Doom 3 problem with FireGL T2?
Has anyone actually tried to run Doom 3 with the IBM drivers? If so what was the result?
Note if you have installed other drivers, be sure to uninstall them and then reinstall the IBM drivers to try it out.
T61P 2.2ghz 4GB 7K200GB 15.4" WSXGA+ Vista 64
HP 2530p L7400 1.86Ghz 3GB 160GB Windows 7 Pro 64
(Hubby) HP 2510p U7500 1.06Ghz 2GB 5K120GB 12" LED WXGA XP Pro
(4 year old son) Toughbook CF-29 1.3Ghz 1.2GB 5K250GB 13.3" XGA XP Pro
mtbiac
Re: doom 3 performance
How in the bloody hell can you run it fine? My laptop is faster than yours and I'm getting about 10fps on the lowest settings. Something is wrong...blackatom wrote:I've played doom 3 for about 7 hours on my T42 so far, and i have to say, i'm extremely impressed at how this performs. I have no trouble running it at 1024x768 in medium quality. Granted it does slow down sometimes if you have 3 enemies on the screen at once, due to the extra poly's and AI running. But i still keep the settings. I even put it on "ultra" quality and played around, it ran at 30+fps in ultra quality, but that was in the very beginning of the game which had no AI running and the rooms weren't very big...still i didn't expect it to be playable at all. I'd recomment 1024x768 at medium if you don't mind it getting a little choppy 5% of the time. And personally i can live w/ the choppy sections that occur rarely.
you can't compare this game to other DX9 games such as farcry or thief 3 in terms of expected performance becuase JC (john carmack) writes incredibly fast code. Not to say farcry has bad code, but doom 3 is just flawless. It's amazing how Halo runs like absolute [censored] and it came out 4 years ago on the xbox and whomever ported it to the pc (forgot the name..but it's not bungie) did a horrible job and made the game run like [censored] respectively.
Doom [censored] rocks, go buy it.
as far as HL2 on these things...we'll have to wait and see
btw i'm running the omega drivers.
1.7ghz, 768, 40 gig 5400rpm, 9600 64meg
which drivers, etc are you using?
etherelithic
i have no problems running doom3 on my laptop either. it slows down a tiny bit when there are a lot of enemies but overall its a good experience. I'm running at medium quality at 1024x768., and I have the 2379-dxu model. I did, however, change the cache parameter in the doom3 config file to 256MB instead of its default of 20mb, and I do have 1gb of ram as well.
mtbiac
since the hardware is the same except for a 9mhz difference, how can there be such a dramatic difference in playability? I've tried every driver possible.Leon wrote:maybe the consistent problem is the FireGL?
I'm now thinking that the problem is related to the 9.0c directx drivers I installed? I'm trying to go back to 9.0b, but its impossible.
any help?
Ditto for me. Only the IBM drivers work. The modded Catalyst drivers do not work.mtbiac wrote:WUHOO
got it working
you have to install the latest video drivers FROM IBM. only way itll work.
I can play at 800x600 at medium quality decently now.
also - you have to set the image_cache to more like 128, its at 20 by default. I'm about to try this and will report back
Thinkpad X200s w/ Ultrabase
C2D SL9600 / 8GB / 160GB X25-M G2 / BD MULTI / 12.1" WXGA / INTEL 4500MHD / INTEL 5150 / BT / AT&T WWAN / W7
mtbiac
ah nice, congrats.
on another note - any idea why I only get 8990 in 3dmark01 with the latest Omegas? I have a friend with an IDENTICAL t42p GVU, but he gets 9600. Only difference is he left his with the factory winXP installed, I formatted and installed fresh XP copy. I installed ALL the drivers, but did I miss something?
thanks
thanks
IIRC, it is REALLY tough to get a playable frame rate with 32MB video ram. High quality compresses textures enough to fit in 256MB VRAM, medium in 128MB, and low quality in 64MB. With 32, you'll have huge dips in framerate as texture data swaps no matter what you do. Unless Doom3 has some nomip setting to completely blur out the textures (which is probably does), but that won't make it much fun.T41mbi wrote:I asked this question to but no one answered. i got a ATI 9000 32MB and was wondering if it would run? (512 RAM) 1.7 -M etc..
For my part, the game loaded up flawlessly (well, with occasional hard-to-notice minor visual artifacts when panning side to side quickly) on my FireGL T2, and I've used both the current IBM drivers and the newest ATI FireGL driver.
