Probably only one way to find out.Vypr wrote:Does the Recovery repair diskette program work with a USB flash drive?
Maybe you'll get lucky and someone that has tried that will post.
Ok, thanks.croooowe wrote:Vypr, your first question about the mucking with the MBR. I have partitioned a few Thinkpads and although several worked without incident but I would NOT recommned doing so without a way to fix it handy since the general failure rate is pretty high. Best two ways to fix it are the app previously mentioned or upgrading your RnR. Be sure to only resize the PRELOAD partition. As for the USB key made bootable, the app that is referenced previously will ask the user if they wish to change the drive letter so that gives hope, but as to whether it would be successful or not, I don't know yet.
so, first thing-if you have the recovery cd's, don't worry about mbr. it's worthless/useless whatever. the cd's will restore it.Vypr wrote:Is it possible to change the size of a partition without messing with the MBR? I'm also thinking about partitioning my hard drive, but still want to keep the functionality of the IBM service partition.
I don't see the option to restore mbr when using the recovery cds. Is it automaticly done?mamamia wrote:so, first thing-if you have the recovery cd's, don't worry about mbr. it's worthless/useless whatever. the cd's will restore it.
Ah ok. I'll just wait till I can find a way to boot the repair disk before I follow mamamia's method.croooowe wrote:Recovery discs will wipe your system and rebuild everything including the MBR. What I think mamaia was saying is that as long as you have your Recovery discs you at least have a safety net, a way to start over and try again.
I assume reinstalling RnR 3.0, which i have right now, will also fix the MBR as well?croooowe wrote:I use Partition Magic 8 and as I said it's hit or miss as to whether the MBR will be in tact at the end. The best success I've had is to resize the drive and then exit and then open it again and set partitions. Baby steps seem to work. Regardless, whenever you're done partitioning and formatting, if you have RnR 2.0 or older installed you can install the latest version, 3.0 from the web, and that will fix your MBR as well.
