T22 RAM problem
Good to hear that! I was just going to check USPS to see if it had been delivered yet. Hope not to hear that you got a re-visit from that fellow named Abbie Normal
OH MY.
I've abandoned my T23 for sometime after having the same problem, and today, i glanced over the thinkpads forum and now there's a solution for this.
rkawakami,
geez man, where'd you acquire those memory fixing skill ?
i think i'm having the same problem with those SPD thingy, should i just replace my memory ? which i doubt i could figure out if the new sticks is going to have the correct SPD bits.
ps.
reading your other thread, i'm using a high density 256mb memory, 4 chips on each side.
should i try replacing it with a low density memory ?
rkawakami,
ps.
Should be no need to do that. The T23 is able to use high density modules. The 512MB sticks I have in a couple of my systems have a total of 16 parts on them. The 256MB version have 8.vladb wrote:ps.
An update on my problem,
i decided to run memtest86+ for a longer period today and after a couple of passes it found many errors on test #5.
Checked on google,
there are dozens of people experiencing this error also.
I wonder if this is the reason i get hangup & freeze problems.
I've ordered for a new T23 systemboard,
and tomorrow i'll check my memory module using a friend's T23.
ps. Thanks for the help ray, =)
Checked on google,
X1 Carbon (5th gen, 2017) : 8gb Ram or 16gb Ram , i5 or i7
by asterinex » Tue Apr 25, 2017 4:12 am » in ThinkPad X1/X1C - 26 Replies
- 2020 Views
Last post by w0qj
Sat Apr 29, 2017 11:22 am
- 3 Replies
- 1489 Views
Sun Jan 08, 2017 9:49 pm
T410s RAM upgrade problem
by wc85 » Sat Jan 14, 2017 9:22 pm » in ThinkPad T400/410/420 and T500/510/520 Series - 4 Replies
- 946 Views
Mon Jan 16, 2017 12:19 am
Thinkpad X220 RAM upgrade problem
by staki » Fri Mar 17, 2017 9:06 am » in ThinkPad X200/201/220 and X300/301 Series - 3 Replies
- 2019 Views
Last post by jdrou
Mon Apr 10, 2017 7:16 pm
