T43 fan problem is gone!
holr
#31 Post by holr » Sat Mar 25, 2006 7:33 am
dino wrote:I already searched the ftp directory and its not there.
ftp://ftp.software.ibm.com/pc/pccbbs/allfiles.txt contains a listing of all the files in the pccbbs subdirectories.
Hmm, im not sure how good that text file is, I found (from a backup CD) the old driver for the ati card, namely 8.082.2-041211m-019929C-IBM, filename 1yd132ww.exe, which you cannot find a mention of on the ibm website. thanks to google's cache however, i found:
http://72.14.203.104/search?q=cache:LKL ... ient=opera
which gave me downloadable links to these old files. I tried checking the text file mentioned for these drivers, and the search came up with nothing. My guess is ibm is hiding stuff there?
Zeitgeist
#32 Post by Zeitgeist » Sat Mar 25, 2006 8:39 am
holr wrote: I tried checking the text file mentioned for these drivers, and the search came up with nothing. My guess is ibm is hiding stuff there?
I could not only downoad the .exe file but also the .txt. Do you want me to post it?
Regards, Zeitgeist
hiyel
#33 Post by hiyel » Sat Mar 25, 2006 11:40 am
I just realized that this version of the driver is the one that was installed on my TP when I first got it. And I had the fan issue at that time as well. So I'm not going to bother installing an old driver, at least until I get another confirmation of this fix from you guys.
Zeitgeist:
I think what Holr meant was, although this driver and its info webpage still resides on the server, it doesn't show up on the file that Dino mentioned:
ftp://ftp.software.ibm.com/pc/pccbbs/allfiles.txt which is supposed to contain a listing of all the files in the pccbbs subdirectories.
T43 2686NAU (2.0GHz, 14" SXGA+) 1.25GB, Seagate 100GB 7200rpm, Bluetooth IV, and an annoying pulsating fan...
holr
#34 Post by holr » Sun Mar 26, 2006 1:57 pm
hehe thanks hiyel ;-) just wondering, could you possibly post a copy of the old driver you had, so that some of us others could have a tinker and see what happens? Im currently running from the set previous, the ones I mentioned earlier, Id like to have the 1.33 version to run a comparison against.
hiyel
#35 Post by hiyel » Sun Mar 26, 2006 11:40 pm
Sorry Holr, I don't have the executable, it just appears on my Software Update's list. I deleted the content of IBMTOOLS and DRIVERS folders (to save space) except the xml files (to be able to use Software Update). I think we should ask Tungo or Christopher, but they haven't been interested in this thread for a while.
christopher_wolf
Special Member
#36 Post by christopher_wolf » Mon Mar 27, 2006 12:45 am
Mmmmm? I have been searching for the *.exe file on my Thinkpad for awhile now...No luck :(
I have gone through most of the IBM update folders and I can't seem to be able to find it.
Anymore ideas as to where I could look for it?
~o/
She does the things you do.
But she is an IBM.
hiyel
#37 Post by hiyel » Mon Mar 27, 2006 10:42 am
According to my xml file, the name of the executable is 1YD135WW.exe.
Maybe that helps.
davidspalding
#38 Post by davidspalding » Mon Mar 27, 2006 1:17 pm
I suspect that if you had it, the setup files would be in c:\drivers\1YD135WW or similar. Might be called 1YD135WW.exe.
Seems IBM downloads the bundled .EXE, then expands it to the \drivers and \ibmshare folders. The install folder includes a SETUP.EXE, not ########.exe
Tungo
#39 Post by Tungo » Mon Mar 27, 2006 2:47 pm
Hello Guys,
Sorry, Just got back from spring break with the wife and kids. It's only right for me to put the file for you guys to download and try since I'm the one that start this thread. Remember that its may or may not work out for your case because I think that the driver is hardware dependent also. But you got not think to loose. Hope this helps.
Here is my ftp address, username and password. I have dynamic address so hurry before it change.
ftp://70.246.151.152
username: thinkpad
password: atidriver
Tung
T43 2668-92U, 760 2Ghz, 15" SXGA+ IPS, 1.5GB
T22 2647-8CU 14.1", 512MB
Tungo
#40 Post by Tungo » Mon Mar 27, 2006 2:54 pm
Sorry, I clik the Submit to soon. There are two file for the download, so I do not know which one is version 8.133..... I make these backup right after i got the T43. So you have to try them out.
Tung
Cache
8.133 Version
#41 Post by Cache » Mon Mar 27, 2006 8:27 pm
Just to let everyone know, the 8.133 driver is contained in the file Tungo hosted named VIDEO.rar .
Thanks Tungo for getting us access to this!
Tungo
#42 Post by Tungo » Mon Mar 27, 2006 10:03 pm
you're welcome Cache. I hope that it works for you as my T43.
