thinkpad and silver 5...........(56K be aware)
zaku
#91 Post by zaku » Sat Sep 16, 2006 7:36 pm
yes i'm under dynamic switching with NHC software (1.020V at 1.7GHz)
room temp is ~25c
i don't know what's my gpu temp.. it's not displayed in the NHC but i set the clock control on NHC for 130MHz/130MHz
i don't think my thinkpad is running at low temperature cuz i've heard someone told me having a t42 2GHz running at average 35c he told me without AS5 :roll:
IBM Thinkpad T43 - PM 1.86GHz
Sony VAIO FE - C2D 1.86GHz
agarza
#92 Post by agarza » Sat Sep 16, 2006 9:20 pm
[censored] 35C is way too low to me. I would be happy if my T42p temp were 40C.
You can check your CPU temp using T43 Fan Control, check the sticky in the ThinkPad T4x Series only section.
I don't understand why some laptops processors run more cooler than others. My average CPU temp is 52C with 1.196V @ 1.8GHz.
I can't undervolt the GPU under NHC because that option is grayed out. I did upgrade the drivers from ATi, or the modded driver over the forums, but the screen flickers weirdely.
Do you have the 128MB FireGL T2 Video card?
Current
T440p:
zaku
#93 Post by zaku » Mon Sep 18, 2006 7:54 pm
i just checkd the fan control... i don't know why i can't get to install it :? :?
my video card is the ati 9600
by the way, now the cpu seems to be cooler than few days back when i just applied as5. no it idles at ~37c
and when watching a movie at full screen, it goes no more than ~42c :D :D seems it really needs a few break in days
agarza
#94 Post by agarza » Mon Sep 18, 2006 10:47 pm
In order to view all the laptop temps, download Thinkpad T43 Fan Control. You unzip the contents of the file, execute fancontrol.exe, then it appears like nothing happens.
But, in your taskbar (right side at the bottom) of your screen you'll see a gray circle with a T inside. You double click on that icon and the software window will appear.
It's amazing that you run 37C idling, but (how much time did you leave the machine in that idle state? To properly measure that temp you should at least wait 1 hour and then check your CPU temp and see if it's the same.
Apparently some laptops run cooler than others. Mine is 45C with Dynamic Switching. But I wish I could underclock my GPU to achieve a more cool system.
Current
T440p:
agarza
#95 Post by agarza » Thu Sep 21, 2006 5:26 pm
Is it better Coollaboratory Liquid Pro vs Arctic Silver 5??
I think my syringe of AS5 is out of date, as curiously all the people that have applied it have yielded positive results.
My CPU is too [censored] hot, generally running at 56-60C with the 1.8GHz processor with the stock voltage.
do you think the CLP will ruin my heatsink/CPU/GPU?
Current
T440p:
nirvana0001
#96 Post by nirvana0001 » Fri Sep 22, 2006 1:18 am
benottomex wrote:Is it better Coollaboratory Liquid Pro vs Arctic Silver 5??
Yes collaboratory is better than AS5. but it's also risky.
2008 Alienware M9750 - 17" WUXGA C2D 2.0Ghz 4GB SLI 7950GTX 100GB+200GB
2007 Sony UX280p - 4.5" SVGA Core solo 1.2Ghz 1GB Ram 40GB HDD XP Pro
2007 Macbook Pro - 15.4" WSXGA C2D 2.33Ghz 2GB X1600 256MB 120GB
nirvana0001
#97 Post by nirvana0001 » Fri Sep 22, 2006 1:22 am
Before:
After:
if you are sure both CPU/GPU and heatsink don't contain silver then you are good to go.
agarza
#98 Post by agarza » Fri Sep 22, 2006 10:36 am
Thanks nirvana
I dumped the option of CLP, too dangerous, considering it might corrode the copper heatsink on T4x series.
