Best & Light sleeve to protect X60 in back pack
FredFromNYC
#61 Post by FredFromNYC » Thu Aug 17, 2006 12:28 pm
gunston wrote:no use.
your keyboard spacebar will be one side elevated/tilted after a long used typing. :wink:
And the meaning of this is...?
gunston
#62 Post by gunston » Thu Aug 17, 2006 5:45 pm
spacebar get elevated because of the design.
2. X60s 1703-CA3 powerful
devilsrejection
#63 Post by devilsrejection » Thu Aug 17, 2006 7:20 pm
<3 waterfeild, my x40 case is amazing so i don't doubt their x60 cases would be any worse
whoisjohngalt
#64 Post by whoisjohngalt » Thu Aug 17, 2006 10:57 pm
So if I get the Waterfield Vertical Sleeve (22-19) for my x60s w/8cell battery for use in a backpacl (I just want to throw it in the laptop compartment of my Targus backpack), should I get a flap or not?
x60s, 2GB RAM, 100GB 5400RPM HD, Bluetooth, x6 Ultrabase, 8-cell battery
FredFromNYC
#65 Post by FredFromNYC » Thu Aug 17, 2006 11:49 pm
Following up on the question by whoisjohngalt, how much bulk does the flap add to the case? Judging from the photos on the SFBags site, especially this one and this one, the flaps seem to be quite thick. I am also concerned about the flap end with the velcro fastener putting pressure right on the center of the display (e.g., when placed next to a big, heavy book in another bag) when I would prefer an entirely flat surface.
spaznrq
#66 Post by spaznrq » Fri Aug 18, 2006 4:19 pm
I have a X60 with 8-cell. I am thinking about getting a vertical 22-19 Waterfield SleeveCase. I'm a bit confused by their website's measurements, as there may be a typo between the X60 and X60s sizes as mentioned before, but I'm afriad the 22-18 will to too small for the X60 thicker rear. Will the 22-19 be a good choice, or will it be too big? I want a snug fit, but not small enough that it'll be difficult to slide it into the sleeve while it being in my backpack.
I have a Northface Recon backpack that's made with a laptop compartment.
http://www.thenorthface.com/opencms/ope ... model=AE6G
I wonder if it would be a good idea to put this sleeve inside that compartment, or would it be too thick to fit in there? You can't have too much protection but I don't want it squeezing my X60 to death in there.
I'm also wondering whether I should get a flap and/or D-rings with the case...[/url]
X220 Windows 7 Pro, X60 - 1709-7HU Ubuntu 9.10 + Ultrabase X6, X61t - 7764-CTO Windows 7 32b Ultimate + Ultrabase X6, , 19" Sony - SDM-HS95/B, Logitech MX Revolution, Logitech Dinovo Cordless keyboard and mouse, IBM Model M (1390131)
whoisjohngalt
#67 Post by whoisjohngalt » Fri Aug 18, 2006 5:37 pm
spaznrq wrote:I have a X60 with 8-cell. I am thinking about getting a vertical 22-19 Waterfield SleeveCase. I'm a bit confused by their website's measurements, as there may be a typo between the X60 and X60s sizes as mentioned before, but I'm afriad the 22-18 will to too small for the X60 thicker rear. Will the 22-19 be a good choice, or will it be too big? I want a snug fit, but not small enough that it'll be difficult to slide it into the sleeve while it being in my backpack.
go to their website and send them an email. they responded back to me in about 2 hours!
anthers
#68 Post by anthers » Sun Aug 20, 2006 1:05 am
FredFromNYC wrote:Following up on the question by whoisjohngalt, how much bulk does the flap add to the case? Judging from the photos on the SFBags site, especially this one and this one, the flaps seem to quite thick. I am also concerned about the flap end with the velcro fastener putting pressure right on the center of the display when I would prefer an entirely flat surface.
I just got my Waterfield case (22-19 vertical with flap) in the mail last week. The flap isn't that thick, it's a layer of felt stitched to the ballistic nylon. It doesn't have the closed cell foam that the main sleevecase does. On the pressure issue, you can try putting the laptop in upside down, since the bottom of the case is flatter than the top. I did that for awhile when I was carrying my X60s in my backpack sans a case.
X60s - L2400 512mb/60gb, 8-cell battery, Bluetooth, Fingerprint reader.
anthers
#69 Post by anthers » Sun Aug 20, 2006 1:11 am
I think the X60 and the X60s are about the same thickness with the 8-cell battery (it adds about half inch to the back of my X60s). My laptop fits a 22-19 case just about right, it's a little loose, but still slides in with some resistance. I'd imagine that it would fit the X60 okay, even if it was a little bit thicker.
I got a sleevecase with a flap, but having it in my hands, it probably would work fine without the flap. The neoprene foam is rolled at the top edge, and that seems to provide pretty good protection against any inadvertant bumps it might get inside a backpack.
whoisjohngalt
Waterfield
#70 Post by whoisjohngalt » Sat Aug 26, 2006 1:01 pm
I just wanted to second what everyone has said about Waterfield. They have the best customer service that I have ever encountered with ANY business. They follow up on your order to ensure that you will be getting exactly what you want, respond to questions quicky, and make the experience a pure joy. Oh yeah, the bags are great too! Well worth the money in my opinion.
