Restore MBR partition
I believe you are using the wrong version of the diskette. If you go to this page.AKCollins wrote:I've tried the rnr32_rd.exe from the beginning of this post, stuck it on my floppy. when i go to start this program a small DOS window pops up and asks me for a compatible drive letter with the diskette.
I type in A or A: and it says incompatible....very odd. Any ideas ?
IBM Rescue and Recovery with Rapid Restore - F11 does not work after uninstalling IBM Rescue and Recovery with Rapid Restore environment
Then click on the Affected configuration link, it brings you here.
IBM Rescue and Recovery with Rapid Restore - List of supported systems
If you click on the Solution link, it brings you here.Supported systems
ThinkPad A31, A31p
ThinkPad G40
ThinkPad R30, R31, R32, R40, R40e, R50, R50p
ThinkPad T23, T30, T40, T40p, T41, T41p, T42, T42p
ThinkPad X22, X23, X24, X30, X31, X40
Rescue and Recovery - Recovery repair diskette
File details
Version: 3.1
Release Date: 2006/05/30
File link File size File description
rnr31_rrd.exe 294,404 Recovery repair diskette
DKB
Notice that the version she is using rnr32_rd.exe is different than the version stated for use with her machine rnr31_rrd.exe. I am not sure which model ThinkPads rnr32_rd.exe is designed for. Right now, I don't have the time to search - have to go to work.ramian wrote:So, the disk should be working with her notebook. That still doesn't explain why the option is greyed out for her...
DKB
It is the rnr31_rrd.exe Iwas attempting to run. The window that opens only lasts for a fraction of a second, so it doesn't appear to work. I apologize I just didn't have the filename in front of me when I made the post.
While looking at the screenshots were there not multiple options one being for thinkvantage (not this machine) and one for the recovery and repair of rapid restore ?
My BIOS here is 1.04 dated 2002. I bought this machine used in July 2004. At the time it had a disk name IBM_Preload. And it was truly factory in the sense it had only Windows 2000, Drivers, IBM support files, DVD player, IBM Record Now, PC Doctor, etc. I have never did anything to change partitions.
The fact that it is greyed out but still [Enabled] gives me hope it is still there, but possibly there is a security setting that needs to be changed ? I have never done anything personally as far as setting security passwords- at the sysytem or windows level.
I thank all of you for your help !!
All The Best,
Amy Collins
Thinkpad A31p 2653-H4U. 760XD (Backup)
A31p...Official laptop of the International Space Station.
Amy Collins
shadowlight
This is the standard name of your C-partition - its not the hidden partition. You should be able to see a FAT32X Partition named "IBM_Service" or something like that from within Windows disk manager at the end of your hard drive - this is the partition you're looking for!AKCollins wrote:At the time it had a disk name IBM_Preload. And it was truly factory in the sense it had only Windows 2000, Drivers, IBM support files, DVD player, IBM Record Now, PC Doctor, etc. I have never did anything to change partitions.
I'm sorry - if you can't see the partition the way mentioned above, I think it's gone. That means they sold you a system without a service partition on it! (happened to me with my X31)AKCollins wrote:The fact that it is greyed out but still [Enabled] gives me hope it is still there,...
Maybe, maybe not. I don't know what year the A31p came out, but it may be old enough to not have the Fat32 Service Partition. One thing to check would be the security setting in the BIOS for the Predesktop Area, HPA or PARTIES - whatever it may be called on the A31p.shadowlight wrote:This is the standard name of your C-partition - its not the hidden partition. You should be able to see a FAT32X Partition named "IBM_Service" or something like that from within Windows disk manager at the end of your hard drive - this is the partition you're looking for!AKCollins wrote:At the time it had a disk name IBM_Preload. And it was truly factory in the sense it had only Windows 2000, Drivers, IBM support files, DVD player, IBM Record Now, PC Doctor, etc. I have never did anything to change partitions.
