Mini review: Advanced Dock with T60p
thibouille27
DigitalFoundry
Other cards in the dock:
http://forum.thinkpads.com/viewtopic.ph ... light=pcie
best,
Mark
best,
Mark
mrdanieloh
Advanced Dock Question
Hi I am sorry if this has already been answered but I was wondering for those individuals who have purchased the advanced dock from Lenovo, do you know whether or not any power cables were shipped with the product? I just checked inside the box and there is no cable.
Thanks!!!
Thanks!!!
Ron, which model NVidia card do you have in your dock?RonS wrote:That's why I have an NVidia card in my dock, so its drivers don't conflict with ATI's.Thesp wrote:Catalyst Control Panel cannot be loaded - causes crash on boot. I think this is due to there being different Catalysts for the FireGL series and the Radeon series.
With this setup, I have three external 24" monitors (1920x1200 DVI) , plus the Thinkpad's 15" monitor.
Did you have to make any modifications to get it to fit?
Do you know if it runs reliably with Vista?
Thinkpad T450s
Thinkpad X61
Thinkpad 240
Thinkpad X61
Thinkpad 240
If you provide an actual link to the card, I can probably tell from a picture whether it will fit or not.
For the way I work, I like a silent computer system. That's why I chose a card with a heatsink rather than a fan, and disconnected the Dock's internal fans. By doing so, I may well have inadvertantly lowered the power requirements enough to have have a stable solid system. Some others who have tried putting video cards in the Advanced Dock have had problems that may be related to too much power draw.
Redmumba
Here is the product page on Newegg for the 7600GT from XFX:RonS wrote:If you provide an actual link to the card, I can probably tell from a picture whether it will fit or not.
http://www.newegg.com/Product/Product.a ... 6814150185
Just from comparing it with the XFX's 7600 GS, I'd say they look pretty similar as far as form goes... in your best opinion, do you think it'll fit?
Real Name: Andrew
Junior CS major, Polytechnic University
T61 - Core Duo 2.2ghz, 2GB, 100GB 7200RPM, nVidia 140M
Asus Z70Va: P-M 2.0, 2GB, 100GB 5400RPM, ATI MRX700
No, I don't think it will fit. Compare is closely with the image of this card: http://www.newegg.com/Product/Product.a ... 6814195013
It appears the the XFX card is a few millimeters wider. I have some cards that are that size and they don't fit in the dock, but by just a tiny bit. I've been tempted to get a sanding wheel and shave off a mm or so...
wallybear
Which BRAND of NVidia do you mean? XFX?RonS wrote:NVidia GeForce 7600GS. I've also used others as dicussed previously in this thread.
Can you provide a link to it on Newegg?
I just got an XFX 8500 card from Newegg after lots of research (thinking it would fit as the published specs show it would). But, it doesn't fit because the onboard fan assembly is too thick for the card to fully seat in the slot. I'm wondering which EXACT model of 7600GS you have so that I can get one that is proven to work.
Thanks in advance!
x100e (3508-CTO) 1.6 L625, 4GB RAM, 320GB 7200rpm HDD, Windows 7 Pro x64.
T400 (2764-CTO) 2.53 Core 2 Duo, 4GB RAM, 500GB 7200rpm HDD, 2GB Intel Turbo Memory, LED high-resolution LCD, Windows 7 Pro x64.
T60 (2623-D6U) 1.83 Core Duo, 3GB RAM, 80GB 5400rpm HDD, Windows 7 Pro x86.
There's a thread in the Vista area on that topic:atyrrrell wrote:sry if this was mentioned but is anyone running vista and mulitple monitors with the two graphics cards?
http://forum.thinkpads.com/viewtopic.php?t=44564
Alexander Heß
I'm using a PCIe-IEEE1394-card in the dock. Works okay except that there's no hotplugging. I actually have to boot the TP in the dock to get the card working.DigitalFoundry wrote:Has any one tried a non-graphics PCIe card in this?
At first I thought that was a Linux-problem, but it doesn't hotswap under Windows XP either.
It's not that problematic though, since I only need FW at home. But having to boot to get it to work sucks since Suspend2Disk is quite useless for me...
T60p 2613-HQU [2.33|2048MB|250GB|14.1" SXGA+|FireGL V5250|Ubuntu 7.10]
XFX 8400GS in Advanced Docking Station
The good news: It fits and it's recognized, drivers loaded etc.
The bad news: Device manager not happy: "Failed to load" and/or "Service failed to start".
The config: T61P, onboard nVidia Quad FX 570M, XP Pro
The comments/questions:
1) Is there any way to get further diag info from Windows? I cheked the event logs in Admin Tools, but nothing there.
I went with a GeForce card because I thought it best to "keep it in the family" with the on-board nVidia.
2) Was this a bad assumption?
I'm on the latest BIOS and I've tried every combination of primary display: PCIe and built-in.
* When set to PCIe, the device manager shows only the unhappy 8400GS and the resolution on my external display is stuck on low. Attempted changes are rejected.
* When set to internal, the device manager shows a happy internal FX570 and the unhappy 8400GS. Same stuck on low resolution on external display.
3) Any ideas before I try the matrox card?
Thanks in advance,
Barry
p.s. I've read about 10 forum threads here and elsewhere. Forgive me if I've missed something pertinant that's been already posted.
Thanks in advance,
Barry
I would try this:
1. Set the BIOS to boot to the internal video adapter
2. Boot into safe mode and uninstall the 8400 drivers.
3. Reboot back into safe mode, and install the 8400 drivers. You might check out laptopvideo2go.com for alternative drivers.
Hi Ron, thanks for the reply.
