It seems that x60/s is not a popular machine
domi
Contributing Member
Contributing Member
#31 Post by domi » Sun Apr 16, 2006 3:48 am
pianowizard wrote:At present, the lightest X-series notebook available on lenovo.com is an X40, which is 2.7 - 2.78 lbs. My guess is that this is to encourage people to buy the X40, and when it's sold out, Lenovo will then start selling the lightest X60s models, which should be as light as 2.69 lbs.
Do you mean that Lenovo currently sells X60/X60s with "heavy" batteries on purpose? I've been wondering why most models found in tabook.pdf include the high capacity 8-cell battery (40Y7003), only a few include the enhanced capacity 4-cell battery (40Y7001) and none include the slim line 4-cell battery (40Y6999), which should be the lightest of all.
X301 (2776-3JG) | Core2 Duo U9400 1.4 GHz | 8GB | 128GB SSD | Win 7 Pro
CalBioEngr
User with bad email address, PLEASE fix!
#32 Post by CalBioEngr » Wed Apr 19, 2006 4:29 pm
I ordered a slim battery (40Y6999) for my x60s last week. I will report back if I feel there is any reason why Lenovo went with the bulkier battery for most of the x60 models.
currently, my battery is being held at customs... :roll:
"PACKAGE WAS DELAYED BY A FOOD AND DRUG ADMINISTRATION HOLD. "
When did batteries became food and/or durg?
trentblase
Re: No clicking...
#33 Post by trentblase » Thu Apr 20, 2006 12:27 pm
christopher_wolf wrote:
Zeitgeist wrote: DVI!
:lol: I think I will say that is the only other port I could want on a Thinkpad, but I will draw the line at putting in a digital audio port; that should probably stay on the docking station. :)
I was under the impression that the X60 did have an optical out. I haven't found any verification, but the startup folder contains something called "digital audio detector" or something like that.
Thinkpad X60s 1702-3QU
All system updates installed
Gee
Re: No clicking...
#34 Post by Gee » Thu Apr 20, 2006 4:11 pm
domi wrote:
ajwells wrote:No clicking at all from the X60... I have the 100GB disc and its completely silent and clickless...
What is the manufacturer of the 100GB drive found in the X60?
Lenovo is using Toshiba drives in the current generation. IBM always used Hitachi because they sold their hard drive division to them and probably had a working arrangement for parts.
christopher_wolf
Special Member
Re: No clicking...
#35 Post by christopher_wolf » Thu Apr 20, 2006 6:27 pm
Gee wrote:
domi wrote: What is the manufacturer of the 100GB drive found in the X60?
Wait, weren't some, if not a good majority of the drives in the X4X Series, made by Toshiba?
~o/
She does the things you do.
But she is an IBM.
pdudas
Re: No clicking...
#36 Post by pdudas » Fri Apr 21, 2006 4:55 am
trentblase wrote:
christopher_wolf wrote: :lol: I think I will say that is the only other port I could want on a Thinkpad, but I will draw the line at putting in a digital audio port; that should probably stay on the docking station. :)
Digital line detector is not the digital output you want.
This is for the detection of the digital line (ISDN) because the builtin modem is analog and cannot use the digital line.
amgdoc
#37 Post by amgdoc » Fri Apr 21, 2006 6:02 am
pianowizard wrote:
amgdoc wrote:You could buy the lightest since Feb. The X60s is on there, just need to click on 'view all models' in the x-series section.
The lightest X60s listed on lenovo.com is 3.0 lbs, quite a bit heavier than the 2.75-lb X40. The 2.69-lb X60s that Lenovo promised is not yet available in the States.
If you buy the x60s now with the 'slim' battery (4-cell prismatic), it will be 2.7-2.8 lbs, the lightest weight possible. However, the 3.0 lbs that you see on the internet is the 'standard' battery (4-cell cylindracil) or the 8-cell cylindracil that gives the x60s a weight of about 3.2 lbs. All depends on the battery, that is the weight factor, but I believe the HD options might also be the cause of the increase in weight (cannot order something less than 60GB, though I am not sure how much a 40GB HD compares weight wise).
The only thing you cannot order currently with the x60s is the L2300 processor (which is slower than the L2400 just a tad) and I believe the UXGA screen (?). Weight wise I think those do not play a major factor.
