g+BT|NMB Thai KB|9-cell bat|WinXP PRO SP2
ntneko
#116 Post by ntneko » Fri Jul 06, 2007 8:29 am
Manufacturer name: Sanyo
Number of cells: 6
Full charge capacity: 53.42 Wh
Number of charge cycles: 45
Manufacture date: 2006-11-17
First used date: 2007-01
I've been reading here about how to make the battery last so I've set it to charge at 86% and stop at 90% :)
ThinkPad T60 2007-AA4/ Core Duo T2400 1.83GHz/ 2GB RAM/ 60GB 7200rpm HDD/ 15" IPS SXGA+ LCD/ 128MB ATI Radeon X1400/ WinXP Pro SP2
Only two things are infinite, the universe and human stupidity, and I'm not sure about the universe ~ Albert Einstein
AdaSch
#117 Post by AdaSch » Fri Jul 06, 2007 5:40 pm
Model of thinkpad: T43p
Manufacturer name: panasonic
Number of cells: 6 (from t43)
Design capacity: 51,83 Wh
Full charge capacity: 45,31 Wh
Number of charge cycles: 171
Manufacture date: 2006-03-23
First used date: 2006-05
W500 @ T9900, 7K750, 2GB ITM as TMP :twisted:
