Mini review: Advanced Dock with T60p
An update on my efforts.
I wrote to the Lenovo Company Secretary in the UK on this issue.
He arranged to send me a Lenovo badged ATI Radeon C300SE card. This worked after the usual problems of updating the ATI drivers etc but only with the external PCI set as primary. With internal set as primary blue screen parity error etc.
Feeling particularly stubborn one day, I decided to order the latest FRU part number 42W4603 for the dock from IBM Part Sales - this was more expensive than normal price but I could be sure of getting the specific part number.
I have just tried this with the NVIDIA 285 which never worked at all in the old dock. It worked fine. The bios is still set to boot on the external PCI but this gave blue screen on the old dock.
[Update: now tried with internal display set as boot and works fine also with both adaptors visible in Device Manager and windows desktop configurable as on both etc.]
I have yet to try all the other combinations I now have available but may do so just for curiosity. The new dock is also noticeably quieter.
Earlier Lenovo told me :
Regarding the different FRU numbers for the dock, as I asked about this, according to the information
I have there were no design changes connected with the PCI-e slot. So from this view it should be still
the same docking station.
so either this is untrue, or the original dock was just plain faulty along with a lot of others as noted by others.
Lenovo have just agreed to refund the cost of this second dock on receipt of the paperwork.
I gather they are in the process of publishing further support information but not exactly sure what.
Ian
Ian
Ian
MaloventEvil
just to clarify, do you have to shutdown when docking in the advanced dock, or can you dock / undock while the computer is on?
(has anyone tested this in vista?)
oh also, can someone post pics of their dock (pics from all angles)
the only picture that i've seen is the tiny one on the website, i kind of wanted to get a feel for the size, and the layout (especially on the sides where the pci slot and ultrabay are.)
thanks again,
-aurash
thanks again,
-aurash
MaloventEvil
would love to know the answer to this as I plan on buying a T60p with a docking station. If you can't undock/dock without powering the notebook down, this is a big downside.MaloventEvil wrote:just to clarify, do you have to shutdown when docking in the advanced dock, or can you dock / undock while the computer is on?
Yes, you can dock/undock with the power on just fine. The easiest way is to select Start->Undock Computer. The "Undock Computer" selection appears when the Thinkpad is docked.
There is one big "However." If there is a video card in the Advanced Dock, you can't hot undock. You have to power-down instead. This is a limitation of the operating system, not the Thinkpad hardware. Video adapters do not support hot undocking.
I haven't put Vista on any Thinkpad yet. I will probably get to this in about two weeks. But I'm willing to bet that the behavior will be the same - not hot undocking video adapters.
i'm using a new Thinkpad T60 with Radeon X1400 and windows vista and Advanced Dock + MSI Geforce 7600GS + Samsung 244T + 214TRonS wrote: I haven't put Vista on any Thinkpad yet. I will probably get to this in about two weeks. But I'm willing to bet that the behavior will be the same - not hot undocking video adapters.
- graphic card a little too big for expansion slot, cover does not fit anymore
- Fans in Dock are horrible noisy - due to extremely complicate disassambly cables cut. no stability problems.
- no hot undocking
- PCIe as primary in BIOS
MaloventEvil
can somebody definitely say which one of the Advanced dock (I mean the FRU Nr) works with the XFX Nvidia 7600GT RonS mentioned. And does the XFX 7600GT indeed fit in the dock?
It seems to me like the different cards and the different docks discussed here, work by chance and not by the "superior" work of the Lenovo engineers.
What do you say?
What do you say?
I'd agree with your post. As no-one has yet identified a common factor to failing or working card-and-dock combinations, it seems that we are still in the realm of the statistical. My comments on this subject are now with Lenovo's management team, and I await an outcome. I do not hold my breath, though...
best,
Mark
best,
Mark
MaloventEvil
MaloventEvil
a few questions:
1) has anyone tried running a card external to the dock using a pci cable extender, and providing a desktop power supply to power the card?
2) Is the 1x a limitation of power, or data pins?
3) Also, theoretically, it should simply reduce the bandwidth (used mostly for transferring textures), so by getting a card with say... 512MB ram, we should be able to store more textures, and not hit the bandwidth limitation so much, right?
4) If yes to #1, has anyone tried over clocking the cards?
Some formal information from Lenovo... more to follow.
the Lenovo X1300LE is certified in a 4-monitor configuration in the dock. Document id: MIGR-67464 last modified: 2007-03-09
http://www-307.ibm.com/pc/support/site. ... MIGR-67464
I do not speak for Lenovo, BUT before doing this, it is important to have ONLY Lenovo drivers on the system (not ATI reference drivers), and it may well be important not to have stressed the dock hardware with more than 50W.
More details for the approved x1300le on the Lenovo site
Also mentioned in the tabook file, p63:
http://www5.pc.ibm.com/us/me.nsf/downlo ... tabook.pdf
and on the page for the Lenovo X1300LE
http://www-307.ibm.com/pc/support/site. ... MIGR-67432
Note this is an X1300LE - a specific Low-Power Enterprise Edition of the card, designed to draw low power from the dock. Other cards are unapproved, and if they draw more than 50W they may damage the dock.
