Yes, but that involves getting the floppy disk drive accessory from IBM, even more stuff?pae77 wrote:If you happen to have a floppy disc drive and a cable adapter so you can connect the floppy drive to the TP without using the ultrabay, the EZ Gig software on the floppy that Lenovo ships with 2nd HD adapter works great and is simpler & easier to use than most other programs for cloning. (I use Acronis TI as well so I know of what I speak, but Acronis is more flexible with more options and features.) Anyway, no dos or OS is required for EZ Gig. You simply boot from the EZ Gig floppy with the target hard drive in the ultrabay, hit two or three keys and the cloning begins. I find it very convenient for routinely backing up my entire hard drive to a drive I can just swap into the primary slot if ever needed.
The EZ Gig floppy only has 10 licenses (will only clone 10 different drives) though. Still I think it's pretty nice they throw it in as a free extra with the 2nd HD adapter.
I tried it out and it is pretty nice.
