Vista BETA Available for Download!
pemoz
thinkpads.com customer
#61 Post by pemoz » Wed Jun 14, 2006 1:23 pm
I have heard a few not be able to install the ultra nav driver, I can tell you that i did it but had to use compatibility mode, same with ATI.
Well I have tried to install with the comp mode but I get silly error messages like "another user is using this software" so no luck there... btw thanks for your quick mail earlier today kyocera...
so I will see if this upgrade works in just a few minutes... shure hope so
UPDATE
no it didn´t work... [censored].. seems to be no way to get my dear Ultra nav to work with Vista...
IBM ThinkPad T42p 2373KXU 1.5GB Ram 60GB/7200 rpm-drive 15"1600*1200 screen
jjesusfreak01
#62 Post by jjesusfreak01 » Wed Jun 14, 2006 4:10 pm
Kyocera wrote:I have heard a few not be able to install the ultra nav driver, I can tell you that i did it but had to use compatibility mode, same with ATI.
The ATI driver? What do you mean? ATI has a Windows Vista Beta 2 driver available, which can be installed with no compatability options checked. The Ultra nav worked on my system with no drivers installed.
Kyocera
#63 Post by Kyocera » Wed Jun 14, 2006 4:54 pm
OK, OK calm down, I've been running build 5308 for a while now and there WERE NO ati drivers for my t42 available back then. If there are now that is great. And people have been having trouble with their ulra nav as some have posted here , so it is also great that you have not had trouble.
Pemoz, I can tell you I had to install hydra vision before installing the ati driver to get it to install correctly, initially i thought this was a fluke so I wiped the drive and started again just to test this out and (on my system, t42 with Vista build 5308) it works if you install hydra vision first. These drivers are right out of the IBM TOOLs > drivers folder.
jesusfreak, hope you didn't get flooded out today, I was all over Raleigh and Durham this morning and it was freakin awful.
cybercorsair
#64 Post by cybercorsair » Wed Jun 14, 2006 5:58 pm
dorronto wrote:Gee, must be nice to download the 3.2gb program. With my cable modem, Microsoft estimates something like 34 or 54 hours!!!!!!!
That seems to be a bit long in the tooth....What's your internet servers rate of transmission? How many gigs per minute?
I would like to download but it would take way too long...
Have fun :D
Ron
?? wow you are getting some bad speeds from MS there guy I like did it in 3 to 4 hours on SBC/AT&T DSL...and on my A31
Even one sshould go read the reviews and all on Vista and laptops.
There are some big limits to what systems can handle Vista in full mode with Aero Glass you need 128 meg to 256 meg of graphic memory alone. and Ideal system would be 2.0 gig CPU 256 DDR video memory graphic card and 2 gig Ram or and 20 gig of HD space(but I think some said you can get way with 15gigs)....Vista is a monster OS and I only plan on running bata on a desktop for testing and all . I also hear MS has anothere OS modle in the works to replace this so ...beware of another ME as vista could just be all eye candy and Bloatware(definitaly Bloatware)..I seen only a few Thinkpads that could handle Vista dn all were newer models. on older one you will get at best a a desktop that look and acts as XP....
Later..
CC
KristianJ
Moderator1
Moderator1
#65 Post by KristianJ » Thu Jun 15, 2006 3:26 am
Just found this email in my inbox:
Dear Kristian,
Thank you for visiting the Microsoft Direct Fulfillment website and your interest in obtaining Windows Vista Beta2.
Microsoft has identified that you may have encountered difficulties with our site as a result of the overwhelming response to the launch of Windows Vista Beta 2. We sincerely apologize for any inconvenience caused and would like to provide you with a complimentary copy of Windows Vista Beta2 shipped via courier. You can expect to receive your product within a week.
We have also been notified that the error experienced may have inadvertently resulted in multiple charges being placed against your credit card. Microsoft has already engaged the relevant bank to reverse all charges made to your card for this particular order and this should be reflected in your next credit card statement. Should this not be the case please email aporders@microsoft.com for assistance.
Thank you for your patience and understanding.
Kind regards
Microsoft Regional Sales Corporation
Hopefully this will come to pass...I'm not sure whether my card was charged more than once, but if I end up getting a freebie no complaints from me :D
X220 4291-46M
HP Pavilion dv7-2109tx
KristianJ
Moderator1
Moderator1
#66 Post by KristianJ » Thu Jun 22, 2006 7:45 am
Got the DVD yesterday and decided to take the plunge today. Pretty disappointed, actually - there's nothing that convinces me that I should move away from XP.
X220 4291-46M
Buccaneerfan
Ultranav
#67 Post by Buccaneerfan » Thu Aug 17, 2006 11:06 am
Hiya,
my first post here...
Has anybody got any hints on why i seem to be unable to install the ultranav drivers on my z60t 2511-3BU with Vista Beta 2 Build 5384?
The software seems to install, although i have to restart the installation midway through the process but i can't find any entry under programs and the device manager only shows a ps/2 mouse.
I used the latest package for ultranav from the Lenovo website.
Apart from that Vista runs okay, the high def audio driver doesn't really install itself permanently but the rest is okay.
Z60t 2511-3BU
R30 2656-E0G
T60 1951-YBB T7600 3GB Vista Ultimate
T60 1951-YBB T2400 2GB ubuntu 7.10
X60s 1704-6DG
Kyocera
#68 Post by Kyocera » Thu Aug 17, 2006 11:16 am
Try using compatibility mode when you install it. There is some discussion back through this thread on that.
Buccaneerfan
#69 Post by Buccaneerfan » Thu Aug 17, 2006 11:33 am
Kyocera wrote:Try using compatibility mode when you install it. There is some discussion back through this thread on that.
Yeah, i read that, but it doesn't work. The install script tells me the it needs W2K or XP to function and stops after that.
Z60t 2511-3BU
R30 2656-E0G
X60s 1704-6DG
