Anyone pull a key off the keyboard before?
Hi, my thinkpad's spacebar is getting finikie. About half the spaces I push aren't detected and I always hit the space with my right thumb. If I hit it with my left thumb or right in the middle, it works okay just doens't like the right side.
So im hoping it would be like a normal keyboard where I could pop off a key and clean it a bit but I pried a little and somehow doubt its that easy.
So any info?
So any info?
T20
850mhz, 256mb, T21 hsf, 14.1" (messed up screen), 20gb drive, SMC2532W-B
I'm not sure about removing the keys themselves, but the keyboard itself is not hard to pop off. For my T21, which should be similar to yours, there are two screws somewhere in the middle of the bottom of the laptop to remove. Then, by removing the battery, there's access to the keyboard from below. Just press up from underneath and carefully pop the keyboard out from above.
If you're not able to re-work the key at this point, you can get keyboards from ebay for under $20.
its easy, remove the batteries, take out the 2 long screws underneath that have arrows pointing to them. After that look where the batteries were and ull see a metal plate, push that up, it just pops off. I had to remove mine too, after that clean it then it will snap back into place then just screw back in.
IBM Thinkpad T21 / 800Mhz / 256MB RAM - upgraded from 128MB / 20 GB HDD / DVD ROM / Windows XP
Item #8 in the FAQ.
Jane
I'm on Twitter
I'm on Twitter
If I understand the OP correctly, the question is not how to remove the keyboard, but a single key. These information can not be found in the HHM or FAQ
IBM TP T41p (1.7G/1GB/100GB-7k100/DVD-CDRW/SXGA+/BT)
IBM TP T22 (900/512/40/DVD/CDRW/14")
IBM TP A31 (1.8GHz/512MB/40GB/DVD-CDRW/15" SXGA)
For sale: n/a
WTB: n/a
Er yeah
I have taken my thinkpad down to the empty case before (dead mobo)
I just want to find out if I can pry my spacebar off safely so I could maybe clean it a little under beause its no longer responsive.
btw, no input on http://forum.thinkpads.com/viewtopic.php?t=26869 ?
I have been eying the T23 but dont know if its a gamble worth taking.
Might be worth it for the keyboard >__< then sell the rest here
T20
I have a picture of a couple of keytops removed from a 600X keyboard at:
http://www.rkawakami.net/ibm_600x/trackpoint/
Doesn't look like you can get at anything to clean from the top side of the keyboard.
From the pictures of the 600X keyboard, the keys appear to be attached in the same manner as every keyboard I've seen.So im hoping it would be like a normal keyboard where I could pop off a key and clean it a bit but I pried a little and somehow doubt its that easy.
In most cases, the spacebar is attached with a wire about the thickness of a paperclip instead of the 2 white plastic holders pictured.
Good luck.
Thanks for that link
I tried prying it up but I think it has two of those clippy things on each side and the wire thing. And for some reason I think the button the spacebar depresses is stuck to the key itself as well.
>_< I will learn to spacebar with my left thumb.
T20
The clippy things have a rubber like thing under them. The one on the right is probably getting worn from use. If you are careful you can remove the two clippy things and put the worn one on the left. But it takes alot of patience to get them put back properly.
T61P 2.2ghz 4GB 7K200GB 15.4" WSXGA+ Vista 64
HP 2530p L7400 1.86Ghz 3GB 160GB Windows 7 Pro 64
(Hubby) HP 2510p U7500 1.06Ghz 2GB 5K120GB 12" LED WXGA XP Pro
(4 year old son) Toughbook CF-29 1.3Ghz 1.2GB 5K250GB 13.3" XGA XP Pro
okay thats kinda the data I wanted, well wanted a more optimistic view but thats still info that I wanted.dsigma6 wrote:two times i removed a space bar from a laptop, and two times it was never the same after that.
Im used to standard keyboards so I just grab the screwdriver and pry.
T20
are there 86-key keyboard drivers that I need?
by xtian170174 » Fri Apr 21, 2017 1:42 pm » in ThinkPad Legacy Hardware - 5 Replies
- 703 Views
Last post by xtian170174
Sun Apr 23, 2017 2:20 pm
TRADE: US keyboard for UK keyboard, Backlit/Chicony for T430/T530/W530/X230
by RealBlackStuff » Tue Apr 11, 2017 6:25 am » in Marketplace - Forum Members only - 0 Replies
- 268 Views
Sat Apr 15, 2017 9:01 am
- 3 Replies
- 620 Views
Last post by Brad
Tue Jan 03, 2017 1:27 pm
Broke middle scroll key x230
by blink » Sun Feb 19, 2017 9:20 pm » in ThinkPad X230 and later Series - 3 Replies
- 502 Views
Last post by blink
Tue Feb 28, 2017 9:04 pm