Read the first page of this thread. I did exactly as you suggested and it does indeed work. Even though the slot is physically x16, it is electrically x1, so you can't get better performance than that.MaloventEvil wrote:a few questions:
MaloventEvil
Keep reading. Yes, I did. I dragged a Dell Workstation box next to the dock and supplied external power from it to the video card.MaloventEvil wrote:i did read the first page; you used an external power supply? Don't some of the higher performance cards have a power connector slot on them?
Thanks again
I am very curious whether the Thinkpad advanced dock fans whine as loudly when the ATI X1300LE is plugged in, given its "low power" design.
BTW I have been running the Diamond BizView 300 with the RonS "fanless dock" mod for about a month now.
Originally I had even cut power to the video card's fan but this produced a disturbing and noticeable ozone-like smell in my office which abated when that fan's power was reconnected.
MaloventEvil
Thanks for the quick response. One last question -- i promiseRonS wrote:Keep reading. Yes, I did. I dragged a Dell Workstation box next to the dock and supplied external power from it to the video card.MaloventEvil wrote:i did read the first page; you used an external power supply? Don't some of the higher performance cards have a power connector slot on them?
Thanks again
Now here is something to think about for any hardware experts out there.
With BIOS set to boot internal display, my Lenovo boxed ATI X300SE (supplied by Lenovo as working with the Advanced Dock) was working sometimes and sometimes coming up with the dreaded blue screen NMI: Parity Error.
It is now clear that it works OK only if there is a USB mouse and/or keyboard plugged into the dock ! With nothing attached, it fails. I might try it with just a memory key plugged into a USB port !
Also, I note that the ATI X300SE is noted in the tabook.pdf (link above in Thesp post) as supported but the latest lenovo drivers are dated 2005. When installed, these drivers trash the LCD display on the Thinkpad. An F8 boot up is required in VGA mode to re-install the LCD drivers to get the LCD screen back.
Ian
DigitalFoundry
Hi there,
Just registered on the basis of this thread - the notion of being able to hook up PCIe cards directly to a notebook is very appealing for a project I'm working on.
I've been talking recent to the people at www.magma.com - they have an ExpressCard harness similar in principle to the dock here in that it connects any PCIe card to the laptop.
What you may find interesting is that they highly recommend that you match your external graphics card with the same make as the internal. So hook up an external ATI card if your internal card is ATI etc. They also suggest that some Geforce cards won't work if the external card is a Quadro, or vice versa.
With regards my own project, I don't own the required laptop or the dock and - a bit of a bizarre request - I'm wondering if any of you UK T60/dock owners also own a PS3 or will be getting one at launch? If so, please drop me a line via PM
MaloventEvil
I've never seen any way to control the fans in software. The main fan is always on, and the PCI-Express bay fan is apparently temperature controlled.biinkbok wrote:I know you can "cut" the cables on the advanced dock to turn off the fan, but can it be turned off in Software?
I ask because I cut them once before, and found that the ATI card I was using became unstable, so I had to reconnect them.
I do not think the PCIe bay fan can be temperature controlled as it reacts so quickly. With a Matrox P650 in the slot driving 2 displays, the fan whirrs up with a howl the instant a form is dragged across the displays and slows down again the moment the screen activity stops. I can only guess it is linked to the power drawn by the card - with some cards it seems to not run at all.
[/quote]
[/quote]
Ian
DigitalFoundry
MaloventEvil
Finally it works.
New virgin dock, Lenovo Radeon x1300le as secondary card, latest Lenovo drivers. All works fine EXCEPT Catalyst Control Panel cannot be loaded - causes crash on boot. I think this is due to there being different Catalysts for the FireGL series and the Radeon series.
very happy now.
best of luck to the rest of you all.
very happy now.
MaloventEvil
Well just wait a few months until ASUS' expresscard -> pci-e solution comes out, it will definitely be cheaper than 700$, and will be full length, supporting some serious cards.DigitalFoundry wrote:It's a specialist product that does what it does well - the ExpressCard to PCI version is tons more expensive!MaloventEvil wrote:HAHAHAHA. i just looked into that magma expresscard + enclosure: 729$!!!
Hi Thesp,
How many displays do you have connected to your dock?
I have ordered the same Lenovo Radeon x1300le card but I want to run two display with DVI link from my dock. I'm thinking if Catalyst Control Panel is not loading how to do it. I like to have 3 display including my T60P LCD working together.
Do you know if it will work or not?
Sepehr
Sepehr
That's why I have an NVidia card in my dock, so its drivers don't conflict with ATI's.Thesp wrote:Catalyst Control Panel cannot be loaded - causes crash on boot. I think this is due to there being different Catalysts for the FireGL series and the Radeon series.
With this setup, I have three external 24" monitors (1920x1200 DVI) , plus the Thinkpad's 15" monitor.
- 6 Replies
- 379 Views
Last post by swallman
Mon May 01, 2017 3:56 pm
- 1 Replies
- 2466 Views
Last post by symbot
Tue Mar 28, 2017 6:38 am
Review of the ThinkPad T470s (Core i7, WQHD)
by Puppy » Wed Mar 08, 2017 3:17 am » in ThinkPad T430/T530 and later Series - 6 Replies
- 3145 Views
Last post by mj0
Fri Mar 31, 2017 11:44 am
Review of the ThinkPad 13 2017 (Core i7, Full-HD)
by Puppy » Thu Mar 23, 2017 3:25 am » in ThinkPad Edge - 1 Replies
- 1013 Views
Last post by 600X
Thu Mar 23, 2017 9:05 am
