Rule of thumb for laptops: If it is too hot, it is not so cool.gunston wrote:well,
frankly speaking, i don't feel hot in Right Wrist palmrest of X60s
Right Wrist Pad Area Overheating
First Light
Our X60s does have a very warm right palm rest but we expect that when we're doing cpu-intensive projects. Ultraportables are not designed to be doing number-crunching all the time; we save that for our T43p which runs up to 75 decrees C! Interestingly, the palm rests remain cool but the fans run on high.
Otherwise, our X60s runs silent and relatively cool under normal applications. No complaint here.
Some may have a faulty unit.
Good luck!
CJ
Good luck!
CJ
Maybe true, but that doesn't mean the X60 is exempt from being able to run hard while still being reliable and maintaining a reasonable operating temperature that's comfortable to work with.cj3209 wrote:Ultraportables are not designed to be doing number-crunching all the time
That said, my X60s runs pretty well. The right palm rest gets warm, especially when charging while in use, but hasn't given me any cause for concern yet. It's lucky that I tend to use my left hand for controlling the pointer though. If I used my right I would be resting my hand above the hottest part of the machine and contributing to the problem.
WirelessAndy
Hi everyone, here is a comparison of;
1. x60 - 1.6Ghz Core Solo - Intel Wifi
2. x60s - 1.6Ghz Colo Duo LV - Intel Wifi
x60 idle wifi off - fan cycling
cpu 43
aps 39
gpu 41
bus 36
pci 36
x60 idle wifi on - fan nearly on all the time
cpu 37
aps 46
gpu 36
bus 36
pci 32
x60s idle wifi off - fan off
cpu 42
aps 38
gpu 41
bus 34
pci 34
x60s idle wifi on - fan cycling
cpu 47
aps 46
gpu 43
bus 36
pci 36
Overall the x60s has a quieter fan and which cycles less compared to the x60, both have hot rests though once wifi is switch on.
cpu 43
aps 39
gpu 41
bus 36
pci 36
cpu 37
aps 46
gpu 36
bus 36
pci 32
cpu 42
aps 38
gpu 41
bus 34
pci 34
cpu 47
aps 46
gpu 43
bus 36
pci 36
Warm right palm rest
Well, this is a really tired thread, but since I recently changed WiFi cards, I thought I'd add an observation.
I haven't done scientific studies, but comparing when my laptop had the Intel wifi card, with having the current atheros card, there is no perceptable difference between the surface temperature (to me). I think some people have wondered about this on other threads...
If the Wifi is turned off, the entire laptop runs very cool (including the wrist rest). If the Wifi is on, the right rest above the wifi card is warm...not burning my hand, but I don't rest my hand there more than I need to. When I'm at my desk I always plug in an ethernet cable so the radio will turn off and my palm rest will be more comfortable.
I am a little bothered by this, because my X30 also had internal Wifi and I didn't have this small annoyance to think about. The wrist rest never rose above room temperature (except if warmed by my hands, of course).
I wish that for the X60/X60S, Lenovo's designers had found somewhere else to put the Wifi card than under the palm of my right hand, or had designed a way to remove its heat other than radiating it through the palmrest into my hand....ergonomics is a major reason why I buy Thinkpads. Maybe all the static on these threads will help prioritize future design decisions and my next Thinkpad (X90?) will be more like my X30 in this respect
However, this is the ONLY thing I think is poorly designed about my X60S, and I'm definitely loving it and keeping it!!!!
X60S, 3GB RAM, Vista x32
X61T, 4GB RAM, Vista x64
X61, 4GB RAM, Vista x64/Windows Server 2008 x64
X30, 1GB RAM, Windows XP
NJ_IT
My case is different from yours.>keruibo
After I changed Intel card with Atheros card, I clearly noticed Atheros was hotter than Intel.
And measured by tpfancontrol,found Atheros was 4~5degC higher than Intel.
Not very hot ,but it is a bit uncomfortable to me.
X60Tablet (6366AJU:Replaced 12"SXGA+)1.83GHz,4.0GB,Fujitsu MHZ2320BH G2(320GB/5400RPM),Atheros Wifi,3yrs.
T60P(200784U)2.16GHz,2G,100G7200RPM
atheros temp
NJ_IT,
4-5 c is significant, don't know why I haven't noticed it, but I trust your data is correct.
Thanks for posting the data!
What were your actual temperatures with the Atheros card?NJ_IT wrote:My case is different from yours.
In my computer, on AC (battery fully charged), WiFi on, only doing email, I get
CPU 45
APS 49-50
GPU 44
BUS 44
PCI 39
Fan = 3022 RPM - I can't hear it above the background noise in the room. TPFancontrol program suggests the fan is responding to the highest temperature = APS.
Right palm rest is not burning, but it does not encourage me to rest my hand on it with any pressure. Like keruibo, I like my X60s -- much more than my X40. Still, I wish the palm rest was cooler. I wonder what is different about gunston's unit.
Gunston, did you ever measure your APS and CPU temperatures?
T40p. T42 and X40
X60s 1704-69U, 2GB Ram, 100GB HD
NJ_IT
X60: Hot CPU(Not X60s),AC operation, Web surfing, Atheros wifi card,>ozmann
CPU 55-C (0x78)
APS 49-C (0x79) ---- (Changed within 48- 50degC)
GPU 53-C (0x7b)
BAT 36-C (0x7c)
BAT 34-C (0x7e)
BUS 44-C (0xc0)
PCI 43-C (0xc1)
FAN: 2914RPM
If wifi off: APS goes to 43degC
But Atheros provides very stable connection under Access Connections.
And much sensitivity. I love it!
My temps (atheros)
Plugged into A/C power, battery is not charging, atheros wifi running:
CPU 51°C (0x78)
APS 52°C (0x79)
GPU 50°C (0x7b)
BAT 34°C (0x7c)
BAT 33°C (0x7e)
BUS 44°C (0xc0)
PCI 41°C (0xc1)
Fan speed: 2979 RPM
CPU 51°C (0x78)
APS 52°C (0x79)
GPU 50°C (0x7b)
BAT 34°C (0x7c)
BAT 33°C (0x7e)
BUS 44°C (0xc0)
PCI 41°C (0xc1)
Fan speed: 2979 RPM
asiafish
- thinkpads.com customer
X41 had the wifi card on the bottom of the computer next to the memory slot, which I think it is a better place for it as all heat generated goes up into the keyboard, out the sides or down into the bottom case. On or off makes no difference in temperature felt by my hand and only a tiny bit on my lap.
Still, even with the X60s placement I think it would be a minor issue. The X41's tiny hard drive is right under the left palmrest and can get pretty hot, similar or perhaps even warmer than a wifi card, but not enough to interfere with its use in any way.
Richard Dawkins, 2002
Oh, you're absolutely right, it's seems common for laptop designers to put hot equipment under the palmrest (even if I wish they wouldn't). My computer at my last job was an HP zd8000, and the palmrest--and even part of the keyboard--seemed hotter than my X60S is.The X41's tiny hard drive is right under the left palmrest and can get pretty hot
Although I miss the room-temperature palmrest of my X30, as you said the temperature certainly doesn't interfere with its use...I don't think about it that much.
I still think the X60S design is way, way ahead of the competitors in its class. Before replacing the X30 with X60S I looked at Dell, HP and Sony, and it took very little time to make my decision.
WirelessAndy
asiafish
The reason they put hot components under palmrests is that there is nothing else there that can be damaged by heat.
First Light
asiafish
You must have VERY delicate hands.
Interesting thread, couple years back ( actually 2003 ) I spent a lot of time trying to figure out improvements to cool the palm rest of Dell D600. Posted under the same name rssb.
The Dell's released in Feb 2005 have implemented some of these features. ( esp D610 )
http://forums.us.dell.com/supportforums ... ing&page=3
Anyone who has used a T40 /41/ 42 can clearly see D600 is much thicker than these models. yet the palmrest on the thinkpads is much cooler.
So I kind of disagree with Saml01 's response that one should be satisfied with the fact that since they packed so much in a tiny space, it is bound to heat up.
The problem is poor design or lets say lack of a better design, there is always scope to improve things. Whether the amount of money / effort that is put in to build a better product which justifies thier profits generated is the controller.
What has kept the thinkpads above the rest is the quality ( whether it is hardware / software or IBM service ).
asiafish
Compare the T4x to the X6x/X4x and you will see that while much thinner than the Dell, it is still much thicker than the X-series. The fact remains that the palmrest is an area where a hot item can be placed without causing damage to other delicate components . If you want better cooling in that particular space, then you need a thicker palmrest, and with a thicker palmrest people will complain about their ThinkPad getting bulkier.
Re: Maybe this will help
cct wrote:http://www2.elecom.co.jp/accessory/cool ... /index.asp
or
Put one on the palm rest area and one of more at the bottom to help dispacth heat. It will dispacth heat and provide some shielding to your hand.
does it really work? pls tell me if it could alleviate the level of heat on the palmrest. thx.
the thinkpad T4x measures 0.75" ( 3/4 of an inch ) in total thickness in the palmrest area from top to bottom. When open !!.
The actual palmrest plastic thinkness is around 2mm, considering the structural strength i doubt if one can go below that on this particular type of ABS plastic.
Asiafish how much does your X4x measure, i doubt if this is much different than the X4x, when it is open. Can you measure the palmest plastic thickness on your X41 ?
asiafish
Not counting the rubber feet its 1/2"
ThinkPad A30p adding thermal pad/sponge onto GPU
by kfzhu1229 » Sat Feb 25, 2017 10:50 pm » in ThinkPad R, A, G and Z Series - 1 Replies
- 1499 Views
Sat Mar 11, 2017 2:40 am
SOLD: X220 Tablet for sale for anyone in Atlanta area
by ThorOfAsgard » Thu May 11, 2017 6:08 am » in Marketplace - Forum Members only - 1 Replies
- 175 Views
Last post by ThorOfAsgard
Thu May 11, 2017 7:46 pm
X220 right click below spacebar not working
by blink » Sun Feb 19, 2017 9:27 pm » in ThinkPad X200/201/220 and X300/301 Series - 2 Replies
- 805 Views
Last post by evening_hunger
Tue Feb 21, 2017 5:51 am
- 1475 Views
Last post by rkawakami
Mon Mar 13, 2017 5:15 pm
