ibm thinkpad icons
Radioguy
#31 Post by Radioguy » Tue Sep 30, 2008 12:30 pm
W and SL, as well.
  • T61 - 6465CTO - T9500 - 15.4" LG WSXGA+ - 8GB OCZ- 120GB EVO 850 SSD - X3100 - Win 8.1 Pro 64-bit
ThinkPad R
Re: ibm thinkpad icons
#32 Post by ThinkPad R » Sat Feb 28, 2009 1:27 am
http://www.mediafire.com/?gykommgmzny
beta vers, 256 x 256 is not clear yet.
ThinkPad X230T Intel Core i5 3320M 2.6GHz 4GB 500GB HDD Intel HD Graphics 4000 with docking station
Dell Vostro 1420 Core 2 Duo 2.53 GHz 4GB 320GB HDD 256MB nVidia GeForce 8400m DVD RW
Radioguy
#33 Post by Radioguy » Sat Feb 28, 2009 5:57 pm
Mediafire is timing out for me. Can you try imageboo.com or picpanda.com instead? They do free icon hosting.
ThinkPad R
#34 Post by ThinkPad R » Sat Feb 28, 2009 8:56 pm
sure
I basically took the thinkpad icon from here
http://www.iconarchive.com/show/lha-obj ... -icon.html
and modified it. I made smaller icons more recognizable & added touches involving stronger contrast or outline
Also, I added an enlarged version of the icon @ 256 x 256 so that it'd appear enlarged in very large view.
There's something stupid w/ Vista where if you have 128 x 128, it only shows up as 48 x 48 in a large thumbnail, in large view mode.
I plan to work on 256 x 256 to smooth it out. It doesn't look rough in "large view" but if you open up windows explorer & then select "extra large" view it does get broken up.
Radioguy
#35 Post by Radioguy » Tue Mar 03, 2009 7:37 am
Thanks. :)
That icon looks good, but the IBM logo is grey rather than tri-color, and it looks a little washed out on a light colored desktop. On a black wallpaper it looks ok in contrast to the darker image, but I think a darker color with highlighting might look better.
Are you resizing from each resolution to the next? I try to go back to the original image every time to reduce to the new resolution. I take an image, clean, edit it and convert to PNG, and then do each size from that original PNG.
EDIT: Did you receive any more of the new Lenovo TP icons? The only ones I've seen so far is the recycle bin, and the ones in Lenovo Toolbox are a little similar.
http://www.picpanda.com/images/4ib7j31h2p53x4tt8a5.ico
http://www.picpanda.com/images/n4pgj833vxc45wbbhit.ico
http://www.picpanda.com/images/km4cmct825vymo1bg2c2.ico
ThinkPad R
#36 Post by ThinkPad R » Tue Mar 03, 2009 12:18 pm
Hey! I also resize from the original. The original icon was really really washed out.
I think the guys who made the original (from the vista icons link) purposely changed the IBM ThinkPad logo to Lenovo's ThinkPad, but I do like the IBM ThinkPad logo so I'll add that.
I fixed the 256 x 256 by resizing an actual image of ThinkPad T42P & also replaced 128 x 128 w/ same image.
I'll upload it after adding the tricolor logo when I get home. Thx.
ThinkPad R
#37 Post by ThinkPad R » Tue Mar 03, 2009 5:20 pm
Ah & no I haven't found more Lenovo icons, but I don't like them to begin with.
I actually wanna make a set of icons that match the one that I made recently.
Complete.
ThinkPad R
#38 Post by ThinkPad R » Sat Mar 07, 2009 2:17 pm
http://www.mediafire.com/?nzjzit1myzd
tablet icon
i think it could be used for control panel
but i dont know how to change the icon for that
ThinkPad R
#39 Post by ThinkPad R » Sat Mar 07, 2009 2:30 pm
Marin85
#40 Post by Marin85 » Sat Mar 07, 2009 6:35 pm
Also, there are utilities like TuneUp Utilities 2008 (shareware) that can change whole packs of system icons. The utility has a 30-days fully functional trial and after applying all needed changes, uninstalling it doesn´t remove any changes already made by it ;)
Radioguy
#41 Post by Radioguy » Sun Mar 08, 2009 4:44 pm
That's usually a negative aspect of any software. ;)
I also like to edit the registry as little as possible. I only did so once in Vista for an icon, because for some reason it wouldn't let a different icon be set for the card reader on my T61. I had to edit the entry for SD, so i could assign my mock MicroDrive SD icon. :) Once I did that, it opened the door to change it with icon software too.
Speaking of which, I like Microangelo On Display, I can change the Control Panel icon and many more without any regedits.