22-19 vertical for x60s w/8 cell.
lightnk102
#71 Post by lightnk102 » Sun Aug 27, 2006 6:41 pm
hey all.
i received my blue shinza case yesterday and i'm pretty happy with it. i was hauling my thinkpad "naked" in my backpack for a few days and I had marks on my LCD from the trackpoint pressing against the screen (i'm guessing from the weight of my books pressing against the lid). after i got the shinza, i haven't seen any marks at all on the LCD, it protects my laptop from sudden falls (like if I mistakenly place my backpack down too heavily), and looks like a retro jumpsuit with the white piping. i'm pretty happy and i've gotten quite a few compliments on it.
my reasons for choosing the shinza:
it was cheaper than the waterfield, was mentioned positively in a few different thinkpad threads, and has a zip-around giving it protection on all sides. i tend to use both shoulder bags and regular backpacks, so choosing between a waterfield horizontal and vertical was tough since it looks like most of their padding is on the "bottom" of the case - depending on which orientation it is. i felt the shinza gave me better all around protection. of course - the downside is that i have to take the entire case out of my bag just to get my laptop out - but that doesn't bother me that much.
i'd heard that the 11 inch shinza fits the x60s very very snugly, but i didn't want to risk the case being too small for my x60, so I got the 12 inch. the 12 inch shinza case is a bit large around the edges (i.e. the footprint is a little larger than the footprint of the thinkpad) but it fits snugly enough around the x60 that the laptop doesn't shift around despite the extra space.
devilsrejection
#72 Post by devilsrejection » Sun Aug 27, 2006 10:51 pm
i personally don't like zippers. no one uses high quality zippers except for a handful of companies, and when they do you obviously know because the price shows.
i have a waterfeild with a flap, velcro is 2 years old and it still works great.
if i were to buy another laptop sleeve would i get it from them? absolutly.
personally if you think 50 bux is a lot of money for a 2 grand laptop then idk what to tell you really.
ewoktype
#73 Post by ewoktype » Mon Aug 28, 2006 2:28 am
I've used a horizontal waterfield sleeve for my T41p and it has been great. I recently purchased a vertical watersleeve case for my X60s + 8cell with their advised 22-19 size. It fits fine and I can easily leave the case in my backpack while taking my laptop out to use.
Thinkpad X60s [1704-69U] 1.66LV 100GB 1GB BT FPR WWAN X6base DVDWR 8cell Atheros abg
Thinkpad T41p [2373-GEU] [sold] 1.7C 60GB 1GB BT SXGA+ 128MB FireGL CDWR 9cell Intel abg
getlow
#74 Post by getlow » Mon Aug 28, 2006 4:11 am
ditto what the guy above me said..
x60s 1704-69U
Wolfie
#75 Post by Wolfie » Wed Aug 30, 2006 1:19 am
I bought a nice Brenthaven bag many years back when I was looking into getting a laptop. I didn't end up buying one and end up giving the bag to my sis for her Dell. She didn't use it much and so it's back in my possession. The sleeve that comes with the bag is a bit thick for the X60s so I'm thinking I should at least get a new sleeve? The question then is whether I should still use my brenthaven or simply put the X60s in a sleeve and then in a backpack along with my heavy books.
In terms of the waterfield sleeve, what is the reason for going with a vertical vs horizontal and vice versa. And is anyone getting a strap with it or are most sticking it into a bag or something?
dannyp
#76 Post by dannyp » Wed Aug 30, 2006 2:09 am
Did you get a larger Brenthaven? I got the 3180 for the 12" lappy.
Yours came with a sleeve? Mine is too small to have a sleeve of it's own. I'm not sure what you mean.
Vertical is built for backpacks, horizontal for messenger bags. Maybe you have some better idea about the use of these, but I like that my vertical can plug in the headphones or power if I need to without removing it. On the other hand with the X60s a Horizontal bag might be more appealing to your aesthetics since the chassis it's more of a wedge shape and not entirely flat. Some vertical sleeve owners may not like this, but I don't mind. Just depends on which orientation you want. I wanted to be able to take the laptop out of the backpack and leave the sleeve in there.
X60s 1705-43U :: T41 :: T410 :: X220 4286-CTO
Wolfie
#77 Post by Wolfie » Wed Aug 30, 2006 12:21 pm
Mine is from many many years back. It came with a sleeve that sticks to the bag itself. It sort of looks like the glove. But obviously the sleeve was designed for a much thicker laptop so the X60 will wobble around in it I'm sure. I suppose I can invest in a new bag.