Tungo
simms
#43 Post by simms » Mon Mar 27, 2006 10:31 pm
When I get this I'll also upload it to my site as well.
xblomx
#44 Post by xblomx » Mon Apr 17, 2006 4:43 pm
Could anyone supply me with the beforementioned driver version?
Thanks and regards
xblomx
xblomx
thinkpad4ever
#45 Post by thinkpad4ever » Mon Apr 17, 2006 10:09 pm
I'm too bafflled with this high temp and noisy fan to mostly T43 owners posting on this site. I got my T43 two months ago and i have no problem concerning on high temp. and noisy fan. right now it's barely warm at the bottom while the fan is in idle. and it's always like that eversince. about a month ago there was these software installer was offered from IBM together with a bunch of driver updates including bios update, i did update and upgrade drivers much of them but i skipped on ATI's. so far my only problem on my T43 is this ultranav red button in the middle of the keyboard it snags my finger most of the time while typing.
T43 2687D3U
techflavor
#46 Post by techflavor » Mon Apr 17, 2006 10:23 pm
For whoever was able to download the file from Tungo's ftp mind reposting the file for others?
If someone sends the file to me I will put it on a permanent host.
gunston
#47 Post by gunston » Tue Apr 18, 2006 10:12 am
hey i need that drive to test it out too.
anyone have that version of ATI driver?
2. X60s 1703-CA3 powerful
gunston
#48 Post by gunston » Wed Apr 19, 2006 9:14 am
Tungo wrote:Hello Guys,
username: thinkpad
password: atidriver
Tung
hey did your ftp still workable for me to download that version of ATI driver???
Eriol
#49 Post by Eriol » Tue Apr 25, 2006 6:45 pm
davidspalding wrote:I'm confused ... you need a specific sub-release of 8.133?
Driver v. 8.133.2-050525a-024243C 8/11/2005:
http://www-306.ibm.com/pc/support/site. ... MIGR-41918
FYI, that link is not for T43 laptops.
I discovered that I have the old video drivers in question, as a directory in the original factory install (it has all the files, but it doesn't follow the 1wXXXX.exe convention). Zipping it up with winzip produces a 32 MB file, which is bigger than Briefcase Yahoo. If someone wants to point me to a host service or anonymous FTP server, I can upload this zipfile.
Now, before any of you celebrate, I uninstalled the latest driver and reinstalled this, and it doesn't quiet my fan. There is no perceivable change to fan noise. Maybe my model is unlucky. Otherwise, I probably have to try atitool, but I'll need settings information.
My CPU is between 45C and 49C, according to NHC. The fan makes a low hum, but it is not near-silent. Is this normal?
T43 2686M5U
gunston
#50 Post by gunston » Wed Apr 26, 2006 4:08 am
please post the zip file for me to download.
thanks.
Eriol
#51 Post by Eriol » Wed Apr 26, 2006 7:44 am
gunston wrote: please post the zip file for me to download.
thanks.
I can't. This forum doesn't allow attachments.
T43 2686M5U
davidspalding
#52 Post by davidspalding » Wed Apr 26, 2006 1:22 pm
Not 32MB ones, surely. :shock:
Eriol
#53 Post by Eriol » Wed Apr 26, 2006 6:04 pm
davidspalding wrote:Not 32MB ones, surely. :shock:
Well that too. I can't do anything about the filesize. The installation files were already uncompressed.
T43 2686M5U
gunston
#54 Post by gunston » Wed Apr 26, 2006 6:06 pm
i thought you will be compressing it and post it in yahoo briefcase??
nimativ
#55 Post by nimativ » Thu Apr 27, 2006 5:05 am
how difficult is it to upload it to somewhere like rapidshare.de
nimativ
#56 Post by nimativ » Thu Apr 27, 2006 5:07 am
thanks.
upload the file here please and then just post the link.
http://rapidshare.de/
gunston
#57 Post by gunston » Thu Apr 27, 2006 9:36 am
looks like this driver version is very demanding, and everyone is eager and curious to test it out whether or not it does help to decrease the temp.
so, please kindly post it with the link given above and share it with us all
Countless Thanks.
Eriol
#58 Post by Eriol » Fri Apr 28, 2006 9:03 pm
Don't get upset nimativ. Not everybody knows the places to upload files. Thanks for pointing me that way.
To those who need the drivers, try this link from Rapidshare.de:
http://rapidshare.de/files/19172778/atidrivers.zip.html
Good luck.
T43 2686M5U
gunston
#59 Post by gunston » Fri Apr 28, 2006 9:21 pm
http://beta.yousendit.com/
you may upload your driver to this link.
more user friendly and i can download it with my download manager. :idea:
Eriol
#60 Post by Eriol » Fri Apr 28, 2006 9:39 pm
gunston wrote:http://beta.yousendit.com/
You send it requires an email address of the recipient?...I am making this available to everybody, so I don't think it makes much sense to do this.
Please get it from Rapidshare, if you need it, gunston.
T43 2686M5U
