survey: thinkpad case recommendations
RamonesFan
I'm surprised no one has mentioned Spire, this is a GREAT bag:
http://www.spireusa.com/products/EN3.html
I highly recommend Targus bag
http://www.targus.com/us/product_detail ... ku=CUCT01A
This lightweight bag includes removable slip case, has a good air protection system, lots of pockets and very convenient shock-absorbing strap.
Regards, KaNo
Regards, KaNo
I borrowed my sisters Targus laptop bag (standard run-of-the-mill one shoulder strap bag) and it absolutely murdered my shoulder. If you're laptop is not light or superlight, I think it's far better to use a backpack over a shoulder bag.
I bought the Kensington Saddlebag from COMP USA for $40 + tax in NYC
just over a week ago. Seemed like a good deal as www.kensington.com was selling it for 60.
- T42 with 15'' and 9 cell battery fits really well.
- Padding on the bag is fairly adequate.
- Been caught in the rain several times and internal of bag is pretty much fine.
- Lots of room in other pockets for large items as well as bits and bobs.
Been going out and about with it all week and I highly recommend it.
I can post some pictures if anybody's interested but it might take a while since I don't always have online access.
Ken
Ken
RamonesFan
I've posted the first set of Rancor's Booq BP3 pics. You can find them at:
www.gwbookseller.com/bp3/bp3systemXXX.jpg
Where XXX is in the following ranges of numbers:
020-030
032-033
035-044
So, for example:
www.gwbookseller.com/bp3/bp3system020.jpg
www.gwbookseller.com/bp3/bp3system021.jpg
etc...
I believe more are coming from Rancor, I'll post when I have 'em up.
-RF
020-030
032-033
035-044
So, for example:
etc...
-RF
Hey ho, let's go!
JaimitoBond
irudy:
Do you have that spireusa bag? If so can you elaborate on how and why you like it?
I currently have the Mobil 1 case by Brenthaven. No direct link but you can find it at www.brenthaven.com then shoulder cases then apple cases. Fits my 14.1 with 9 cell very snuggly and looks like it will last 20 years easy. Unfortunately it lacks external and internal zip pockets. When I add the ac adaptor, mouse, and headphones, it gets quite crowded in the main compartment. Looking for something a little bit bigger. However i must say again how impressed i am with the build construction.
Binglehopper
does anyone have one of these cases?
http://www.timbuk2.com/tb2/catalog/cate ... egoryId=21
seems like the laptop grip sleeve, size small would fit the T42 14.1" perfectly. listed dimensions are: 10" x 1.5" x 12.5"
if anyone does have one of these, do you have any pics w/ the shoulder strap attached?
The powersleeeve 14 WILL hold a 14 inch t40 series with 9 cell bat no problem. I dont know about the 15 inch t42's but there does seem to be a little free room. You might want to check with the dimension from the tabook pdf and the interior dimensions from the booq website to see if it can hold a 15 incher.EnsignRicki wrote:Nacy333, so the PowerSleeve14 holds the 14 inch T42p with 9 cell battery? If I had known that I would've gotten that instead of the PowerSleeve15. Oh well.
Its a reasonably snug fit, but maybe a bit too snug as its pretty full when you add the power supply to the small front compartment, but then again, I didnt want a case that was bigger than the laptop and the power supply itself.
If you are interested in getting a good quality sleeve made out of soft wetsuit material custom made for your laptop, Pouch will make it for you if you give them the dimensions. The price is very reasonable and they have quick service.
http://www.thepouch.com/
RamonesFan
OK, the rest of Rancor's excellent pics are now online. Range of numbers is 001-019.RamonesFan wrote:I've posted the first set of Rancor's Booq BP3 pics. You can find them at:
020-030
032-033
035-044
So, for example:
etc...
-RF
-RF
Hey ho, let's go!
I bought a nice padded bag from Codi two years ago, and it fits my T41 very nicely. Of course, they no longer sell that particular model.
http://www.codidirect.com/shop/default.asp
Here is a review of laptop bags from PC magazine. This is what led me to the Codi in the first place.
http://www.pcmag.com/article2/0,1759,5558,00.asp
Rick G
T41 | 1.7ghz| 1.5 gb RAM | 14.1" XGA | Radeon 9000 | Dual 60gb @ 7200rpm | DVD-CDRW | WiFi a/b/g | XP Pro SP2
I use Targus Matrix
It's a backpack with many pockets and compartments. I am a student, so beside the laptop, I need room for paper, notes, some book, my ipod, cell phone, cables, water bottle, mouse, and much more. The bag holds them all. It is well padded, durable, and comfortable on my shoulder. I highly recommend it.
http://www.targus.com/us/product_details.asp?sku=RG0322
-Hai
Re: I use Targus Matrix
Wow, that thing's got some major surface area! But it looks like it does hold quite a lot of books.
