Nylon coated screws, replacing them?
Nigellus
I have not experienced any problems re-using my screws... but the year is young.
T420 i5-2520M 2.50GHz 4 GB RAM 64-bit OS WIN7pro SP1
T60 1951-46U Intel Core Duo 1.83GHz 1 GB RAM 60 GB XPpro
TP 600E 2645 PII 366MHZ 160MB RAM 37.2GB WIN98SE
Computers do exactly what you tell them at amazing speeds; this can be bad if what you told them wasn't what you had in mind.
think2much
Re: Nylon coated screws, replacing them?
I've tried PTFE (Teflon) Tape on 2 screws. Works fine, but it's annoying to wrap the threads without leaving any visible white residue...PanEuropean wrote:The nylon coating on the screws is a threadlocker, pure and simple. In theory, you could use the screws over and over again, until they physically wear out, if you were able to apply an equivalent threadlocking material to the screw prior to each use so that you achieve the same results as the nylon coating. However, the problem with that is trying to find an 'equivalent' threadlocker. Obviously you don't want to use an automotive product, because that would lock them up too tight (you would not be able to release them in the future), and you don't want to use a liquid product, because of the risk of the liquid running off the fastener and onto something inside the ThinkPad.XCoalMiner wrote:...the special nylon-coated screws used in ThinkPad models should be used only once...
X21 PIII 700 - 256MB - 40GB
Dell Latitude 110L - Cel M 1.3 - 768MB - 30GB
HP NC4000 - P-M 1.4 - 512 - ???
X1C 4TH GEN - Can I pop off keys to rearrange them?
by bittercactus » Mon Feb 06, 2017 3:18 am » in ThinkPad X1/X1C - 1 Replies
- 616 Views
Last post by w0qj
Sun Feb 12, 2017 10:36 am
WTB Feeler: W530 T530 FHD 1080p Models - Also, how to fine tune Ebay search for them?
by crashnburn » Tue May 16, 2017 9:51 am » in Marketplace - Forum Members only - 5 Replies
- 396 Views
Last post by RMSMajestic
Wed May 17, 2017 2:56 pm
Does the T60 use the same screws as the T61?
by thinkpac » Sat Apr 08, 2017 8:05 pm » in ThinkPad T6x Series - 2 Replies
- 769 Views
Sat Apr 08, 2017 9:05 pm
- 2 Replies
- 227 Views
Last post by karotlopj
Sun Jun 11, 2017 9:57 am