I was searching the web, and found out another competitor for Arctic Silver: It's name is Zalman ZM-STG1
Read the review here:
http://www.tipidpc.com/viewtopic.php?tid=67101&page=1
It claim to reduce CPU/GPU temps 1-3 or maybe more degrees off better than AS5!!
Really impressive
The most important thing here, is that it comes in a nail polishing bottle with the brush, so that the application of the product is easier.
I think my AS5 syringe is oudated or something, or was stored in a place where the product lost its consistency, because my T41p temps have gone very high.
I already ordered it off eBay for 14 USD included shipping.
I'm enthusiastic about this product. Time to ditch the AS :lol:
Current
T440p:
sparta.rising
#99 Post by sparta.rising » Fri Sep 22, 2006 10:40 am
Well can we get a report from anyone who has used Coollaboratory Liquid Pro on their thinkpad? Like a "1 month later" thing? Any corrosion?
nirvana0001
#100 Post by nirvana0001 » Fri Sep 22, 2006 2:23 pm
sparta.rising wrote:Well can we get a report from anyone who has used Coollaboratory Liquid Pro on their thinkpad? Like a "1 month later" thing? Any corrosion?
i think the GPU/CPU might contain silver
sparta.rising
#101 Post by sparta.rising » Fri Sep 22, 2006 4:49 pm
Might being the key word
I know at least one person has posted that he used this on his thinkpad, so what is the aftermath?
agarza
#102 Post by agarza » Sat Sep 23, 2006 12:17 am
I will post my results after applying Zalman on my T41P.
I'm sure the temps will go down.
Current
T440p:
Dead1nside
#103 Post by Dead1nside » Sat Sep 23, 2006 6:34 am
To be honest I don't think there will be much difference between the two brands of thermal paste.
agarza
#104 Post by agarza » Sat Sep 23, 2006 8:29 am
Dead1nside wrote:To be honest I don't think there will be much difference between the two brands of thermal paste.
Well, to me I think there will be.
It's demonstrated that Zalman Super Grease DO decrease 1-4C compared to AS5.
In my case, my AS5 syringe has proved a pain in the a$$, because I've reapplied to many times, but the temps rise stratospherically.
Is there a way to know if the compound inside the syringe had lost its consistency, maybe storing it in a bad way (syringe should be stored facing down).
I heard also from a user in newegg, that his new AS5 paste is blueish, compared to the grayish stuff on his former AS5 syringe.
How can you explain that my CPU reach 63C when not gaming, only watching a DVD movie, running at 1.8GHz. This is unacceptable.
Current
T440p:
nirvana0001
#105 Post by nirvana0001 » Sat Sep 23, 2006 11:36 am
benottomex wrote:How can you explain that my CPU reach 63C when not gaming, only watching a DVD movie, running at 1.8GHz. This is unacceptable.
Product defective?
Dead1nside
#106 Post by Dead1nside » Sat Sep 23, 2006 6:42 pm
Depending on how old it is, if it has been kept in a cool place and out of the sun etc. I'm sure there's some way it could be less effective if applied after present in the above conditions.
AS5 works fine for me, and others. Zalman are pretty good with their products, so all the best to you.
agarza
#107 Post by agarza » Sat Sep 23, 2006 6:45 pm
Yep, indeed.
Strangely enough, in my T30 the temp drops very fast, considering that the thing (AS5) has not reached the 200 burn-in period.
The T30 is ready to sale. A shame, because that machine is rock-solid.
I need the money to make up of getting this T41p hot hot machine, thanks to AS5 defective production :?
Current
T440p:
Senser
#108 Post by Senser » Fri Sep 29, 2006 2:15 pm
@benottomex, did you try Zalman SGT1 yet? I'm also considering it on my T43 since the temperature is annoying.
agarza
#109 Post by agarza » Fri Sep 29, 2006 4:45 pm
Senser wrote:@benottomex, did you try Zalman SGT1 yet? I'm also considering it on my T43 since the temperature is annoying.
Nope, the thing has not arrived yet.
