T60 - Fresh install of XP
QUESTION ABOUT RELOAD
questions:
1) If I reload, can I then download the software loader from IBM and reload all the IBM specific software? Will it recognize my machine, and down load the drivers etc. or will have to do that one by one ... and I assume risk messing it up?
2) when I do a fresh load, how do I make sure that it does not formate the IBM backup partition in case I need it?
3) I have made a back of the drive with True Image... I assume that if I mess up I can just run a recovery cd and reinstall that ...
I have a T60 2007 63G with German software that I am trying to get into English ... the result of a major misunderstanding when I bought the machine and IBM has not been very helpful so far
Steve
Thanks serpico. I'll check the device manager.
Okay now I'm having another problem (perhaps related to the first?). I installed the hotfix for the audio, but the software installer still doesn't recognize any audio drivers to install. And there are a number of drivers (TPM, PCMCIA, Network) that I install, the software installer says the installation has finished fine, and then when I reboot the software installer shows that these drivers aren't installed.
Maybe there's something messed up with the slipstreamed windows cd I made? Hmm.
Cassirer, in response to 2. If you DO NOT disable the predesktop area in the BIOS, then it won't be reformatted. When you run the windows installer, you will have an option just to reformat c: and install XP to your reformatted c: partition. (Perhaps this is true even if you do disable the predesktop are. Not sure.)
I didn't use the installer to install the audio drivers. I ran c:\drivers\win\audio\setup.exe. This will install the SoundMax drivers.donking! wrote:Thanks serpico. I'll check the device manager.
<snip>
Not sure why you are having problems with the other drivers. As you note, maybe it's related to the Intel chipset support files? Were you able to re-install these or otherwise confirm that they have been installed?
T430: i5-3320M(2.6GHz), 8GB RAM, 120GB SSD, 14" 1600x900, NVIDIA NVS 5400M 1GB
W510: i7-720QM(1.6GHz), 8GB RAM, 240GB SSD, 15.6" 1600x900, 1GB nVIDIA Quadro FX 880M
T410s: Core i5 2.53GHz, 8GB RAM, 120GB SSD, 14.1" 1440x900
T60
X60
T60
X60
Thanks again serpico. It looks like the system drivers are installed. And the TPM driver is also installed (though it shows as not installed in the software installer).
Alas, I think I'm going to go back to the factory install and try to optimize performance from there. I'm not feeling very confident about my deployment of the clean install process at the moment. And I haven't even used the computer for anything yet!
I may take up the clean install effort again another time.
Thanks for all the help. I learned a lot in the process.
I don't think you're losing much by not doing the clean install. Just uninstall the stuff you don't want and make sure to use msconfig to check on all the processes that load at startup and remove those that you don't need.donking! wrote:Thanks again serpico. It looks like the system drivers are installed. And the TPM driver is also installed (though it shows as not installed in the software installer).
After all, you bought the laptop as a means to an end rather than as an end in itself.
One note though - if you think you might attempt a clean install in the relatively near future, try to limit the number of applications you install as well as the number of customized settings you configure for Windows and for apps. Obviously you would have to redo all of these if you do a clean install and I think this is more time consuming than the clean install of XP itself. Or you could note down all your customized settings as you make them.
T60
X60
T60
X60
misfit
Re:
Ok, I know that I'm replying to a really old question but I've just discovered something myself and, after reading this thought I'd share...meanestfish wrote:Have you found yourself able to make recovery disks? Mine does a fatal error even after a complete factory reset.
I've never been able to write recovery disks before and have variously put it down to HDD bad sectors, malware and perhaps the disks having been written before. (I've never been fortunate enough to own a new TP, I only 'discovered' them in 2008 and by then I was only interested in discontinued models.)
Anyway, I was trying to write recovery disks for my latest acquisition (a 2374-M97 T42) the other day and, after getting several messages like "couldn't read xxxxx" or "Bad data at xxxx" for some reason I decided to try to write them with the anti-virus (Avast!) turned off. Well! It worked perfectly so I got out my T41 (and it's original HDD that was 'in storage') that I'd not been able to write disks for before and yet again, by turning off the AV I was able to get the disk-set written with no trouble.
I've never seen this 'tip' mentioned before (haven't really looked TBH) but thought that it might be worth sharing.... Now I'm *really* wishing I hadn't deleted the factory partition of my T60/s after failing to write disks.
Shaun.
T60 2007-72U [T7400, UXGA FV]
T43p 2668-H2M [FV]
T43 2668-84M [FV]
R52 1847-A18
T42p 2373-KXM [FV]
T42 2374-M97 [SXGA+]
R51 1829-E5C [FV]
R40 2723-BAM [SXGA+]
R40 2723-26M
X32 x 2 2672-CM5/W58
X31's x 8 Four working.
X30 2672-4HM
X24 2662-FMT
Etc.
T43p 2668-H2M [FV]
T43 2668-84M [FV]
R52 1847-A18
T42p 2373-KXM [FV]
R51 1829-E5C [FV]
R40 2723-26M
X30 2672-4HM
X24 2662-FMT
Etc.
- 583 Views
Last post by KingBubba
Sat May 13, 2017 11:26 am
AMD Catalyst Install Manager will not install video card driver on T60
by psun9999 » Mon Mar 13, 2017 1:33 am » in ThinkPad T6x Series - 1 Replies
- 1466 Views
Last post by zoltan87
Mon Mar 13, 2017 5:55 pm
SOLD: T430s FHD i5, 8Gb + fresh Ultrabay battery + DVDRW
by harryK » Wed Apr 26, 2017 10:41 am » in Marketplace - Forum Members only - 3 Replies
- 384 Views
Last post by vaggs
Thu Apr 27, 2017 3:34 am
- 987 Views
Mon Feb 06, 2017 12:11 am
