You won't be so happy when you realize I used your Visa card Dave!GomJabbar wrote:WhoopeeeJHEM wrote:I've just gone through the complete DVD order process and there's no product key displayed at any time.![]()
James
On the link that JHEM provided when he started this thread, the following is posted.tselling wrote:Will Vista install to a specified partition? Or do I need a spare HD?
Additionally, Kyocera posted the following in this thread: http://forum.thinkpads.com/viewtopic.php?t=25546Installation limitations
There are two installation scenarios for Windows Vista Beta 2 (and RC1):
You can do a clean installation. This process will overwrite any data that you have on your hard disk or on your installation partition. The overwritten data will be lost and unrecoverable.
You can upgrade an existing installation of Windows XP.
No other installation scenarios are supported. Upgrading to this beta from any other edition of Windows requires a clean installation, as described in option 1. In addition, once you install Windows Vista Beta 2 (or RC1) you cannot roll back to the previous operating system installation—you will either have to acquire and install the final released edition of Windows Vista or reinstall a previous edition of Windows. Before installing Windows Vista Beta 2 on any computer, please remember to back up all your files.
Note: Please close any open applications before beginning an upgrade. During installation we recommend you have an active Internet connection and choose to “Go online to get the latest updates for installation.”
Kyocera wrote:You can install Vista from inside XP, this will give you dual boot and your recovery partition.
Download the ISO file to your PC
(An ISO file is an exact representation of a CD or DVD, including the content and the logical format. Once you download the ISO file, you’ll need to burn it to a DVD before you can install the software.)
Go here http://www.daemon-tools.cc/dtcc/downloa ... ry&catid=5I finally got the download, and have an ISO, but........I don't have a DVD burner!!!!! Does anybody know what I can use, if anything, to "bust" this ISO and maybe copy the files to an old hard drive, or a "few" CD's?
Office 2007 runs great under Vista, as well as a few other MS Betas, but that's about it for now.kulivontot wrote:My experience with beta 2 is that there are not enough applications fully supported and working for it right now for it to be usable as a primary OS.
