(T42 vs T43) vs R52 & 14.1 vs 15. Purchase advice needed
(T42 vs T43) vs R52 vs....
T42 is better than T43
15
43%
T43 blazes everything else beneath it ('xcept T60 'course)
8
23%
R52 takes the least but gives best
3
9%
15 wins hands down against 14.1
2
6%
14.1 is the way to go
7
20%
Total votes: 35
bzzz
#31 Post by bzzz » Sat Mar 18, 2006 5:47 pm
christopher_wolf wrote: Mind taking a good, high quality recording, of both and comparing them to mine?
Probably. some day - T43 isn't mine.
christopher_wolf wrote: Mine has now been on battery for two hours and has hovered around 38-41 degrees with the fan at Level 1 without having to use the Fan Control Utility. :D
34-35C at level 1 and w/o the utility. I don't think claiming any hours makes any sense because it depends totally on settings and load. I can say the lower rate I reached is ~7.5W.
christopher_wolf wrote: Later, if you want I can measure and chart out the temperatures on my T43 and my friend's T42 and compare them again; I can guarantee there is little difference. After running them daily, they both feel lukewarm to the touch on the bottom.
well, on that T43 I never seen CPU temperature lower than 41C.
I'm not an expert, actually. Probably there are bad and good T43s and T42s. I'm just describing my impression.