I like the tablet icon. :)
EDIT: By the way, since most of the icons I create are for drives, when I can, I create autorun folders and inf's so I can move those drives to other PCs and still have the icons show. (Here's some of the my stuff showing on my VAIO)
ThinkPad R
#42 Post by ThinkPad R » Sun Mar 08, 2009 9:50 pm
http://lenovoblogs.com/designmatters/?p=273
they improved upon the icons--> they look cool now
Radioguy
#43 Post by Radioguy » Mon Mar 09, 2009 1:12 am
Yeah, I extracted those from the newer TV apps when I downloaded them, but never used them for anything else. They're a different template than the current recycle bin ones. I thought the recycle bin was just the tip of the iceberg, and I do suspect there were more, but maybe they just didn't use them. :(
Radioguy
#44 Post by Radioguy » Tue May 19, 2009 3:28 pm
HarryC has posted a new PC and Networking icon from the new template:
http://forum.thinkpads.com/viewtopic.ph ... 94#p510794
Radioguy
#45 Post by Radioguy » Thu Sep 02, 2010 10:43 pm
I'm sorry I didn't post this earlier. It's one of the more recent Lenovo created icons. I believe it installs with the Lenovo "ThinkVantage Tools" package (Not toolbox) and appears in "Control Panel\All Control Panel Items\Devices and Printers" for the Thinkpad once installed:
http://picpanda.com/images/101zapt2w3bgqrw6bchz.ico 216KB [128X128 pixels and below]
It looks like an X series model.
BillMorrow
*Senior* Admin
*Senior* Admin
#46 Post by BillMorrow » Fri Sep 03, 2010 12:44 am
its not clear WHAT it is besides a black notebook..
to give it a thinkpad identity add a red dot to the keyboard and, maybe, a red, green and blue "IBM" to the top lid..
Sysop - forum.thinkpads.com
~~~Mark Twain~~~
Radioguy
#47 Post by Radioguy » Fri Sep 03, 2010 12:50 am
Actually, open it in your browser or native photo viewer and zoom in (Crtl+). I think you'll see the details I'm referring to. ;)
EDIT: Nevermind, I turned it into a png:
http://img716.imageshack.us/img716/9397/thinkpad.png
BillMorrow
*Senior* Admin
*Senior* Admin
#48 Post by BillMorrow » Fri Sep 03, 2010 3:34 am
ahh, i see..
looks like an X300..
maybe i should replace charlie and the green bird with it..?
~~~Mark Twain~~~
Radioguy
#49 Post by Radioguy » Tue Sep 07, 2010 10:03 am
If you must, then it should fit with the established style:
http://img810.imageshack.us/img810/3548/beakcrown.png
By the way, that X300 icon I posted came from this package: http://www-307.ibm.com/pc/support/site. ... MIGR-73962
Also, are the current models still using the same recycle bin/network/my computer icons as posted earlier? (Same background I used for Bill's) If so, I did a couple more based on that template that I could post. They are a bit like the retro ones ThinkPad R did (folders etc). It's not enough for another pack yet, but I could let a few fly. ;)
BillMorrow
*Senior* Admin
*Senior* Admin
#50 Post by BillMorrow » Tue Sep 07, 2010 12:59 pm
the bird looks way too pixelated and the balck background obscures the image..
i think i'll stick with charlie for now.. :-)
~~~Mark Twain~~~
Radioguy
#51 Post by Radioguy » Tue Sep 07, 2010 1:11 pm
It would look better set at 256x256 or less. That was just to tempt you. If you want the .ico, I could do it. Do you have a higher-res version toucan? That was the best I could do with your avatar. (Not sure how it's obscured when it's on top, though)
Just for the hell of it:
http://yfrog.com/5htplogojpx (PNG's, mind you. I haven't ico'd these either yet)
BillMorrow
*Senior* Admin
*Senior* Admin
#52 Post by BillMorrow » Tue Sep 07, 2010 5:52 pm
no higher res version unless i use a photo of one of my real toucans..
all of whom have become deceased..
what are you using to edit graphic files..?
~~~Mark Twain~~~
Radioguy
#53 Post by Radioguy » Tue Sep 07, 2010 10:29 pm
I mentioned some apps earlier like MicroAngelo (great), but I also use Photoshop too.
I tend to use PS and then ico it with MicroAngelo, although it can be done in PS too with a plugin
SHoTTa35
#54 Post by SHoTTa35 » Sun Sep 26, 2010 6:25 pm
I wanna use the Thinkpad icons for Windows 7 but i want one of the actual T410. There are some that's of the T61 posted last page but anyone know where i can get some T410 ones :mrgreen:
Radioguy
#55 Post by Radioguy » Mon Sep 27, 2010 12:36 am
SHoTTa35
#56 Post by SHoTTa35 » Mon Sep 27, 2010 2:15 pm
Very nice! Danke!!!
BloodyGenes
#57 Post by BloodyGenes » Sun Dec 04, 2011 3:31 pm
I would really like do have the icons for my ThinkPad. For now I've got none of them, most of the Links previously posted are dead.
I am especially interested in the template-icon, the originals and the ones great users created themselves.
So, if you got some of the icons, please re-upload or send me PM!
I'd love to see Lenovo/IBM icons on my T61 :P
downthemachine
#58 Post by downthemachine » Sun Dec 25, 2011 3:37 am
BloodyGenes wrote:Hi,
+1
Radioguy
#59 Post by Radioguy » Sun Dec 25, 2011 8:25 pm
Which ones?
ThinkPad R
#60 Post by ThinkPad R » Sat Jun 22, 2013 6:52 pm