Wolfie
#78 Post by Wolfie » Thu Aug 31, 2006 1:31 am
I think I'm going to go with an SF bag in the horizontal config. Should I get the flap, strap, and piggyback?
devilsrejection
#79 Post by devilsrejection » Thu Aug 31, 2006 5:50 pm
Wolfie wrote:I think I'm going to go with an SF bag in the horizontal config. Should I get the flap, strap, and piggyback?
its personal preferance dude
i have the flap.
tbfox
#80 Post by tbfox » Fri Nov 10, 2006 8:09 pm
Not to be redundant, but I wanted to share my Waterfield (www.sfbags.com) experience. I ordered my sleeve (22-18 for my X60s with 8-cell) on Wednesday. Wednesday afternoon I received the email stating that it shipped. Two days later and it's in my hands. It is extremely well made, and quite stylish. My lappy fits like it was custom made. Nicest touch: inside the shipping box was a hand-written note from whomever packed it thanking me for the purchase.
I would definitely deal with this company again.
Traci
42.7 percent of all statistics are made up on the spot.
Proud Owner of X60s (1704-69U)
ozmann
#81 Post by ozmann » Fri Nov 10, 2006 9:53 pm
I have the flap, suspension strap and piggyback. It makes a nice combination for carrying the computer by itself. I agree with other comments about aesthetics and quality. If you are only going to use the sleeve in a backpack, the flap is not necessary, but it makes sense if you will carry the computer on its own. The suspension strap is very comfortable because there is some elastic in the portion that goes over the shoulder (it is not practical if you want to switch between cross-body and over the shoulder, since the wide, padded portion is fixed on the strap). The piggyback bag is surprisingly useful. It holds the AC power adapter and lots more.
T40p. T42 and X40
X60s 1704-69U, 2GB Ram, 100GB HD
First Light
#82 Post by First Light » Sat Nov 11, 2006 10:35 am
I too have the SF bag, but only with the flap which suits my needs perfectly. This is my second SF bag - my first one which is now 3 years old still looks new (can't figure that one out as I use the bag a lot), and I liked my first one so much I bought another for my X60s. I might add that this new SF bag has a pocket on the back into which you can carry 8 1/2 x 11 papers, and or the AC power adapter can also be crammed into it.
Spif
#83 Post by Spif » Tue Nov 14, 2006 2:59 pm
Thanks guys, this is an awesome thread. So much useful information. Deserves to be stickied, no doubt about that.
I'm not entirely sure if I should buy a Waterfield sleeve though. I'm a bit worried about the protection of the laptop compared to normal carrying cases. Can you for instance drop the laptop and expect it to not get any ugly marks when it has the sleeve on? Also, does your X60/s get any scratches on the screen by being in the sleeve?
I just want to be 100% sure this is the right choice for me, as buying one will cost me a bundle (international shipping plus a crap load of taxes when it arrives). So if anyone can clarify this for me, I would really appreciate it.
IBM Thinkpad X60s (1704-56G) Core Duo L2400, 80 GB 5400, Intel 3945, Bluetooth, 8-cell and 4-cell slim battery
First Light
#84 Post by First Light » Tue Nov 14, 2006 6:05 pm
Spif wrote: Can you for instance drop the laptop and expect it to not get any ugly marks when it has the sleeve on? Also, does your X60/s get any scratches on the screen by being in the sleeve?
I can speak only for the SF sleeve. I have dropped mine several times and the laptop has suffered no ill effects as the SF sleeve is nicely padded.
archer6
#85 Post by archer6 » Tue Nov 14, 2006 7:01 pm
While I have not dropped mine in the Waterfield Sleeve, I like that it has a special strap on the bottom of the sleeve that allows you to slip a finger or two through it while carrying.
This provides an extra measure of safety and I must admit I believe it has prevented me from dropping mine in a couple of instances.
Netbooks... S-10 ~ S-12
First Light
#86 Post by First Light » Tue Nov 14, 2006 8:51 pm
Yes, that is nice - the SF bag also has a strap into which a couple of fingers will fit for carrying purposes . . . . . . .
stgreek
#87 Post by stgreek » Thu Nov 16, 2006 6:37 am
I would also check the booq powersleeves. I got both 12" models (the old black and the new grey one) for my X31 and X60s and they can be used both as a sleeve inside a backpack and as a standalone bag for the laptop. Excellent build quality, and perfect fit for the X series (I also have the 14" one which is a perfect fit for a T4x 14" with extended battery).
Stgreek
gandini
Mambo Combo
#88 Post by gandini » Mon Nov 20, 2006 4:00 pm
I have been using my WF Mambo Combo, which includes the 22-19 sleeve, for a couple of weeks now--Wow! I have had WF sleeves before, but the satchel and sleeve together are really fantastic. Easy to bike, commute, get through TSA, etc. And stylish to boot!
Dr. Phil
x60s 1704-4UD
Trolle
#89 Post by Trolle » Mon Nov 20, 2006 4:14 pm
Spif,
If you want an SF bag I'll bring one to Denmark and mail it to you. I live in Copenhagen and will be back in early 2007, if you can wait that long.
Trolle
ozmann
Re: Mambo Combo
#90 Post by ozmann » Wed Nov 22, 2006 10:43 pm
gandini wrote:I have been using my WF Mambo Combo, which includes the 22-19 sleeve, for a couple of weeks now--Wow! I have had WF sleeves before, but the satchel and sleeve together are really fantastic. Easy to bike, commute, get through TSA, etc. And stylish to boot!
Which WF bag did you get with your sleeve?
T40p. T42 and X40
