"We used to use something in the service, avionics cleaner, or "tweat in a can,' "
Would this be the same thing that Radioshack sells in a spray can as contact cleaner/lubricant?
I use a long flat oil painting brush for cleaning--you can get it started at one end, and sweep under the keys from one end to the other, and then do the whole board diagonally/vertical also. Eventually you get a lot of crud out. I also have a compressor at my shop, which works to blow out stuff.
space bar problems
davidspalding
One word of caution. Before you guys/gals go dragging out the Kirby or Shop Vac, you may want to take a look at this thread. The original post is most.........
http://forum.thinkpads.com/viewtopic.php?t=12824
DKB
Long time after: USB stick problems on W98
by wujstefan » Sun Mar 05, 2017 2:29 pm » in ThinkPad R, A, G and Z Series - 6 Replies
- 1187 Views
Last post by wujstefan
Tue Mar 21, 2017 1:32 pm
Looking at buying a 1st Gen - but has no HD - COA problems?
by dwilsonfl » Tue Mar 14, 2017 8:56 pm » in ThinkPad X1/X1C - 5 Replies
- 1633 Views
Last post by dwilsonfl
Sat Mar 18, 2017 6:23 pm
- 14 Replies
- 1280 Views
Thu Jun 15, 2017 10:40 am
- 7 Replies
- 749 Views
Mon Apr 17, 2017 6:57 pm