Lenovo is offering us the lightest. It all depends on what options you choose, which for now is the battery (something luckily that is changeable after purchase as well)
thinkpad x40, type:2372-9EU, (2x) 512MB, 40GB HD (4200rpm), 802.11abg, CDC bluetooth
thinkpad x60s, type:1702-94U, (2X) 512MB, 40GB HD (5400rpm), 802.11abg, Ultralight LCD.
amgdoc
#38 Post by amgdoc » Fri Apr 21, 2006 6:05 am
Well, at least they give us the option of ordering it with the slim. I'm sure they have their reasons. I have no idea what the performance between a 4-cell prismatic vs. a 4-cell cylindracil battery is. The former is lighter though for sure.
pdudas
#39 Post by pdudas » Fri Apr 21, 2006 7:35 am
I dont see why somebody wants to order the lightest battery!
It is not smaller than the normal, there is only a weight and capacity difference.
http://www-307.ibm.com/pc/support/site. ... MIGR-62402
http://www5.pc.ibm.com/uk/products.nsf/ ... enDocument
The slim battery is 0.2kg. 2.0Ah
The extended is 0.26kg. 2.6Ah
The 8cell battery is 0.48kg. 5.2Ah
I dont see how somebody able to buy a smaller battery for 60 gramms of weight saving!!!!
My X60 is below 1.6kg with the 8 cell battery, and below 1.4kg with the extended 4 cell battery.
I think the 8 cell battery has the better capacity/weigt index.....
amgdoc
#40 Post by amgdoc » Fri Apr 21, 2006 8:58 am
i'm most likely going with what lenovo has as standard (the 4-cell cylandrical).
You are right about the small weight difference, it really is not that big of a deal. My point was the lightest x60s is on the US market but you have to customize it with lighter items to get it the lightest (which in the end will not be a big difference in comparison with a 3 lbs x60s standard).
RS_003
#41 Post by RS_003 » Fri Apr 21, 2006 10:38 am
amgdoc wrote:
pianowizard wrote: The lightest X60s listed on lenovo.com is 3.0 lbs, quite a bit heavier than the 2.75-lb X40. The 2.69-lb X60s that Lenovo promised is not yet available in the States.
UXGA ??? On a 12" ?
Maybe SXGA, but UXGA? No way :) (not that I dont want it, but afaik there are no 12" UXGA screens)
Own:
X61t
Owned:
X41, X31, T41, T42, X40, X61s
Yes... I love the X-series.
#42 Post by pianowizard » Fri Apr 21, 2006 12:37 pm
amgdoc wrote:You are right about the small weight difference, it really is not that big of a deal. My point was the lightest x60s is on the US market but you have to customize it with lighter items to get it the lightest (which in the end will not be a big difference in comparison with a 3 lbs x60s standard).
The difference between the slim and the standard batteries is only 0.06 kg or 0.13 lbs. The lightest X60s listed on lenovo.com is 3.0 lbs with standard battery, so switching to the slim version would make it 2.87 lbs, which is still 0.18 lbs heavier than the 2.69-lb model that Lenovo said would be available.
CalBioEngr
#43 Post by CalBioEngr » Fri Apr 21, 2006 12:55 pm
I finally got my 4 cell slim battery. I got the slim cell because of the fact that it's flush fit and doesn't have the bumps on the bottom. I know the standard battery is only slightly heavier but I ordered the x60s instead of the x60 mainly for the size, so I want my thinkpad to look nice and thin. If I need the extra battery life, I always have the 8 cell as backup.
#44 Post by pianowizard » Fri Apr 21, 2006 1:25 pm
amgdoc wrote:The only thing you cannot order currently with the x60s is the L2300 processor (which is slower than the L2400 just a tad) and I believe the UXGA screen (?). Weight wise I think those do not play a major factor.
For the X20, the XGA models have much thicker display lids than the SVGA models, making the former about 0.3 lbs heavier. So, an X60s with a UXGA screen will most likely weigh more than the currently available ones.
amgdoc
#45 Post by amgdoc » Fri Apr 21, 2006 3:43 pm
Oops. I should not have put UXGA. I meant the U as Ultralight not Ultra Extended GA. Sorry. Regardless of the U meaning Ultralight, the X60s with the Ultralight XGA is heavier :shock: according to lenovo's literature:
Travel weight
12.1" XGA:
1.22kg/2.69 lb (4-cell prismatic)
1.27kg/2.80 lb (4-cell cylindrical)
1.48kg/3.26 lb (8-cell cylindrical)
12.1" UltraLight XGA:
1.31kg/2.89 lb (4-cell prismatic)
1.36kg/3.00 lb (4-cell cylindrical)
1.57kg/3.46 lb (8-cell cylindrical)
Pianowizard is correct, we are missing the other machine types. However, if you call them they can find one for you. I know the L2300 processor ($300 cheaper than L2400) is not online to order, but when I called they had a couple available. When I call them next week to order mine I will ask about the 'others'. :?