I'm also expecting a Thai keyboard bought from Dimitri, on these forums.
For sure I'll post a review how did all go with the Zalman.
Anyone could confirm if the TIM affects heat dissipation when you run your CPU undervolted at 600 or 800MHz? For example, if I did applied a lot of AS5 in the CPU core, then the heat dissipation would be affected, even if the fan is not ON?
Current
T440p:
nirvana0001
#110 Post by nirvana0001 » Sat Sep 30, 2006 12:19 am
a lot of AS5 would get your laptop hotter.
agarza
#111 Post by agarza » Sat Sep 30, 2006 9:17 pm
nirvana0001 wrote:a lot of AS5 would get your laptop hotter.
Yes, indeed.
Maybe I did applied it too thick.
On my T30 I used a kitchen plastic bag and covered my hand with the bag, then spread too little AS5 on the P4-M core and with my finger I spread it, It was a very thin layer.
Like I said, Im still waiting for Zalman to arrive
Current
T440p:
agarza
#112 Post by agarza » Thu Oct 05, 2006 12:38 pm
Zalman rocks!
Current
T440p:
Senser
#113 Post by Senser » Thu Oct 05, 2006 2:41 pm
@benottomex,
So you did apply Zalman? Was it difficult? I'm a bit anxious to open up my T43 since I've got almost 2,5 years of warrenty left..
Dead1nside
#114 Post by Dead1nside » Thu Oct 05, 2006 3:10 pm
I get the same temperatures with AS5, running SuperPi it maxes out at 59degC, running an intense 3D game it gets to 61degC.
agarza
#115 Post by agarza » Thu Oct 05, 2006 3:26 pm
Yes! At last the thermal compound arrived.
It was very easy to apply, with the included brush. You just paint your CPU/GPU/Heatsink too.
This thing works better than AS (IMHO), but it all depends on tastes.
@Dead1nside: Well, this thing is less than one day applied and it has performed very well. the CPU maxes 70C when playing NFS Most Wanted, and the GPU reaches about 75C. About 3-6C degrees off AS5.
Current
T440p:
Dead1nside
#116 Post by Dead1nside » Tue Oct 10, 2006 8:12 pm
Well, I've just done some extensive testing. My thermal paste is only a week or so since I got the IBM tech. whilst replacing the system board (fried GPU) to use my AS5 instead.
I was playing Rise of Nations for 6 hours straight, on the AC so everything going at full.
Afterwards temperatures were:
66degC CPU
75degC GPU
45degC HDD
I haven't experienced any adverse affects, and think that these temps are normal, since it's a laptop and a thin and light one at that.
The FireGL T2 is a reasonably good performer.
agarza
#117 Post by agarza » Wed Oct 11, 2006 7:25 am
Could you try playing Need for Speed: Most Wanted.
My T41p has quite low temps, but my CPU is reaching higher temps because my E7K100 is causing a lot of heat (40-43C) :(
Current
T440p:
nirvana0001
#118 Post by nirvana0001 » Wed Oct 11, 2006 9:34 am
benottomex wrote:Could you try playing Need for Speed: Most Wanted.
my t43p reached 65C after 1 hour playing
Dead1nside
#119 Post by Dead1nside » Wed Oct 11, 2006 11:15 am
I don't think any of these temps are anything to be concerned about.
If it was reaching into the 80s for the CPU then yes, the GPU running that hot is fine, GPUs always run very hot. Hard drive at 40degC is alright, not ideal but the design of the T series means that the heat is very concentrated.
The second HDD I imagine does raise the whole motherboard area temperatures by a few degrees.
agarza
#120 Post by agarza » Wed Oct 11, 2006 12:05 pm
I wonder what's your HDD temp guys.
My CPU reaches about 71C after playing. The GPU about 80-83C.
I can't keep my CPU temp to keep in 35C idling, guess it has to be that the primary HDD E7K100 jumps very high its temp.
Current
T440p:
