I have an i1300 (P3-750 Mhz, 256 MB, 20 GB, CD/CDRW, 10/100 Ethernet NIC , 13.3, Windows 98 SE) with a tale and several questions.
I bought a nearly identical machine about a year ago that had several problems -- tinny broken sound, instability, inability to recover fully from sleep, overheating. After trying to fix it the seller (USANotebook) sent me another. The hard drive of the first machine was carried over. This one has the same problems -- except for the overheating (so far). I've had a several thinkpads and none has been as problematic as this model. SO my questions are:
1) Is there something wrong with the i series?
2) Can I upgrade to Windows XP and would that solve anything?
3) Is the tinny broken sound -- even on things like the Eudora "You Have Mail" alert -- a system problem?
4) IS the 256 memory OK? I read elsewhere that the i series is supposedly limited to 192. Norton Utilities reports a problem with the memory, the same problem it reported on the previous machine. USANotebook pooh-poohed this Norton result. But I do seem to have limited memory, and get messages to close programs in order to run others.
Thanks for any help you can offer. I love the site.
i1300 Multiple Questions and Tale (sorry)
AlphaKilo470
- Moderator Emeritus
For the overheating, I would first look at the system fan. Get a can of compressed air (or if you have an air compressor in your garage, use that with the blower nozzle attached but make sure pressure isn't too high) to get every spec of dust out of the fan and vent. Keep air blowing in and use different angles until you hear fan spin freely and see zero dust left.
For the broken sound, open up the volume control program in Windows and try turning down the wave volume and system volume a little bit.
W520: Questions regarding heatsinks and fans.
by Surfrider » Wed Jan 04, 2017 12:40 am » in ThinkPad W500/510/520 and W7x0 Series - 9 Replies
- 1841 Views
Last post by jcvjcvjcvjcv
Thu Jan 05, 2017 11:00 pm
Just joined and Frankenpad questions
by cortina18 » Sat Jan 14, 2017 2:00 pm » in ThinkPad T6x Series - 21 Replies
- 2270 Views
Last post by Vonfeffer
Mon Jan 30, 2017 12:16 pm
WOL (Wake On Lan) T-61 Win7 32bit Problem/Questions
by EAkamai » Sun Jan 22, 2017 4:41 am » in ThinkPad T6x Series - 1 Replies
- 823 Views
Last post by EAkamai
Tue Jan 24, 2017 4:39 pm
Swapped X61s motherboard into X60s, questions on BIOS version / computrace
by thewanderer » Sun Feb 12, 2017 3:01 pm » in Thinkpad X6x Series incl. X6x Tablet - 10 Replies
- 1631 Views
Thu Feb 16, 2017 9:14 am
