Upgrading T21 CPU to 1GHz
nikki605
#31 Post by nikki605 » Mon Feb 05, 2007 10:52 am
Oops! :oops: Either I can't read MobileMeter, or I can't type. A re-check shows my idle temp to be around 38 to 41°C. Sorry 'bout that!
Gary A.
lenovo: T410 (2516-CTO) | i7-620M | 8GB | 320GB 7200rpm | WXGA+ | WiFi 6300 | Bluetooth | Webcam | DVD-RW | 9 Cell | Win7 Pro x64 | Full System Specs
IBM: T21 (2647-47U) | PIII 1GHz | 512MB | 60GB 5400rpm | 3Com Mini PCI Ethernet/56K | DVD-RW | WinXP Pro SP3 | Full System Specs
furiousmonkey
Ok this forum is getting large!
#32 Post by furiousmonkey » Tue Feb 06, 2007 6:41 pm
I have been doing some research about the 1gig chip, I really want to upgrade my T21.
There are different chip names like SL5TF, and SL5CH
Mobile Intel Pentium III 866MHz - M fru# 26P7999 N
Mobile Intel Pentium III 1.0GHz - M fru# 26P8122
Mobile Intel Pentium III 1.13GHz - M fru# 26P8082
Mobile Intel Pentium III 1.2GHz - M fru# 26P8005
I would like to know, what will work and what wont, can you go beyond the 1gig with a 1.2Ghz? Which 1Ghz processor works?
Gerbil
Re: Ok this forum is getting large!
#33 Post by Gerbil » Tue Feb 06, 2007 11:58 pm
I had the same question. I think I found the answer.
The SL53S is a 495 pin chip. There are no PIII's beyond 1.0GHz with the same number of pins. Thus, no fit.
furiousmonkey
upgrading the MOBO
#34 Post by furiousmonkey » Mon Feb 12, 2007 3:35 pm
How about putting a T22 MOBO in my T21 case, is that possible?
AlphaKilo470
#35 Post by AlphaKilo470 » Mon Feb 12, 2007 4:47 pm
It's possible but pointless (unless you have a bad mobo) as the chip socket is the same.
furiousmonkey
MOBO
#36 Post by furiousmonkey » Mon Feb 12, 2007 5:51 pm
How about the T23? they support up to a 1.2? is there anyway of hacking it into the laptop?
larryb
#37 Post by larryb » Tue Apr 03, 2007 6:53 pm
did anyoone do the above 1.0Ghz moditifaton to a T20.
Did it work without clock modificatons?
Larry
pudu1951
#38 Post by pudu1951 » Wed Jan 30, 2008 4:39 pm
vlyne wrote:Below is my attempt at compiling a list 1Ghz CPUs for the T20/21/22 series from this site:
Part# CPU_Speed BUS_Speed Mfg_Tech Stepping Cache Package
SL58S 1 GHz 100 MHz 0.18 micron PD0 256 KB 495 pin
SL53S 1 GHz 100 MHz 0.18 micron PD0 256 KB 495 pin
SL5TB 1 GHz 100 MHz 0.18 micron BD0 256 KB BGA2
SL54F 1 GHz 100 MHz 0.18 micron BD0 256 KB BGA2
SL5TF 1 GHz 100 MHz 0.18 micron PD0 256 KB Micro-PGA2
FWIW: The Micro-PGA2-package has 495 pins: see
<http://www.intel.com/support/processors ... Bottom.jpg>
HTH
pudu1951
furiousmonkey
T21
#39 Post by furiousmonkey » Thu Jan 31, 2008 12:34 pm
What I did with my T21, was pull the bottom off of it and purchased a complete used T23 1.13Mhz from ebay, I had to "Trim" the plastic off the top left hand side of the T21 (Thats left as you face the screen)
It fit, I then added 1024Mb of PC133 RAM, and a 100Gb 7200 RPM Hdd.
Truth be told its more economical to just purchase a faster used one, but its not as fun, especially if you love to do stuff like this!
I use it all the time, I have some older games I play on it. But if you want a good package, purchase a used T30 they come with the Radeon 7500 Graphics Chip, even if only one RAM slot works, you can still put 1024Mb of Memory into it, plus the Bus Speed is faster.
1400i 366Mhz 128Mb Ram
1300i 750Mhz 320Mb Ram 60Gig
T23 1.13GHz 1024Mb Ram 100Gig
T30 2.4GHz 1024Mb Ram 160Gig
T30 2.4GHz 2Gb Ram 120Gig
T60 1.8Ghz Duo 3 Gb RAM 80Gig
George
#40 Post by George » Sat Nov 22, 2008 3:45 pm
Question about replacing a T21 Fan/Heatsink, with the T22 Fan/Heatsink, which per this thread is P/N 26P9254 / FRU 26P9317:
I have accomplished the 1.0 GHZ CPU change and like the improved performance in my T21 (800 MHZ). I just want to run it a little bit cooler, per NHC.
Can I use the original 4 screws which secure the T21 fan unit? Or need longer screws?
Do I need the "Tension Brace-Bracket" which goes under the 4 screws and sits on the T21 Fan unit? Is there a T22 Specific bracket, or will the T21 bracket fit?
Looking in Ebay, I see lots of T22 Fan units. Some show the "Bracket", and some do not. Some come with screws and some do not, leaving me with questions.
I appreciate any suggestions
George
Venice, Florida
570E (500 MHZ) (320 MB)
600X (650 MHZ) (576 MB)
T21 (1 GHZ) (512 MB)
A31 (2 GHZ) (2 GB)
T60 (1.83) (3 GB)
nikki605
#41 Post by nikki605 » Sat Nov 22, 2008 3:54 pm
George,
When I did mine, I bought just the fan assembly and reused the original bracket and 4 screws. Worked fine! The only thing I found I had to do was trim the plastic CRU Insulator with a pair of scissors so that it didn't touch the larger heatsink.
Gary A.
George
#42 Post by George » Sun Nov 23, 2008 1:29 am
Gary,
Thank You! Exactly what I needed to know.
George
Venice, Florida
A31 (2 GHZ) (2 GB)
T60 (1.83) (3 GB)
nikki605
#43 Post by nikki605 » Sun Nov 23, 2008 9:17 am
You're welcome. When you install the T22 fan, don't forget to properly clean the CPU & heatsink surfaces, and apply a fresh coat of quality heatsink compound (thermal grease) like Artic Silver. It makes a big difference in keeping the CPU running as cool as possible.
Gary A.
