I have the Software Installer ver 3.61.0609 installed on my T41p (2373-GEU). It is doing a couple of strange things.
1. It thinks that I have InterVideo WinDVD 4.0-B11.270 and it wants to install 4.0-B11.280. If I allow that to go, the installation fails. When I start WinDVD I see that it IS version 4.0 DXVA B11.280C14.14125.0000D00000. Nevertheless, the software installer wants to do this every time. Is there some installer file or installer data corruption that I can fix?
2. It wants to install Intel ProSET 6.4.0.0 and says it is required but not installed. Nevertheless, when I do Start -> Programs -> Intel Network Adapters -> Intel PROSet for Wired Connections -> Help -> About it says version 8.2.0.0.
Then that program sees two different "Network components:. The first is labeled '11a/b/g Wireless LAN Mini PCI Adapter" and it has driver version 4.1.102.1095. The second one is labeled "Intel(r) PRO/1000 MT Mobile Connection" and it has driver 7.2.12.101.
So, has anyone else experienced this problem? Is there anything I can do to fix these confusing offers by the software installer?
Should I delete anything from the C:/DRIVERS directory that might be causing some confusion?
The Software Installer has generally worked quite well in the past.
Thank you very much.
Software installer strange behavior
600e (needs a replacement HD)
T20 (2647-44U, needs a win98 install disk to rebuild vmm32.vxd)
T23 (2647-HNU, pulsing fan, won't boot)
T41p (2373-GEU, works perfectly)
T61 (7658-CTO, works perfectly)
For the WinDVD problem I suggest you just select that it should ask to install that again.
As far as I remember it is possible to check a box after download but I might be wrong and that it's only System Update that offers that option.
IBM X41 2527-67G
12.1", 1.5 GHz, 1024 MB DDR2, 40 GB 4200 RPM 1.8" HDD, 1.3 kg w. 4-cell battery, 1.5 kg w. 8-cell battery
Strange AC/battery behavior after teardown
by Sweater Fish Deluxe » Fri May 05, 2017 12:38 pm » in ThinkPad T400/410/420 and T500/510/520 Series - 2 Replies
- 561 Views
Sun May 07, 2017 1:53 pm
Restoring CTRL-FN behavior
by whitelabel » Sun Mar 19, 2017 2:53 am » in Thinkpad X6x Series incl. X6x Tablet - 0 Replies
- 873 Views
Last post by whitelabel
Strange webcam issue with T500
by Kaervak » Sat Jan 21, 2017 10:57 pm » in ThinkPad T400/410/420 and T500/510/520 Series - 6 Replies
- 926 Views
Last post by Kaervak
Sun Jan 22, 2017 5:53 pm
- 3 Replies
- 531 Views
Last post by luca9903
Mon Jun 12, 2017 7:02 am