CHoPSTICK89
#46 Post by CHoPSTICK89 » Fri Apr 21, 2006 3:59 pm
amgdoc wrote:Oops. I should not have put UXGA. I meant the U as Ultralight not Ultra Extended GA. Sorry. Regardless of the U meaning Ultralight, the X60s with the Ultralight XGA is heavier :shock: according to lenovo's literature:
Travel weight
12.1" XGA:
The UltraLight model is 2.69lbs [look on tabook.pdf]. It is avaliable to order, I got it about a week ago.
RS_003
#47 Post by RS_003 » Sat Apr 22, 2006 11:37 am
Can you compare the Ultralight screen to a normal screen?
And / or post pictures here.
Because I would really like to see the change in brightnes :)
Own:
X61t
Owned:
pdudas
#48 Post by pdudas » Sat Apr 22, 2006 2:00 pm
Which model has ultrabright screen?
Model no?
sugo
#49 Post by sugo » Sat Apr 22, 2006 3:19 pm
The downside of UltraLight screen is absence of internal bluetooth.
X61
CHoPSTICK89
#50 Post by CHoPSTICK89 » Sat Apr 22, 2006 6:49 pm
RS_003 wrote:Can you compare the Ultralight screen to a normal screen?
I bought both an X60 and X60s. I ended up keeping the X60s (sold the X60) because of the Ultralight screen. I personally found it alot brighter, the whites are so white it starts to hurt the eyes.
But beware, the X60 screen has what it seems a harder backing, (meaning less flexing) screen than the Ultralight. Both are hard enough that you can't push enough to distort display. It just seems to be a different material inside.
The Ultralight though is really light compared to the X60 I had (3.1lbs).
http://plaza.ufl.edu/riceboy5/IMG_2375.JPG
http://plaza.ufl.edu/riceboy5/IMG_2376.JPG
http://plaza.ufl.edu/riceboy5/IMG_2383.JPG
http://plaza.ufl.edu/riceboy5/IMG_2384.JPG
I just picked a picture online to show a representation.
X60 on Left X60s on Right
*all pictures are with no flash
And the 19" is a Samsung 914v just used to compare
RS_003
#51 Post by RS_003 » Sun Apr 23, 2006 9:24 am
Thank you so much :)
Those pictures really helped me :)
Now I just need to get an UltraLight screen :)
To bad they are not for sale in the EU afaik :( :oops:
Own:
X61t
Owned:
pdudas
#52 Post by pdudas » Sun Apr 23, 2006 10:17 am
Model No PLEASE!
sugo
#53 Post by sugo » Sun Apr 23, 2006 10:24 am
pdudas wrote:Model No PLEASE!
Just download tabook. Link is in FAQ forum.
X61
amgdoc
#54 Post by amgdoc » Mon Apr 24, 2006 12:37 pm
sugo wrote:The downside of UltraLight screen is absence of internal bluetooth.
Well, that is sad. Anyway it could be add on later (with e.g., a CDC bluetooth/modem chip?) or something else that makes it better intergrated in the notebook. i hate usb dongles and pc-cards bt.
trentblase
#55 Post by trentblase » Tue Apr 25, 2006 6:16 pm
1702-94U is the only Ultralight model, right? I don't see this online. How did you order yours? Call them up and beg? I got a different 1702, but I still have my 30 days to return it if I can snap up a 94U!
DavidNZ
#56 Post by DavidNZ » Wed Apr 26, 2006 1:18 pm
Thanks for posting the pics. I think the straight XGA screen would be fine for my needs if I ever decide to get an X60, and would save a slight amount of weight. Dunno. Have never really played with a U-XGA screen before so I might change my mind...
X40 (2371-6EM) w/ 768 RAM
XPP SP2
DLINK DI-614+
amgdoc
#57 Post by amgdoc » Thu Apr 27, 2006 8:01 am
I just ordered the 1702-94U.
RS_003
#58 Post by RS_003 » Thu Apr 27, 2006 5:08 pm
Or for sale in the EU?
Own:
X61t
Owned:
thibouille27
#59 Post by thibouille27 » Sun Apr 30, 2006 11:17 am
RS_003 wrote:Or for sale in the EU?
If you are student/teacher then you can get one in Switzerland at a stupid price but not in stock.
MOD EDIT: Just to nip things in the bud, please be sure not to go into any detail regarding the Educational Pricing, per forum rules.
EDIT: OK, won't do it again, promise :oops:
amgdoc
#60 Post by amgdoc » Tue May 02, 2006 7:01 pm
I know we cannot discuss in detail educational pricing, but many institutions do not have any deals still with the X60/s. However, you can still get a 'student' discount if you ask the sales rep. They gave me one on my 1702-94U
