Anyone else with a T60 that won't resume from standby?
I don't know if this helps, or if anyone experiences this, but I noticed on my X41 that when I standby for an extended period with Firefox window(s)(tabs) open when I go into standby, I have trouble recovering from standby using the Fn key, and I also have to use the Fn spacebar to activate the screen once it finally wakes up with a blank dark screen. However if I standby with noFirefox windows open before I stand-by, recovery from standby is immediate and normal and the screen comes up with backlight on. This happens on three different X series laptops.
H Fawaz
DHL Enterprises, Inc.
"Solutions On The Cutting Edge"
laundromatt
I had thought that I was past this problem of screen won't come on after PM timeout, but it's baaack. Fn+F7 doesn't work in my case only Fn+F4, but this scales all of my active CAD windows down and they have to be manually resized individually when I access them. Major PITA.
I use FireFox/Thunderbird, so I'll go a day without using either to see if they're potential culprits.
I have noticed, though, that when my machine refuses to suspend on cover close or even when using Fn + F4 that the Windows Start>Shutdown>StandBy sequence still works.
After a failed standby attempt do a windows shutdown. My machine goes through the shutdown process to a certain point, but at that point it kills some process then goes into standby. When I resume from standby it completes the shutdown.
I just don't know what process is causing the problem. I don't recall ever experiencing a problem without a fix for this long on any previous T'Pad system. It's quite disappointing.
T'Pad 600e, 770x, A20p, A21p, A30p, A31p (2653-H3U), T43p (2668-Q2U) & T60p (2623-DDU)...it's an addiction.
It was supposedly a Windows Update http://support.microsoft.com/kb/917332/en-us that did the trick for some.
The monitor does not turn on when you move the mouse or press any key after you configure the "Power Options" settings on a Windows XP SP2-based portable computer
I haven't installed it yet, but I haven't seen this issue since my last go round with System Updater.
That's the one. From the description:
-darren
Couldn't be more bang on. Has fixed it for me. Thanks for the link Scratch.Consider the following scenario. You have a Microsoft Windows XP Service Pack 2 (SP2)-based portable computer that uses a dual-core processor or that uses an Intel Pentium 4 Processor that supports hyper-threading technology (HT Technology). You use Power Options in Control Panel to configure the computer to enter a standby or a hibernation state when you close the lid. You also configure the computer to turn off the monitor after a period of inactivity.
In this scenario, the computer correctly enters a standby or a hibernation state after you close the lid, and then the computer correctly resumes activity when you reopen the lid. Also, the monitor turns off correctly after the period of inactivity that you specify. However, the monitor does not turn on again when you move the mouse or press any key.
-darren
http://hf.xable.net/
I too was wondering how to get it. The above site came up in a google search. Looks to be pretty useful for getting hotfixes which aren't publicly released.
cheers!
cheers!
My 2nd Advanced Dock went bad. No serial or USB ports working. No resume from standby. It took 6 weeks for the 3rd one to arrive, but it's the latest FRU and supposedly fixes everything. See the link:
http://www-307.ibm.com/pc/support/site. ... MIGR-65164
I can now resume from standby or hibernation. Cool. For the sencond time, I hope it lasts.
Jon
Jon
Jon
I have 2 week old T60 and I had the very same problem - I left the system unatteded for 1 hr and it was just blank. It was powered on, and I could not get it back to activity at all - no key combinations including Ctrl-Alt-Del worked. I had to unplug the power and remove the battery and restart the machine
Rules of the road
Rules of the road
Success. Thanks for the answer. Unfortunately I was using an old image that didn't already have the correct HAL in there. For that I referenced:kai jiang wrote:This problem was caused by the ACPI mode,you can change it to "ACPI Multi Processor"mode in system property.The old configuration can't assigned enough "IRQ" to Multi processor system.I fixed this problem by this method on my T60.
http://blog.case.edu/djc6/2005/09/22/im ... s_wsysprep
I had to pull out an old XP Pro CD lying around the office and I used the snippet contained in the link:
expand HALMACPI.DL_ C:\Windows\System32\HAL.DLL
expand NTKRNLMP.EX_ C:\Windows\System32\NTOSKRNL.EXE
expand NTKRPAMP.EX_ C:\Windows\System32\NTKRNLPA.EXE
Oh, and I forgot to mention that I got a 0x7e error on the reboot. So then I proceeded to reboot into Safe Mode until the kernel completed its reinstall.ringonian wrote:Success. Thanks for the answer. Unfortunately I was using an old image that didn't already have the correct HAL in there. For that I referenced:kai jiang wrote:This problem was caused by the ACPI mode,you can change it to "ACPI Multi Processor"mode in system property.The old configuration can't assigned enough "IRQ" to Multi processor system.I fixed this problem by this method on my T60.
Replacement for X220: X260 or E470? Or something else?
by awebber » Sat Jan 07, 2017 11:48 am » in ThinkPad X230 and later Series - 13 Replies
- 1310 Views
Last post by mj0
Thu Jan 12, 2017 7:20 pm
How to Wake Up External LCD after Waking Up from Standby - T61?
by EAkamai » Thu Mar 02, 2017 6:10 pm » in ThinkPad T6x Series - 1 Replies
- 666 Views
Last post by EAkamai
Fri Mar 03, 2017 2:46 pm
Anyone interested in buying LED mod for T60 (from xiphmont) in the UK?
by zoltan87 » Mon May 01, 2017 6:36 pm » in ThinkPad T6x Series - 1 Replies
- 579 Views
Last post by zoltan87
Tue May 09, 2017 4:02 pm
New message notification won't go away
by dandreye » Thu Dec 29, 2016 1:52 pm » in ** HOW TOs & FAQs ** - 6 Replies
- 1776 Views
Last post by dandreye
Fri Dec 30, 2016 4:09 am