Remember that "playable" is very subjective: what is perfectly playable for one person can easily be a nauseating slideshow for another. If I was playing competitively, I wouldn't even dream of playing the game on an LCD, even the new <16ms response time displays, nor would I settle for anything less than a solid 120fps. But just to enjoy the single-player game and bask in the glory of the graphics engine and scripting, a plodding 15-40 fps on a laptop is just fine, if not ideal.
I just cranked the game up to 1600x1200 high quality. Wow. It ain't fast, but [censored] is it pretty, and at least it runs (who would have thought 1 fps would be enough to take out 2 imps rushing you in unison
RoadHazard
Where do I set the image_cache?mtbiac wrote:WUHOO
got it working
This article below benchmarks various video cards and Doom 3. Should give an idea of how well your machine will perform. I find that 800x600 Med quality works well on my T42p.. 1024x768 is playable too, but I think 800x600 is a bit snappier and I don't notice the diff in res much.
Lowest ATI card tested was Radeon 9200.
http://www.anandtech.com/video/showdoc.aspx?i=2146
mtbiac
go to the Doom3 directory, open the config file in notepad, and you'll see a line that says somethign like image_cachemegs "20". Change that to 128 (other values may work better, havent tested this much).RoadHazard wrote:Where do I set the image_cache?mtbiac wrote:WUHOO
got it working
I dont know about you guys, but when running 800x600 at medium quality, its very choppy. Sure, it runs somewhat smooth when NOBODY is around me and no action is taking place, but as soon as a door opens or I see another moving creature, I get bad lagging. Is this normal? I'm still pretty impressed that a LAPTOP can run the most advanced game out there
Sounds about right. I'm also impressed that a "business laptop" can even run a true next-generation game, let alone do so at a framerate good enough to get through single-player. But yes, it is choppy, especially as you get close to a door and it starts predictively setting up new geometry and textures.
Maybe it's about time for a Mobility Radeon 9800! I'm assuming the video chipset is soldered onto the motherboard...what a shame. Oh well, if I wanted an immovable brick to use for gaming, I'd have gotten a Dell XPS
Kenn, hahaha.. the XPS and all those "desktop replacement" laptops that get like an hour tops on a full battery.. what a joke.
I'm so glad I got a Pentium M. Compared to an Athlon 64 or a Pentium 4.
Why not just throw in a X800XT and make the bottom of it about 4 inches thick? It's KINDA portable...
I'm using the latest ATI FireGL T2 drivers from IBM and DirectX9.0c and the game plays exceptionally well. At 1024x768 on medium quality it's playable, but the cut scenes are a bit jerky. I've changed the image cache to 128MB from the 20MB. The graphics and game are superb for the first hour I've had to play around with it. I'll check some other setting and resolution combinations and report the results.
Daniel.
Daniel.
Cgillies86
My T42p runs Doom 3 at 1024 X 768 in "High Quality" Mode Very well only slows down when there is 4+ Monsters on the screen. I have the image_cache set to 640 though. The crazy part is i have a few things running in the background while playing the game so i wonder if it would slow down at all if I shut those programs down. I would also like to point out that I am using the latest IBM drivers for my Fire GL T2.
IBM ThinkPad T42p (2373-KTU)
Pentium M 755 2.0GHZ, 1GB PC2700
14.1" SXGA+, ATI FireGL T2 w/128MB
60GB 7200rpm HDD, DVD-R/RW
IBM a/b/g, Bluetooth, 9-Cell
mtbiac
check this out: http://ucguides.savagehelp.com/Doom3/FPSVisuals.htm
people have reported as much as 20fps gains from these tweaks!! gonna give em a try as soon as I finish formatting and reinstalling the factory windows setup...
- 7 Replies
- 1865 Views
Wed Jan 04, 2017 11:29 am
- 3 Replies
- 1489 Views
Sun Jan 08, 2017 9:49 pm
T410s RAM upgrade problem
by wc85 » Sat Jan 14, 2017 9:22 pm » in ThinkPad T400/410/420 and T500/510/520 Series - 4 Replies
- 947 Views
Mon Jan 16, 2017 12:19 am
WOL (Wake On Lan) T-61 Win7 32bit Problem/Questions
by EAkamai » Sun Jan 22, 2017 4:41 am » in ThinkPad T6x Series - 1 Replies
- 818 Views
Last post by EAkamai
Tue Jan 24, 2017 4:39 pm