IBM Rescue and Recovery Deployment GuideVersion 2.0 wrote:These IBM computers were announced prior to January 2003 or computers that have an ImageUltra™ Builder disk image. v Location: A virtual partition that must be installed on the C drive (primary partition of the master hard disk drive) of the computer. v Partition link: :Links to the IBM_SERVICE partition to restore the factory contents or the ImageUltra Builder disk image.
IBM computers that have a PARTIES area were announced during 2003. v Location: A virtual partition that must be installed on the C drive (primary partition of the master hard disk drive) of the computer. v Partition link: Links to the PARTIES partition to initiate a restore of factory contents or diagnostics.
IBM computers with this configuration were announced during 2003 and also have an ImageUltra disk image in the IBM_SERVICE partition. v Location: A virtual partition that must be installed on the C drive (primary partition of the master hard disk drive) of the computer. v Partition link: Links to the PARTIES partition to initiate a restore of factory contents or diagnostics.
IBM computers that are announced in the first quarter 2004 and come with the Rescue and Recovery environment preinstalled feature this configuration. See the following figure. v Location: 100 percent in a type 12 partition. v Location of factory recovery and system diagnostics: entirely in a type 12 partition. v Location of backups: NOT in the type 12 partition. v Partition link: Links to the PARTIES partition to initiate a restore of factory contents or diagnostics. v Advantage of a type 12 partition: When the Rescue and Recovery environment is placed in a virtual partition, several files are placed in the root of the C drive where an end user could possibly delete them. The filter driver does not protect these files because some are common with Windows boot files (for example, NTDETECT.COM). If they are deleted or otherwise become unusable, the end user would be unable to boot to the Rescue and Recovery environment. However, when the Rescue and Recovery environment is placed in a type 12 partition, Windows prevents all users from accessing that partition and the files required to open the Rescue and Recovery environment are highly protected. Note: With the Rescue and Recovery environment secured in the type 12 partition, only a corrupted MBR would prevent access to the Rescue and Recovery. In that case, an external version of the Rescue and Recovery environment must be used. Currently IBM supports CD and USB hard disk drive-based versions of the Rescue and Recovery environment that are created with the Create Rescue Media applet in the Access IBM folder of the Start Menu.
DKB
christopher_wolf
- Special Member
If I recall correctly, the A31 and the A31p were released sometime in March 2002; they don't have the R&R partition set.
The first Thinkpads to have the R&R partitions were the T40 and the R40.
~o/
She does the things you do.
But she is an IBM.
~o/
But she is an IBM.
Then do you have an explaination for the following page and it's links (posted previously above)? I am not trying to contadict you, I am just trying to understand why the following is posted on IBM/Lenovo's site. I don't know much about the A series other than one of my coworkers used to have one (in other words, I know what one looks like).christopher_wolf wrote:If I recall correctly, the A31 and the A31p were released sometime in March 2002; they don't have the R&R partition set.
http://www-307.ibm.com/pc/support/site. ... MIGR-54947
DKB
If you have Acronis_TrueImage or Norton_Ghost, would it be simpler to:
1. Use your disk imaging software to image your current partition.
2. Use your Product Recovery CD's to format HDD & rebuild the hidden partition (and reinstall Windows).
3. Use your disk imaging software to clone the HDD image on (1) back into (3) here, but slightly less HDD space is availble (due to hidden paritition).
christopher_wolf
- Special Member
I believe they are referring to the R&R download by IBM/Lenovo; you don't necessarily have to have the partition to get it to work.GomJabbar wrote:Then do you have an explaination for the following page and it's links (posted previously above)? I am not trying to contadict you, I am just trying to understand why the following is posted on IBM/Lenovo's site. I don't know much about the A series other than one of my coworkers used to have one (in other words, I know what one looks like).christopher_wolf wrote:If I recall correctly, the A31 and the A31p were released sometime in March 2002; they don't have the R&R partition set.