I'll give this a try. In the meantime I've ordered the new Matrox P690. Even if I can get the 8400GS to work, the P690 seems a better choice due to:
1) Much lower power (a well-noted limitation w/ the dock)
2) Heat sink vs fan (a card fan combined with the dock fan produces quite a rumble, also widely noted).
3) Dual DVI (XFX recently revved their 8400GS card to be one DVI plus one VGA).
Anyways, thanks again for taking the time to help out us newbies!
Apparently, yes. The fastest I"ve transferred data to/from any device on the Advanced Dock is around 34 MB/sec.commander wrote:Hello, has Advanced dock limited brandwitch if I put eSata PCIex1 card to it? I mean HDD > eSata PCIe > dock > T60. I read that HDD in ultrabay is limited to 34 MB/s.
This is so uselessRonS wrote:Apparently, yes. The fastest I"ve transferred data to/from any device on the Advanced Dock is around 34 MB/sec.commander wrote:Hello, has Advanced dock limited brandwitch if I put eSata PCIex1 card to it? I mean HDD > eSata PCIe > dock > T60. I read that HDD in ultrabay is limited to 34 MB/s.
I really regret, that I bought IBM. If I bought HP, I would buy their 3in1 dock with 3.5" HDD inside. Damm Flexview
I use a PCMCIA Firewire card on my Thinkpad and get 64-65MB/sec from a LaCie firewire drive. You may be able to do even better with an ExpressCard.
The Thinkpad supports a second hard drive in the SlimBay (remove the CD Drive) which does not have the bandwidth limitation of the dock. You can put the CD drive in the dock instead.
The Advanced Dock has a slot for a PCI Express card (commonly used for an add-on video card) that, from what I can tell, HP doesn't offer.
The dock's 34MB/speed limit shows itself during benchmarks, but in my real-world use of the dock, it's rarely noticable.
Success: T61P, internal nVidia, Matrox P690
Success!
I finally received my Matrox "P690 Plus LP PCIe x16" from Fedex today. To summarize, I have a 2-week old T61P, running XP Pro, with internal nVidia Quadro FX 570M. I have two external 22" LCD monitors and my goal is to use these in conjunction with the laptop LCD (and reserve the laptop's external display connection for a fourth display should I want one). I initially thought that using an nVidia-based PCIe card in the advanced dock would make life easier, I called XFX, found one that fit (8400GS), but was unable to get it to work and ended up returning it. After reading this and other forum threads, I decided to give Matrox a try.
I was all set to order the P650 but noticed on the Matrox site an announcement for the P690. I was drawn to this for a few reasons: Low power (10-11 Watts), heat sink instead of fan (noise factor), and an available 256MB version (the 690 "Plus").
I followed the matrox white paper instructions, but was immediately foiled. With the laptop BIOS set to use the external PCIe as the primary display, it wouldn't boot at all while docked. It emitted some kind of failure code, one long beep followed by two short beeps. No display or hard disk activity at all. I played around with reseating the card, disconnecting the monitors, switching BIOS boot displays, etc, all to no avail.
Eventually, dissapointed and bitter and determined I was going to return everything, laptop included, I switched back to internal LCD as both primary and boot display, but left it docked. It booted and low-and-behold, the device manager came up with new hardware, a generic VGA display adapter. I was suspicious that it had refound the internal nVidia display, but a quick check into the device manager indicated that no, this was an additional display adapter.
Again following the matrox instructions, I cancelled the driver install and executed the matrox software setup. Then rebooted. Checked the device manager and it was happily presenting both display adapters. So I went to display properties, attached all the monitors, and viola, success.
Another note: with XP managing the multiple displays, I was limited to 1280X1024 for the externals (1680X1050 for the laptop display). Switching to Matrox's display manager, I was limited to 1600x1200 for the externals (not-widescreen compatible). I had to set Matrox's "Mode Source" to "PowerRes Mode" to gain access to 1680X1050 for the externals, which is their native resolution (newer 22" LCDs).
Thats good result, but it must be annoying that you have to plug any cable to ThinkPad every time you dock it. In fact in my case I shoud have a cable with ExpressCard on the desk, and this thing connect every time...RonS wrote:I use a PCMCIA Firewire card on my Thinkpad and get 64-65MB/sec from a LaCie firewire drive. You may be able to do even better with an ExpressCard.
Yes, but I cannot plug 500+GB 3.5" drive, which I have.The Thinkpad supports a second hard drive in the SlimBay (remove the CD Drive) which does not have the bandwidth limitation of the dock. You can put the CD drive in the dock instead.
I am afraid of, because I will have connected about 5 devices all the time (mice, Keyboard, microphone, sound card, LCD, camera) and HDD. The bottleneck seems dangerously for me. In the second case, I need some card like thisThe dock's 34MB/speed limit shows itself during benchmarks, but in my real-world use of the dock, it's rarely noticable.
bill bolton
- 6 Replies
- 366 Views
Last post by swallman
Mon May 01, 2017 3:56 pm
- 1 Replies
- 2410 Views
Last post by symbot
Tue Mar 28, 2017 6:38 am
Review of the ThinkPad T470s (Core i7, WQHD)
by Puppy » Wed Mar 08, 2017 3:17 am » in ThinkPad T430/T530 and later Series - 6 Replies
- 3103 Views
Last post by mj0
Fri Mar 31, 2017 11:44 am
Review of the ThinkPad 13 2017 (Core i7, Full-HD)
by Puppy » Thu Mar 23, 2017 3:25 am » in ThinkPad Edge - 1 Replies
- 981 Views
Last post by 600X
Thu Mar 23, 2017 9:05 am
Users browsing this forum: Dekks and 18 guests
