What I copy-and-pasted was from the Tabook, which is as definitive as you can get. The motherboard chipset is designed to use 4200 and so that's the fastest RAM speed you can achieve, and if you install 5300 sticks on this laptop, the RAM will not run at 5300 but instead only at 4200. The reason some people would rather buy 5300 sticks for the T43 even though they aren't any faster is that these sticks would also work on machines that take 5300 memories, e.g. the T60, so that if you later upgrade from T43 to T60, you can re-use the memory. If 4200 and 5300 modules cost the same amount of money, I would prefer to buy the latter too, but they are always much more expensive.little a wrote:well, i'm methodical like that for some things and, because i've yet to hear a definitive answer on this issue (i.e. whether 4200 is the fastest available RAM)
RAM update- IBM or not?
Dead1nside
I had an engineer come round and he seemed like a nice guy, I asked him to use my thermal paste and he did and he asked about the RAM and I said, to be honest I don't know. It's second hand.Bgradid wrote:I'm curious, does IBM care if you've installed 3rd party ram should you ever need it serviced? Or should I sneak out my 2 1gB sticks I got and put in the 512 it came with if I was to send it to the shops
You would have thought IBM were quite strict on stuff like the thermal paste they used, as a matter of not wanting extra expense later for fixing something to do with a product they haven't tested or certified.
Very pleased. Now I've got to get them to come out and do my screen before the warranty's up
BIOS update - ok to jump 11 updates in one update?
by serpico » Tue Apr 18, 2017 11:53 am » in ThinkPad T430/T530 and later Series - 6 Replies
- 489 Views
Last post by MikalE
Wed Apr 19, 2017 12:21 pm
X1 Carbon (5th gen, 2017) : 8gb Ram or 16gb Ram , i5 or i7
by asterinex » Tue Apr 25, 2017 4:12 am » in ThinkPad X1/X1C - 26 Replies
- 2067 Views
Last post by w0qj
Sat Apr 29, 2017 11:22 am
Camera LED does not work? Make sure it's not taped over. :)
by dr_st » Sat Feb 18, 2017 12:00 pm » in ThinkPad X200/201/220 and X300/301 Series - 0 Replies
- 803 Views
IBM thinkpad 380xd sound driver not working in windows 3.1 correctly
by MichaelWeaser » Sun Apr 02, 2017 9:55 am » in ThinkPad Legacy Hardware - 0 Replies
- 752 Views
Last post by MichaelWeaser