But at 3.6lb, it's almost 1lb heavier than mine, and my extra weight allowance was already taken up when I decided 15" over 14"
fireracer7
I am looking to get a thin sleeve/slipcase for my new T42. I am looking at both the BOOQ Powersleeve 14 and the Spire Boot (vertical) [http://www.spireusa.com/products/BT4.html]. Anybody have either of these and any recommendations on either? I want to get one so that I can put it into my existing L.L.Bean backpack.
IBM ThinkPad T42 (2373-3VU): 14" SXGA+, 1.7GHz, 512MB, DVD-RAM, ATi Radeon 9600 64mb, 80gig 5400rpm, Intel Pro/Wireless 2200BG
JaimitoBond
The Booq Powersleeve 14 fits the 14" T41, with either 6 or 9 cell battery. The quality is quite good, and I recommend it.fireracer7 wrote:I am looking to get a thin sleeve/slipcase for my new T42. I am looking at both the BOOQ Powersleeve 14 and the Spire Boot (vertical) [http://www.spireusa.com/products/BT4.html]. Anybody have either of these and any recommendations on either? I want to get one so that I can put it into my existing L.L.Bean backpack.
Plinkerton
Re: survey: thinkpad case recommendations
This:Binglehopper wrote:hello all,
i'm looking to get everyone an idea of what people are using as laptop cases for the T42.
http://www5.pc.ibm.com/uk/products.nsf/ ... enDocument
I just picked up the targus sport backpack because I got a really good deal on it, I haven't had a chance to use it since my laptop doesn't come for a few more days, but here's a link:
http://www.targus.com/ca/product_details.asp?sku=TSB212
I'll tell how it is, but, if someone uses it, let me know.
MSE Environmental
Trager and
I've had great success with a couple of different bags, one from Trager and one from High Sierra.
The messenger bag from trager is outstanding and the best bag to protect a laptop. A couple of years ago it was rated the best bag by PC World or PC Magazine. It doesn't look or feel like your typical laptop bag which screams "I'm carrying a laptop".
http://www.tombihn.com/Merchant2/mercha ... t_Count=12
The High Sierra is a little more traditional. It will hold everything plus the kitchen sink. This is the good and the bad. On a recent trip to the Middle East and Europe I loaded it down with my Dell 5100, cords, digital camera, cell phone, Pocket PC, and supplies for my speech, it had to have weighed over 20 lbs. Way too heavy.(Which is why my office manager is getting my Dell 5100 and I'm getting a T42!) But it is very well designed and ideal for those of you who need to carry tons of extra stuff when you travel. It works best when placed on top of a rolling suitcase and not lugged on your shoulder.
http://www.ebags.com/high_sierra/a_t_ge ... elid=15704
Has anyone tried this one? IBM Backpack #73P3599
Anyone here experienced with using this backpack?
http://www5.pc.ibm.com/us/products.nsf/ ... p/_73P3599
If anyone has, please let me know how you like/dislike it. Thank you.
t9
t9
After looking for weeks all over this forum and the web, I got this today:
http://www2.elecom.co.jp/products/BM-IB01BK.html
Cons:
- thin padding
- not water-proof
- made in china
Pros:
- God made Perfect fit for 14.1" t4x with 6 cell battery (9 cell won't fit)
- 3 pockets hold everything I need: ac adapter, ethernet cable and airport express
I carry it in a messenger style school bag. It suits my needs very well.
Cons:
- thin padding
- not water-proof
- made in china
Pros:
3rd party batteries, recommendations
by Olangu » Tue Feb 21, 2017 7:45 am » in ThinkPad T430/T530 and later Series - 3 Replies
- 563 Views
Tue Feb 28, 2017 2:53 am
Need Repair Shop Recommendations
by redking » Sat Jun 24, 2017 12:42 am » in GENERAL ThinkPad News/Comments & Questions - 10 Replies
- 219 Views
Last post by Hans Gruber
Wed Jun 28, 2017 6:05 am
Identifying old IBM ThinkPad messenger bag/case
by EloItsMee » Wed Apr 19, 2017 3:45 am » in Thinkpad - General HARDWARE/SOFTWARE questions - 2 Replies
- 723 Views
Wed Apr 19, 2017 7:33 am
X61 - new LCD rear cover and upper case
by zz7 » Mon Feb 20, 2017 2:32 pm » in Thinkpad X6x Series incl. X6x Tablet - 11 Replies
- 1412 Views
Last post by jaspen-meyer
Thu Feb 23, 2017 3:28 pm
