How to add Windows Key on a T41p thinkpad
XCoalMiner
#7 Post by XCoalMiner » Mon Aug 02, 2004 6:30 am
siut wrote: Can you tell me how to remap the ALT key to windows key? Does it require me to remove the keyboard and do some rewiring job? Thanks.
No rewiring necessary. As an alternative to the above suggestions, you can also use the following, which modifies the registry and thus uses the XP operating system to remap a key.
- Create a simple text file, ending with the extension .reg, with the following lines in the file. Omit the ===== lines.
- Double click on the file, then reboot.
- This maps the right Ctrl key as the windows key. You'll have to search for the code for the right ALT key.
- To reverse the remapping, put a "-" (without quotes) in front of the line starting with [HKEY_LOCAL_MACHINE\, and run again.
- This only works for WinXP, for Win2k or NT the first line is different. Search to find.
==== Beginning of file ===
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Keyboard Layout]
"Scancode Map"=hex:00,00,00,00,00,00,00,00,02,00,00,00,5b,e0,1d,e0,00,00,00,00
===== End of file ====
Roy_W
#8 Post by Roy_W » Mon Aug 02, 2004 9:27 am
Continuing on from XCoalMiner
For the lazy at heart here follows the "LEFT ALT" version for remapping the Windows Key
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout]
"Scancode Map"=hex:00,00,00,00,00,00,00,00,03,00,00,00,1d,e0,5b,e0,5b,e0,38,00,\
00,00,00,00
I also tried remapping the FN Key, but it seems that it cannot be done?
The scancode is given as 0x163 which I tried swapping with the Left CTRL key 0x1D but unfortunately the system does not respond correctly.
The FN Key is probably Hardware/Bios controlled only. Anyway I am glad that this hack allows for the "IBM Keyboard Configurator" to be removed from memory and subsequently uninstalled.
IBM ThinkPad T43p.
IBM ThinkPad T41p.
lvlolvlo
#9 Post by lvlolvlo » Tue Aug 03, 2004 2:52 pm
on my t40p there is a "Keyboard Customizer" utility under the Access IBM menu in my Start-->Programs menu.
I have mapped my right shift button for the windows key, they only reason why i have chosen to do this is b/c i need it for switching desktops.
sorry i needed to justify the reason for mapping that key.
