Yes, please let us know. The older Atheros WiFi card in my two-year old X40 detects far more access points than the Intel card in my new X60. I'm concerned about what happens in weak signal areas.domi wrote:Sovereignty68: I assume you have received your Atheros adapter by now. Does it perform OK / better than the Intel adapter?sovereignty68 wrote:replaced the router with various linksys models. tried all settings but nothing works.
I am going to replace Intel 3945ABG with Lenovo part # 40Y7026 which is atheros chipset-based Mini PCIe adapter 802.11 A/B/G same used in Z60t. Part # 40Y7026 can be purchased from Amazon for $48.00 (shipped free), so I ordered one and see how it goes.
WIFI turning off by itself
redburgundy
I am having exactly the same problem with my new t60 using the 3945abg card with the latest drivers, I never had this problem with any other card including my t42 which has atheros. Now with the t60 not only my connection drops but the whole network drops
its crazy, So no one have posted any feedback on changing to atheros 40Y7026 which is what i am about to do, bright away i am using netgear wpnt834 which is the best router i ever use and i dont want to ditch it if the atheros card works, so please leave any feedback on the atheros.
Webmaster, Visual Basic Programmer
Thinkpad T42 1.2 Ram - 80 gb 7200 rpm HD- DVD Writer
Perhaps you will find some information on this page that will help. Note that if you download wireless drivers from the Intel site, Access Connections will not work with them.
Intel® PRO/Wireless 3945ABG Network Connection
DKB
Have you tried the ***NEW*** Driver? It's version 10.5.0.0 API Release Date: 2006/10/13
ThinkPad T60p T7600 4 GB RAM 320 GB 7200 RPM HD Vista Ultimate Service Pack 2 5.1 4.7 4.2 4.6 5.8You can also download the newest driver by pressing the ThinkVantage button and updating the system under maintenance.
X201s: 1440x900 LED backlit 2.13 GHz, 8 GB, 160 GB Intel X25-M Gen 2 SSD, 6200 a/b/g/n, BT, 6-cell, 9-cell, Windows 7 Ultimate x64 SP1, Verizon 4G LTE USB modem, USB 2.0 external optical drive, Lenovo USB to DVI converter
Previous Models: A21p, A30p, A31p, T42, X41T, X60s, X61s, X200s
Perhaps this will help: http://www-307.ibm.com/pc/support/site. ... MIGR-62875 System update should find them now as well. Sorry about that.WizardNYC wrote:GomJabbar, I try it the same thing happen
DAH the link is not working, although I try installing the latest drivers before and the same thing
ThinkPad T60p T7600 4 GB RAM 320 GB 7200 RPM HD Vista Ultimate Service Pack 2 5.1 4.7 4.2 4.6 5.8Just and update:
First thanks
Now after I change drivers, use both intels and IBMs the same happen so I just gave up on the 3945abg card and baught on amazon.com the 40Y7026 card.
And everything so far is working great no drops no interruptions just perfect
and I am finally enjoying my T60 laptop which I have to say is much faster then the t42 which I had before.
Also the Atheros 40Y7026 card is much better then the intel 3945abg card.
It has an average of 20% range. Where the 3945abg shows 80% signal strenght the 40Y7026 shows 100%. Not only that it detects more hotspot, the 3945abg shows 4 and the 40Y7026 shows 9 hotspot.
So if I were any of you I will buy the Atheros 40Y7026 is well worth the extra money.
PS: Dont even bother calling the IBM Tech support they can't get it through their head that somethign is wrong with this card, so save your time and don't even bother
First thanks
T420s - randomly offing itself
by Lockheed » Sun Jun 04, 2017 4:49 pm » in ThinkPad T400/410/420 and T500/510/520 Series - 1 Replies
- 281 Views
Last post by Hans Gruber
Mon Jun 05, 2017 5:11 am
X220 thinks that the hardware wifi switch is off (help and discussion)
by axur-delmeria » Mon Apr 03, 2017 12:42 pm » in ThinkPad X200/201/220 and X300/301 Series - 4 Replies
- 1009 Views
Tue Apr 04, 2017 11:08 pm
- 1205 Views
Last post by emtee3511
Sun Feb 12, 2017 12:53 pm
X1C 4TH GEN - Can I pop off keys to rearrange them?
by bittercactus » Mon Feb 06, 2017 3:18 am » in ThinkPad X1/X1C - 1 Replies
- 615 Views
Last post by w0qj
Sun Feb 12, 2017 10:36 am
