How long should a TP keep working?
How long should a T4x work without failure?
One year
1
1%
Two years
2
3%
Three years
27
34%
Forever
49
62%
Total votes: 79
JPOESQ
**SENIOR** Member
**SENIOR** Member
#31 Post by JPOESQ » Wed Jun 14, 2006 10:52 pm
It should last 5 years, at least.
Now, my T41p died after 2 years. The system board had to be replaced, and the replacement system board died 3 weeks later. I've been waiting 2 days for onsite repair. Maybe the 3rd day will be the charm. Everytime I call to ask when the tech is coming, I am given stories about the case being closed, the tech supposed to be coming but no show...
John P. O'Banion, JD, PE, BSEE
Registered Patent Attorney
http://www.intellectual.com
600, X61s, X220, X230, T530
egibbs
#32 Post by egibbs » Thu Jun 15, 2006 5:47 am
JPOESQ wrote:I've been waiting 2 days for onsite repair. Maybe the 3rd day will be the charm. Everytime I call to ask when the tech is coming, I am given stories about the case being closed, the tech supposed to be coming but no show...
You're an attorney and you're sitting still for that crap? Wow - patent lawyers must be a pretty laid back bunch. Maybe it comes from dealing with the Patent Office - slow seems normal. :roll:
Are you billing them for the time?
Ed Gibbs
JPOESQ
**SENIOR** Member
**SENIOR** Member
#33 Post by JPOESQ » Thu Jun 15, 2006 8:38 am
Ed Gibbs
I should bill them for my time. But, being an attorney doesn't help at all - they can still hang up on you!
Now, I could take them to task, but I would spend more money fighting with them than a new machine would cost.
And, yes, the Patent Office is a slow bunch. We will submit a patent application and if you are lucky, it will be examined within 2 years. 5 years is not unheard of for some technologies. Job security...
kimsn
#34 Post by kimsn » Sun Jul 02, 2006 8:20 am
My ThinkPad is now 3 years+ without problem. I do not expect for forever but I think I can use it for next 5 years+.
T-40 (2373-72A), 1.5GHz, 2GB, WD1200VE, MultiBurner, Bluetooth
rhema83
#35 Post by rhema83 » Mon Jul 10, 2006 3:29 am
I had to pick "forever" because 3 years is miserably short for a well-built laptop like a Thinkpad. I am expecting my T42 to last through college and graduate school.
X61 7675-CTO Merom 2.0GHz 4GB RAM, 7K200 HDD
gunston
#36 Post by gunston » Mon Jul 10, 2006 3:43 am
i am aiming for 5 years+ too
2. X60s 1703-CA3 powerful
TarzanBoy
#37 Post by TarzanBoy » Mon Jul 10, 2006 12:34 pm
christopher_wolf wrote:Having the system work, essentially, forever isn't impossible. As long as you treat any existing problems and prevent future ones with due dilligence, it should work fine.
I disagree. It can't/wont' work forever. Even if you treat all the electronic failures, there are mechanical failures that will inevitably occur and material failures (the air you breath has corrossive gases in it which eventually take their toll on small electronics) as well.
Assuming 100% 'normal' use...the two items I would expect to go first on a laptop would be either the power source (or where it comes in on the mobo) or the hard drive. These two items undergo the most 'shock' when a system powers on and off. The hard drive has the most moving parts (motors, heads, magnets), so its the leading contender for mech failure. There are bearings, lubrication, coiled wires and magnetically coded bits of data to worry about.
When computers make the move to Flash-type permanent storage (i expect it within the next 5 years) then corrosion and power surges will be the leading causes of hard drive crashes
christopher_wolf
Special Member
#38 Post by christopher_wolf » Mon Jul 10, 2006 3:32 pm
True, but those take quite a *long* time; by then you will either *have* to upgrade or you will be having serious hardware issues yourself. ;)
If you take good care of the equipment, it will last far longer than the average market lifespan of such devices; so much so that it could be considered, "forever." Not in the cosmological or astronomic time scale sense, but in the sense that, given the timespan the user in their lifetime will have a computer form birth to death, it will be a very long time. :)
~o/
She does the things you do.
But she is an IBM.
wiresounds
#39 Post by wiresounds » Mon Jul 10, 2006 4:28 pm
I got my T41 for 27 months and it worked for 24/7. It is off only when it is transported from work to home and the opposite, a ten minute walk.
Lately I sometimes get “fan error” during boot. I have contact the service for an inspection and a possible later fan replacement. I asked the gentleman over phone, that if I will supply them with an up rated cpu how much the will charge me. He said “none, it is only one screw” during the fan replacement. I love me Thinkpad.
I will upgrade the cpu and I hope it will last 5 or more years.
PS. The Thinkpad is been used as a DAW (Digital Audio Workstation)
T41 23733JG,14.1''xga,ATI9000,CDR/DVD,BT,GigaLAN
upgraded:Dothan 2.1 undervolted,2GBram,120GB@5400 Seagate Momentus,Intel 2915,Ultrabay battery,DockII, BT GPS
PCMCIA cards:firewire,AverMedia AVerTV Hybrid (DVD-T&Analogue TV-FM radio-Svideo in)
sugo
#40 Post by sugo » Mon Jul 10, 2006 6:48 pm
I would expect 3 years to 4 years on average.
X61
jrw
#41 Post by jrw » Wed Jul 12, 2006 11:08 pm
I also think that 3 to 4 years sounds about right for normal use of a laptop (even if a laptop gets abused), although, if a laptop is well taken care of, I think that 5 years to over a decade are not unrealistic expectations if the laptop was well-designed.