I do, however, find that highly unusual as I cannot recall working on something older than a T40 or R40 that had the R&R partition, as something you could boot into and manage stuff with and no just a partition where you could save backups to boot from, on it. Perhaps and older form of it? I could very well be wrong.
I think that, if the system as the Access IBM button on it, it should have the R&R partition as well.
~o/
But she is an IBM.
~o/
But she is an IBM.
shadowlight
To give you some facts:GomJabbar wrote:Maybe, maybe not. I don't know what year the A31p came out, but it may be old enough to not have the Fat32 Service Partition. One thing to check would be the security setting in the BIOS for the Predesktop Area, HPA or PARTIES - whatever it may be called on the A31p.
I'm writing this on my X31 but my A31p is working and placed next to it.
Under Windows/computer management/disk management (I'm not sure if these are the right english words for it!) of my A31p there is a Partition "IBM_SERVICE" file system"FAT32" status "without error(unknown partition)" size "1.42GB" free space "205MB" at the end of the drive!
"Press F11" is visible and useable on my A31p (not greyed out) and if I press it I can work with the "IBM Product Recovery Version 5.7"
PartitionMagic 8 and Drive Image 2002 are able to see and work with that partition!
Under Windows Explorer the Service partition is not visible or useable.
There is no BIOS option AT ALL which has to do with the settings of the service partition!!!
In BIOS you can only enable/disable boot prompts for F1, F11, F12 each of them individually!
It's completely different with my X31:
Here I have BIOS options to set the partition "secure", "normal" or "disabled".
With setting "normal" PM8, DI2002, Windows Explorer, Windows disk management cannot see or work with that partition! They all think they have a smaller disk available!
With setting "disabled" PM8 could see unallocated space at the end of the hard drive but nothing else!
So far with the facts - and now the question:
Is it possible that IBM after using a hidden FAT32 service partition with the older models (like my A31p) changed it to the HPA/PDA/PARTIES with some middleaged models like my X31 (and the T40 and T41 if they are the same) and changed it back again to a FAT32 type service partition with all _42 _43 and _60 models ???
It's really confusing to me - perheaps we should start an sticky thread in the general forum about the different types of service partitions, on which Thinkpad-model which partition type is used and which tools are working with which partition type to successfully clone it.
I also wanted to add that I had the same problem after installing fresh copy of vista on my T61 with Rescue and Restore 4.0 .
I tried making a bootable cd from the floppy created on my desktop with nero, but did not work giving me an error that "media is write-protected"
I also tried copying files from the floppy to the cd and then bootup using dos 7 and copying the file on the cd to the ram drive. but it didn't work either.
Finally the problem was resolved by making a bootable floppy disk from rnr40_rrd.exe from lenovo support site and borrowing an external fdd from a friend. it repaired the mbr and the things went right.
anyway I learned alot from this topic and thanks to all the people who participated.
T61 | T7300 | nvidia quadro nvs 140m | WXGA+ | 120 GB | Intel Trubo memory
2.4 Kg | Vista Business
Wipe NVMe disk, change GPT to MBR?
by Edward Mendelson » Sat Mar 18, 2017 5:36 pm » in Thinkpad - General HARDWARE/SOFTWARE questions - 7 Replies
- 1131 Views
Last post by Edward Mendelson
Sat Apr 15, 2017 9:51 am
x41 restore partition
by D L Davis » Thu Jan 12, 2017 1:37 pm » in ThinkPad X2/X3/X4x Series incl. X41 Tablet - 6 Replies
- 825 Views
Last post by D L Davis
Mon Jan 23, 2017 3:05 pm
Does it make sense to use mSATA SSD for data partition?
by serpico » Wed Apr 19, 2017 9:14 am » in ThinkPad T430/T530 and later Series - 11 Replies
- 625 Views
Thu Apr 20, 2017 12:36 pm
Create bootable GPT partition for windows 10?
by thinkpadcollection » Thu Jun 22, 2017 6:07 pm » in Windows 10 - 2 Replies
- 121 Views
Fri Jun 23, 2017 12:39 pm
